The dual-basis
approximation
779
J. Phys. Chem. A
(2004),
108,
pp. 3206.
1213
J. Chem. Phys.
(2006),
125,
pp. 074108.
1216
J. Phys. Chem. A
(2006),
110,
pp. 13915.
313
Mol. Phys.
(2007),
105,
pp. 2731.
1215
Mol. Phys.
(2007),
105,
pp. 2455.
1212
J. Chem. Theory Comput.
(2009),
5,
pp. 1560.
to self-consistent field (HF or DFT) energies provides an efficient means for
obtaining large basis set effects at vastly less cost than a full SCF
calculation in a large basis set. First, a full SCF calculation is performed
in a chosen small basis (specified by BASIS2). Second, a single
SCF-like step in the larger, target basis (specified, as usual, by
BASIS) is used to perturbatively approximate the large basis energy.
This correction amounts to a first-order approximation in the change in density
matrix, after the single large-basis step:
| (4.59) |
Here (in the large basis) is built from the converged (small basis) density matrix. Thus, only a single Fock build is required in the large basis set. Currently, HF and DFT energies (SP) as well as analytic first derivatives (FORCE or OPT) are available.
Note: As of version 4.0, first derivatives of unrestricted dual-basis DFT energies—though correct—require a code-efficiency fix. We do not recommend use of these derivatives until this improvement has been made.
Across the G3 set
279
J. Chem. Phys.
(1991),
94,
pp. 7221.
278
J. Chem. Phys.
(1998),
109,
pp. 7764.
277
J. Chem. Phys.
(2000),
112,
pp. 7374.
of 223
molecules, using cc-pVQZ, dual-basis errors for B3LYP are 0.04 kcal/mol
(energy) and 0.03 kcal/mol (atomization energy per bond) and are at least an
order of magnitude less than using a smaller basis set alone. These errors are
obtained at roughly an order of magnitude savings in cost, relative to the
full, target-basis calculation.
