A variety of CIS-like methods have been proposed that add a limited number of double excitations to the
CIS excitation space,
in order to overcome certain deficiencies of CIS without incurring the prohibitive
cost of a method such as CISD or CCSD that includes the full complement of double excitations.
These “extended” CIS methods are discussed in this section, starting with the original excited CIS (XCIS) procedure of
Maurice and Head-Gordon.
862
J. Phys. Chem.
(1996),
100,
pp. 6131.
The motivation for XCIS stems
from the fact that ROCIS and UCIS are less effective for radicals than CIS is
for closed shell molecules. Using the attachment/detachment density
analysis procedure,
499
J. Phys. Chem.
(1995),
99,
pp. 14261.
532
Phys. Chem. Chem. Phys.
(2024),
26,
pp. 3755.
the failing of ROCIS and UCIS
methodologies for the nitromethyl radical was traced to the neglect of a
particular class of double substitution which involves the simultaneous
promotion of an spin electron from the singly occupied orbital and the
promotion of a spin electron into the singly occupied orbital. The
spin-adapted configurations
| (7.12) |
are of crucial importance. (Here, are virtual orbitals; are occupied orbitals; and are singly-occupied orbitals.) It is quite likely that similar excitations are also very significant in other radicals of interest.
The XCIS proposal, a more satisfactory generalization of CIS to open shell molecules, is to simultaneously include a restricted class of double substitutions similar to those in Eq. (7.12). To illustrate this, consider the resulting orbital spaces of an ROHF calculation: doubly occupied (), singly occupied () and virtual (). From this starting point we can distinguish three types of single excitations of the same multiplicity as the ground state: , and . Thus, the spin-adapted ROCIS wave function is
| (7.13) |
The extension of CIS theory to incorporate higher excitations maintains the ROHF as the ground state reference and adds terms to the ROCIS wave function similar to that of Eq. (7.13), as well as those where the double excitation occurs through different orbitals in the and space:
| (7.14) |
XCIS is defined only from a restricted open shell Hartree-Fock ground state reference, as it would be difficult to uniquely define singly occupied orbitals in a UHF wave function. In addition, unoccupied orbitals, through which the spin-flip double excitation proceeds, may not match the half-occupied orbitals in either character or even symmetry.
For molecules with closed shell ground states, both the HF ground and CIS excited states emerge from diagonalization of the Hamiltonian in the space of the HF reference and singly excited substituted configuration state functions. The XCIS case is different because the restricted class of double excitations included could mix with the ground state and lower its energy. This mixing is avoided to maintain the size consistency of the ground state energy.
With the inclusion of the restricted set of doubles excitations in the excited states, but not in the ground state, it could be expected that some fraction of the correlation energy be recovered, resulting in anomalously low excited state energies. However, the fraction of the total number of doubles excitations included in the XCIS wave function is very small and those introduced cannot account for the pair correlation of any pair of electrons. Thus, the XCIS procedure can be considered one that neglects electron correlation.
The computational cost of XCIS is approximately four times greater than CIS and ROCIS, and its accuracy for open shell molecules is generally comparable to that of the CIS method for closed shell molecules. In general, it achieves qualitative agreement with experiment. XCIS is available for doublet and quartet excited states beginning from a doublet ROHF treatment of the ground state, for excitation energies only.
Example 7.4 An XCIS calculation of excited states of an unsaturated radical, the phenyl radical, for which double substitutions make considerable contributions to low-lying excited states.
$comment C6H5 phenyl radical C2v symmetry MP2(full)/6-31G* = -230.7777459 $end $molecule 0 2 c1 x1 c1 1.0 c2 c1 rc2 x1 90.0 x2 c2 1.0 c1 90.0 x1 0.0 c3 c1 rc3 x1 90.0 c2 tc3 c4 c1 rc3 x1 90.0 c2 -tc3 c5 c3 rc5 c1 ac5 x1 -90.0 c6 c4 rc5 c1 ac5 x1 90.0 h1 c2 rh1 x2 90.0 c1 180.0 h2 c3 rh2 c1 ah2 x1 90.0 h3 c4 rh2 c1 ah2 x1 -90.0 h4 c5 rh4 c3 ah4 c1 180.0 h5 c6 rh4 c4 ah4 c1 180.0 rh1 = 1.08574 rh2 = 1.08534 rc2 = 2.67299 rc3 = 1.35450 rh4 = 1.08722 rc5 = 1.37290 tc3 = 62.85 ah2 = 122.16 ah4 = 119.52 ac5 = 116.45 $end $rem BASIS = 6-31+G* EXCHANGE = hf MEM_STATIC = 80 INTSBUFFERSIZE = 15000000 SCF_CONVERGENCE = 8 CIS_N_ROOTS = 5 XCIS = true $end
Spin-flip extended CIS (SF-XCIS)
185
J. Chem. Phys.
(2008),
129,
pp. 064104.
is a
spin-complete extension of the spin-flip single excitation configuration
interaction (SF-CIS) method.
689
Chem. Phys. Lett.
(2002),
350,
pp. 522.
The method includes all configurations in which no more
than one virtual level of the high spin triplet reference
becomes occupied and no more than one doubly occupied level becomes vacant.
SF-XCIS is defined only from a restricted open shell Hartree-Fock triplet ground state reference. The final SF-XCIS wave functions correspond to spin-pure (singlet or triplet) states. The fully balanced treatment of the half-occupied reference orbitals makes it very suitable for applications with two strongly correlated electrons, such as single bond dissociation, systems with important diradical character or the study of excited states with significant double excitation character.
The computational cost of SF-XCIS scales in the same way with molecule size as CIS itself, with a pre-factor 13 times larger.
Example 7.5 A SF-XCIS calculation of ground and excited states of trimethylenemethane (TMM) diradical, for which double substitutions make considerable contributions to low-lying excited states.
$molecule 0 3 C C 1 CC1 C 1 CC2 2 A2 C 1 CC2 2 A2 3 180.0 H 2 C2H 1 C2CH 3 0.0 H 2 C2H 1 C2CH 4 0.0 H 3 C3Hu 1 C3CHu 2 0.0 H 3 C3Hd 1 C3CHd 4 0.0 H 4 C3Hu 1 C3CHu 2 0.0 H 4 C3Hd 1 C3CHd 3 0.0 CC1 = 1.35 CC2 = 1.47 C2H = 1.083 C3Hu = 1.08 C3Hd = 1.08 C2CH = 121.2 C3CHu = 120.3 C3CHd = 121.3 A2 = 121.0 $end $rem UNRESTRICTED = false SF-XCIS runs from ROHF triplet reference EXCHANGE = HF BASIS = 6-31G* SCF_CONVERGENCE = 10 SCF_ALGORITHM = DM MAX_SCF_CYCLES = 100 SPIN_FLIP_XCIS = true Do SF-XCIS CIS_N_ROOTS = 3 CIS_SINGLETS = true Do singlets CIS_TRIPLETS = true Do triplets $end
Spin-Adapted Spin-Flip CIS (SA-SF-CIS)
1435
J. Chem. Phys.
(2015),
143,
pp. 234107.
is a spin-complete
extension of the spin-flip single excitation configuration interaction (SF-CIS)
method.
689
Chem. Phys. Lett.
(2002),
350,
pp. 522.
Unlike SF-XCIS, SA-SF-CIS only includes the minimal
set of electronic configurations needed to remove the spin contamination in
the conventional SF-CIS method. The target SA-SF-CIS states have spin
eigenvalues one less than the reference ROHF state, i.e., if singlet states () are targeted then the reference
state should be a triplet (), or if doublet states () are targeted then the reference state should be a
quartet (). The SA-SF-CIS approach uses a tensor equation-of-motion formalism,
1435
J. Chem. Phys.
(2015),
143,
pp. 234107.
such that the dimension of the CI vectors in SA-SF-CIS remains exactly the same as that in conventional SF-CIS.
A DFT correction to SA-SF-CIS (i.e., SA-SF-TDDFT) can be added.
1435
J. Chem. Phys.
(2015),
143,
pp. 234107.
As with other SF-TDDFT methods,
1436
J. Chem. Phys.
(2021),
155,
pp. 124111.
the BH&HLYP functional has become something of a de facto standard choice.
525
Acc. Chem. Res.
(2016),
49,
pp. 931.
Example 7.6 An SA-SF-DFT calculation of singlet ground and excited states of ethylene.
$molecule 0 3 C C 1 B1 H 1 B2 2 A1 H 1 B3 2 A2 3 D1 H 2 B4 1 A3 3 D2 H 2 B5 1 A4 3 D3 B1 1.32808942 B2 1.08687297 B3 1.08687297 B4 1.08687297 B5 1.08687297 A1 121.62604150 A2 121.62604150 A3 121.62604150 A4 121.62604150 D1 180.00000000 D2 0.00000000 D3 180.00000000 $end $rem EXCHANGE bhhlyp BASIS cc-pvtz BASIS2 sto-3g UNRESTRICTED false CIS_N_ROOTS 5 SASF_CIS 1 CIS_TRIPLETS false $end
