In practical DFT calculations, the forms of the approximate exchange-correlation functionals used are quite complicated, such that the required integrals involving the functionals generally cannot be evaluated analytically. Q-Chem evaluates these integrals through numerical quadrature directly applied to the exchange-correlation integrand. Several standard quadrature grids are available (“SG-”, ), with a default value that is automatically set according to the complexity of the functional in question.
The quadrature approach in Q-Chem is generally similar to that found in many
DFT programs. The multi-center XC integrals are first partitioned into
“atomic” contributions using a nuclear weight function. Q-Chem uses the
nuclear partitioning of Becke,
87
J. Chem. Phys.
(1988),
88,
pp. 2547.
though without the “atomic
size adjustments” of Ref.
87
J. Chem. Phys.
(1988),
88,
pp. 2547.
. The atomic integrals are
then evaluated through standard one-center numerical techniques. Thus, the
exchange-correlation energy is obtained as
| (5.15) |
where the function is the aforementioned XC integrand and the quantities
are the quadrature weights. The sum over runs over grid points
belonging to atom , which are located at positions , so this approach requires only the choice
of a suitable one-center integration grid (to define the ),
which is independent of nuclear configuration. These grids are implemented in
Q-Chem in a way that ensures that the is rotationally-invariant,
i.e., that is does not change when the molecule undergoes rigid rotation in
space.
611
Chem. Phys. Lett.
(1994),
220,
pp. 377.
Quadrature grids are further separated into radial and angular parts. Within
Q-Chem, the radial part is usually treated by the Euler-Maclaurin scheme
proposed by Murray et al.,
904
Mol. Phys.
(1993),
78,
pp. 997.
which maps the semi-infinite
domain onto and applies the extended trapezoid rule to the
transformed integrand. Alternatively, Gill and Chien proposed a radial scheme
based on a Gaussian quadrature on the interval with a different weight
function.
223
J. Comput. Chem.
(2003),
24,
pp. 732.
This “MultiExp" radial quadrature is exact for
integrands that are a linear combination of a geometric sequence of exponential
functions, and is therefore well suited to evaluating atomic integrals.
However, the task of generating the MultiExp quadrature points becomes
increasingly ill-conditioned as the number of radial points increases, so that
a “double exponential" radial quadrature
892
Theor. Chem. Acc.
(2011),
130,
pp. 645.
891
Theor. Chem. Acc.
(2012),
131,
pp. 1169.
is used
for the largest standard grids in Q-Chem,
892
Theor. Chem. Acc.
(2011),
130,
pp. 645.
891
Theor. Chem. Acc.
(2012),
131,
pp. 1169.
namely SG-2 and SG-3.
283
J. Comput. Chem.
(2017),
38,
pp. 869.
(See
Section 5.5.3.)
