The application of quantum chemical methods to elements in the lower half of the Periodic Table is more difficult than for the lighter atoms. There are two key reasons for this:
the number of electrons in heavy atoms is large
relativistic effects in heavy atoms are often non-negligible
Both of these problems stem from the presence of large numbers of core
electrons and, given that such electrons do not play a significant
direct role in chemical behavior, it is natural to ask whether it is
possible to model their effects in some simpler way. Such enquiries led to the
invention of Effective Core Potentials (ECPs) or pseudopotentials.
Many review articles discussing relativistic effects in chemistry are
available.
233
Annu. Rev. Phys. Chem.
(1985),
36,
pp. 407.
1064
Chem. Rev.
(1988),
88,
pp. 563.
440
Coord. Chem. Rev.
(1996),
147,
pp. 87.
If we seek to replace the core electrons around a given nucleus by a pseudopotential, while affecting the chemistry as little as possible, the pseudopotential should have the same effect on nearby valence electrons as the core electrons. The most obvious effect is the simple electrostatic repulsion between the core and valence regions but the requirement that valence orbitals must be orthogonal to core orbitals introduces additional subtler effects that cannot be neglected.
One of the key issues in the development of ECPs is the definition of the “core”. So-called “large-core” ECPs include all shells except the outermost one, but “small-core” ECPs include all except the outermost two shells. Although the small-core ECPs are more expensive to use (because more electrons are treated explicitly), it is often found that their enhanced accuracy justifies their use.
When an ECP is constructed, it is usually based on either non-relativistic or quasi-relativistic all-electron calculations. As one might expect, the quasi-relativistic ECPs tend to yield better results than their non-relativistic brethren, especially for atoms beyond the 3 block
Q-Chem’s ECP package is integrated with its electron correlation and DFT packages. Of course, no correlation or exchange-correlation energy due to the core electrons is included when using an ECP in a DFT or correlated method, respectively.
The most widely used ECPs today are of the form first proposed by Kahn
et al. in the 1970s.
624
J. Chem. Phys.
(1972),
56,
pp. 2685.
These model the effects of the core by a
one-electron operator whose matrix elements are simply added to the
one-electron Hamiltonian matrix. The ECP operator is given by
| (8.6) |
where the radial potentials have the form
| (8.7) |
and is the spherical harmonic projector of angular momentum . In practice, , or 0 and rarely exceeds 5. In addition, contains a Coulombic term , where is the number of core electrons.
