It can sometimes be desirable to go beyond atomic partial charges to calculate atomic dipoles and quadrupoles.
This is useful in particular for certain types of force fields, which use these terms to more accurately model charge anisotropy.
QChem provides the ability to calculate atomic dipoles and quadrupoles, using a method
inspired by the formulations of Ref.
1194
Chem. Phys. Lett.
(1983),
98,
pp. 86.
We simply evaluate atomic contributions to the multipole moment by assigning contributions from each atom’s basis functions.
However, we avert any basis set dependence and delocalization errors by using intrinsic atomic orbitals,
660
J. Chem. Theory Comput.
(2013),
9,
pp. 4834.
which have been shown to have excellent convergence with basis set.
37
J. Chem. Phys.
(2022),
157,
pp. 094102.
The atomic quadrupoles available from this method are the traceless quadrupoles, which are the more commonly used
type in force field contexts.
We calculate atomic dipoles and (traceless) quadrupoles using the following equations:
| (10.25) |
| (10.26) |
Here A is the atom index, is the vector , and or . is the Kronecker delta function, represents an intrinsic atomic orbital, and are the IAO indices, is the one-particle density matrix, and the superscript on the density matrix indicates that this is the density matrix in the IAO basis. Additionally, the inclusion of , , and (the coordinates of atom A) ensures that the multipoles are origin-invariant.
The calculation of atomic dipoles and quadrupoles is controlled with the following $rem variable:
DO_ATOMIC_MULTIPOLES
Enables atomic multipole calculation
BOOL
Do not calculate IAO atomic multipoles
Calculate IAO atomic multipoles
Example 10.5 Input for calculating atomic dipoles and quadrupoles via the IAO/IBO procedure.
$molecule 0 1 F 0.0000000000 0.0000000000 0.2314949765 H 0.0000000000 0.0000000000 1.1541050235 $end $rem jobtyp sp method hf basis aug-cc-pvtz do_ibo true do_atomic_multipoles true $end $loco min_basis autosad ibo_mem 1000 $end
