For CIS, TDHF, and TDDFT excited-state calculations, we have already mentioned
that Mulliken population analysis of the excited-state electron densities may
be requested by setting POP_MULLIKEN = , and multipole moments of
the excited-state densities will be generated if CIS_MOMENTS =
TRUE. Another useful decomposition for excited states is to separate
the excitation into “particle” and “hole” components, which can then be
analyzed separately.
1093
J. Chem. Theory Comput.
(2011),
7,
pp. 1296.
To do this, we define a density
matrix for the excited electron,
| (10.27) |
| (10.28) |
The quantities and are the transition density
matrices, i.e., the components of the TDDFT eigenvector.
329
Chem. Rev.
(2005),
105,
pp. 4009.
The indices and denote MOs that occupied in the ground state, whereas
and index virtual MOs. Note also that , the difference between the ground- and
excited-state density matrices.
Upon transforming and into the AO basis, one can write
| (10.29) |
where is the total charge that is transferred from the occupied
space to the virtual space. For a CIS calculation, or for TDDFT within the
Tamm-Dancoff approximation,
543
Chem. Phys. Lett.
(2000),
326,
pp. 255.
. For full TDDFT
calculations, may be slightly different than .
Comparison of Eq. (10.29) to Eq. (10.3) suggests that the quantities and are amenable to population analyses of precisely the same sort used to analyze the ground-state density matrix. In particular, represents the th AO’s contribution to the excited electron, while is a contribution to the hole. The sum of these quantities,
| (10.30) |
represents the contribution to arising from the th AO. For the particle/hole density matrices, both Mulliken and Löwdin population analyses available, and are requested by setting CIS_MULLIKEN = TRUE.
CIS_MULLIKEN
CIS_MULLIKEN
Controls Mulliken and Löwdin population analyses for excited-state particle and
hole density matrices.
Do not perform particle/hole population analysis.
Perform both Mulliken and Löwdin analysis of the particle and hole
density matrices for each excited state.
Although the excited-state analysis features described in this section require very
little computational effort, they are turned off by default, because they can generate
a large amount of output, especially if a large number of excited states are requested.
They can be turned on individually, or collectively by setting CIS_AMPL_ANAL =
TRUE. This collective option also requests the calculation of
natural transition orbitals (NTOs),
532
Phys. Chem. Chem. Phys.
(2024),
26,
pp. 3755.
which were introduced in Section 7.14.3.
(NTOs can also be requested without excited-state population analysis. Some
practical aspects of calculating and visualizing NTOs are discussed below, in
Section 10.5.3.)
CIS_AMPL_ANAL
CIS_AMPL_ANAL
Perform additional analysis of CIS and TDDFT excitation amplitudes,
including generation of natural transition orbitals, excited-state
multipole moments, and Mulliken analysis of the excited state densities
and particle/hole density matrices.
Perform additional amplitude analysis.
Do not perform additional analysis.
CIS_AMPL_PRINT
CIS_AMPL_PRINT
15
Print if or is larger than .
EXCIT_ENERGY_COMPONENTS
Compute individual compnents of the CIS/TDDFT excitation energy.
987
J. Phys. Chem. Lett.
(2021),
12,
pp. 2712.
The output is divided into the one-electron components (H);
Fock-matrix type components representing the Coulomb (J1), non-local exchange (K1), and xc potentials (XC1);
and true two-electron components (J2, K2, XC2).
Note that H+J1+K1+XC1 is equivalent to a weighted sum of MO energy differences whereas J2, K2, and XC2 represent the post-MO terms.
For more information see Ref.
650
(2023),
19,
pp. 2340.
Compute excitation energy components.
Do not compute excitation energy components.
Use if more detailed insight into excitation energies is required.
