While second-order Møller-Plesset perturbation theory (MP2) offers the simplest and most cost-effective ab initio correlation energy, it requires a separate formulation for degenerate states because the MP2 energy diverges in the zero-gap limit. Second-order Brillouin-Wigner perturbation theory (BW2) requires no such reformulation, as the second-order energy given by,
| (6.27) |
is finite when the orbital energy gap is zero due to the presence of the correlation energy in the denominator. However, the BW2 correlation energy is not size-consistent in the sense that it does not satisfy for two distant, noninteracting subsystems A and B, severely limiting its applicability to chemistry.
Recently, Carter-Fenk and Head-Gordon introduced a size-consistent-to-second-order
Brillouin-Wigner perturbation theory (BW-s2)
that retains this essential property while remaining
finite for zero-gap systems.
178
J. Chem. Phys.
(2023),
158,
pp. 234108.
This theory, based on a repartitioning of the zeroth-order Hamiltonian,
results in a slightly-modified amplitude equation. Whereas
the MP2 amplitudes can be found by solving,
| (6.28) |
the BW-s2 amplitude equation contains a regularizing tensor,
| (6.29) |
In the above equations is composed of Fock matrix elements and reduces to the familiar when canonical orbitals are used, and
| (6.30) |
where,
| (6.31) |
This form of was chosen because it is size-consistent, leading to a size-consistent BW-s2 correlation energy. Physically, represents the correlation energy of a Koopmans’ (static orbital) ionization process. Thus, the occupied orbitals in BW-s2 are imbued with correlation such that the occupied/virtual gap increases. After rotating the occupied orbitals into a basis where is diagonal, the BW-s2 working equation looks like that of MP2,
| (6.32) |
but the orbitals and corresponding anti-symmetrized two-electron integrals have been rotated into the new basis.
In equation 6.30 there is an implicit parameter
that controls the regularization strength.
Initially, this parameter was set to to obtain the exact
result for the two-electron two-orbital system of minimal-basis H
at the dissociation limit,
but was later tuned to achieve much more accurate results
for a wide array of chemical problems ranging from thermochemical properties
to noncovalent interaction energies and closed-shell transition-metal
reaction energies.
184
(2023),
159,
pp. 171104.
The optimal value for the resultant BW-s2() approach
varies somewhat between chemical problems,
but was found to be more flexible than gap-dependent regularizer parameters
like -, -, or -MP2.
A “universal” parameter of was suggested as a compromise to achieve
the best all-around results for a wide array of chemical
properties.
184
(2023),
159,
pp. 171104.
