The zeroth-order Hamiltonian for XSAPT is taken by the sum of
fragment Fock operators defined by the XPol procedure, and the perturbation is
the usual SAPT intermolecular perturbation
[Eq. (12.53)] less the intermolecular interactions
contained in the XPol fragment Fock operators. A standard SAPT0 correction
(see Section 12.9)
is then computed for each pair of monomers, using Eq. (12.58)
in conjunction with the modified perturbation. This affords the dimer interaction
energy, . The total XSAPT energy is
521
Phys. Chem. Chem. Phys.
(2012),
14,
pp. 7679.
| (12.64) |
which is equal to the sum of the XPol monomer energies plus the pairwise SAPT corrections. In this expression, we have removed the over-counting of two-electron interactions present in Hartree-Fock theory, effectively taking the intrafragment perturbation to first order. The generalization to a Kohn-Sham description of the monomers is straightforward, which extends the SAPT0(KS) approach to clusters larger than dimers.
The inclusion of many-body polarization within the zeroth-order Hamiltonian
makes the subsequent SAPT corrections less meaningful in terms of energy
decomposition analysis. For instance, the first-order electrostatic correction
in XSAPT is not the total electrostatic energy, since the former
corrects for errors in the approximate electrostatic treatment at zeroth order
(i.e., the electrostatic embedding). In order to replenish some of the significance
of the XSAPT electrostatics, a “corrected” electrostatic energy is obtained
by subtracting the XPol embedding potential from the first-order electrostatic energy
obtained in SAPT, effectively removing the zeroth-order corrections from the first-order
electrostatics. The dispersion correction may be
less contaminated, since all of the XSAPT modifications to the traditional SAPT
perturbation are one-electron operators and therefore the pairwise dispersion
correction differs from its traditional SAPT analogue only insofar as the MOs
are perturbed by the electrostatic embedding. This should be kept in mind when
interpreting the output of an XSAPT calculation, although Lao and
Herbert
720
J. Chem. Phys.
(2013),
139,
pp. 034107.
722
J. Phys. Chem. A
(2015),
119,
pp. 235.
later proposed a many-body energy
decomposition scheme for XSAPT that extends traditional SAPT energy
decomposition to systems containing more than two monomers. (The
aforementioned contamination problems are avoid through pairwise
corrections, comparing XSAPT results to
traditional SAPT based on gas-phase monomers.)
An XSAPT calculation is requested by setting JOBTYPE = XSAPT
in the $rem section. The choice of XPol charge embedding is controlled by
the embed and charges keywords in the $xpol input section;
see Section 12.8 and the example provided below. Additional job
control options for the SAPT part of the calculation are specified in the
$sapt input section as described in Section 12.9. Researchers who
use Q-Chem’s XSAPT code are asked to cite
Refs.
584
J. Chem. Phys.
(2011),
134,
pp. 094118.
521
(2012),
14,
pp. 7679.
. The latter contains a thorough
discussion of the theory; a briefer summary can be found in
Ref.
585
Annu. Rep. Comput. Chem.
(2013),
9,
pp. 25.
Example 12.40 Example of an XPol + SAPT0 calculation using ChElPG charges for the XPol calculation and computing and by solving CPHF equations as discussed in Section 12.9.
$molecule 0 1 -- formic acid 0 1 C -1.888896 -0.179692 0.000000 O -1.493280 1.073689 0.000000 O -1.170435 -1.166590 0.000000 H -2.979488 -0.258829 0.000000 H -0.498833 1.107195 0.000000 -- formic acid 0 1 C 1.888896 0.179692 0.000000 O 1.493280 -1.073689 0.000000 O 1.170435 1.166590 0.000000 H 2.979488 0.258829 0.000000 H 0.498833 -1.107195 0.000000 $end $rem JOBTYPE XSAPT BASIS CC-PVDZ METHOD HF $end $xpol embed charges charges CHELPG ! charges derived from electrostatic potential $end $sapt basis projected ! use the pseudocanonicalized dimer basis CPHF ! solve CPHF equations for induction response $end
The latter example is simply a traditional SAPT0 (dimer) calculation but based on zeroth-order monomer wave functions computed from a charge-embedded XPol calculation. The following example corresponds to a truly “extended” SAPT calculation, i.e., one with more than two monomers.
Example 12.41 XSAPT calculation on water tetramer using the LRC-PBEh
functional. Includes the three-body induction couplings that arise at second
order in perturbation theory when the number of monomers is greater than 2 (see
Ref.
521
(2012),
14,
pp. 7679.
-- water
O -0.459965 1.488925 0.391165
H 0.442885 1.099622 0.558106
H -0.551255 2.236567 0.999244
-- water
O -1.111823 -1.126854 0.565807
H -1.153929 -0.145562 0.663733
H -2.016599 -1.451826 0.678719
-- water
O 1.661160 -0.139676 0.530681
H 1.455561 -0.313184 -0.421143
H 1.146044 -0.835459 0.974417
-- water
O 0.201725 -0.384036 -1.774045
H -0.394336 -0.876966 -1.168916
H -0.094680 0.533258 -1.645074
JOBTYPE xsapt
EXCHANGE gen
BASIS 6-31G*
$xpol
embed charges
charges chelpg
$sapt
algorithm mo ! could be ri-mo for RI approximation
basis projected ! default choice; recommended
3b-ind ! include the 3-body induction couplings (optional)
$xc_functional
x wPBE 0.8
x HF 0.2
c PBE 1.0
