Vibrational analysis is an extremely important tool for the quantum chemist,
supplying a molecular fingerprint which is invaluable for aiding identification
of molecular species in many experimental studies. Q-Chem includes a
vibrational analysis package that can calculate vibrational frequencies and
their infrared and Raman activities.
607
Chem. Phys. Lett.
(1995),
247,
pp. 120.
Vibrational frequencies are calculated by either using an analytic Hessian (if available;
see Table 9.2) or, numerical finite difference of the
gradient. The default setting in Q-Chem is to use the highest analytical
derivative order available for the requested theoretical method.
The performance of various ab initio theories in determining vibrational
frequencies has been well documented.
905
Chem. Phys. Lett.
(1992),
199,
pp. 551.
610
J. Chem. Phys.
(1993),
98,
pp. 5612.
1141
J. Phys. Chem.
(1996),
100,
pp. 16502.
When calculating analytic frequencies at the HF and DFT levels of theory, the
coupled-perturbed SCF equations must be solved. This is the most time-consuming
step in the calculation, and also consumes the most memory. The amount of
memory required is where is the number of basis functions,
and the number of atoms. This is an order more memory than is required for
the SCF calculation, and is often the limiting consideration when treating
larger systems analytically. Q-Chem incorporates a new approach to this
problem that avoids this memory bottleneck by solving the CPSCF equations in
segments.
671
Mol. Phys.
(2002),
100,
pp. 1755.
Instead of solving for all the perturbations at
once, they are divided into several segments, and the CPSCF is applied for one
segment at a time, resulting in a memory scaling of ,
where is the number of segments. This option is invoked automatically by the program.
After a vibrational analysis, Q-Chem computes useful statistical
thermodynamic properties at standard temperature and pressure following the rigid-rotor-harmonic-oscillator (RRHO) approach. These include the zero-point vibration energy (ZPVE) and, translational, rotational and
vibrational, entropies and enthalpies. Note: in the Q-Chem output the “total enthalpy”
actually means the total enthalpy correction to the internal energy. One must add this
“total enthalpy” to the internal energy to obtain the total enthalpy in common sense.
In addition to these thermal corrections, Q-Chem also prints the interpolated vibrational entropy and enthalpy according to the
quasi-RRHO (qRRHO) approach by Head-Gordon and co-workers,
776
J. Phys. Chem. C
(2015),
119,
pp. 1840.
which extends Grimme’s previous scheme
460
Chem. Eur. J
(2012),
18,
pp. 9955.
to address low-frequency vibrations; Section 10.7.3.
In order to carry out a frequency analysis users must at a minimum provide a molecule within the $molecule keyword and define an appropriate level of theory within the $rem keyword using the $rem variables EXCHANGE, CORRELATION (if required) (Chapter 4) and BASIS (Chapter 8). Since the default type of job (JOBTYPE) is a single point energy (SP) calculation, the JOBTYPE $rem variable must be set to FREQ.
Users should also be aware that the quality of the quadrature grid used in DFT calculations is more important when calculating second derivatives. The default grid for some atoms has changed in Q-Chem 3.0 (see Section 5.5) and for this reason vibrational frequencies may vary slightly form previous versions. It is recommended that a grid larger than the default grid is used when performing frequency calculations.
Vibrational frequencies.
Raman and IR activities and intensities (requires $rem DORAMAN).
Atomic masses.
Zero-point vibrational energy.
Translational, rotational, and vibrational, entropies and enthalpies.
DORAMAN
DORAMAN
Controls calculation of Raman intensities. Requires JOBTYPE to be set
to FREQ
Do not calculate Raman intensities.
Do calculate Raman intensities.
VIBMAN_PRINT
VIBMAN_PRINT
Standard full information print out.
If VCI is TRUE, overtones and combination bands are also printed.
3
Level 1 plus vibrational frequencies in atomic units.
4
Level 3 plus mass-weighted Hessian matrix, projected mass-weighted Hessian
matrix.
6
Level 4 plus vectors for translations and rotations projection matrix.
Use the default.
CPSCF_NSEG
CPSCF_NSEG
Determine the number of segments based on the memory request and MEM_TOTAL
User-defined. Use segments when solving the CPSCF equations.
Use the default.
Example 10.28 EDF1/6-31+G* optimization followed by vibrational analysis. Doing the vibrational analysis at a stationary point is necessary for the results to be valid.
$molecule 0 1 O C 1 co F 2 fc 1 fco H 2 hc 1 hco 3 180.0 co = 1.2 fc = 1.4 hc = 1.0 fco = 120.0 hco = 120.0 $end $rem JOBTYPE opt METHOD edf1 BASIS 6-31+G* $end @@@ $molecule read $end $rem JOBTYPE freq METHOD edf1 BASIS 6-31+G* $end
Numerical values in the following discussion correspond to Example 10.7.1.1 and the referenced partition functions come from the textbook by McQuarrie & Simon. Note that Q-Chem assumes K and atm by default; see Section 10.7.2 for instructions on how to modify these choices.
The quantity listed as zero-point energy (ZPE),
Zero point vibrational energy: 12.695 kcal/mol
corresponds to . Within Q-Chem the vibrational entropy () is computed from the bottom of the well rather than from the zero-point level, and thus includes the ZPE. This corresponds to a vibrational partition function
| (10.38) |
where indexes vibrational modes and is the vibrational temperature of the th mode. This expression can be altered by a factor of to start at the first vibrational level rather than the bottom of the well. The vibrational entropy is then
| (10.39) |
and for Example 10.7.1.1 it is reported as
Vibrational Entropy: 0.620 cal/mol.K
The vibrational enthalpy,
| (10.40) |
is reported as
Vibrational Enthalpy: 12.839 kcal/mol
The rotational and translational enthalpy are multiples of and then then
Total Enthalpy: 15.209 kcal/mol
is given by
| (10.41) |
where the final contribution of comes from the usual definition, . Translational and rotational entropies can be computed from the corresponding ideal-gas partition functions; see Ref. .
For thermochemical calculations performed in implicit solvent (using models described in Section 11.2),
there is a subtle point with some controversy attached.
547
J. Phys. Chem. A
(2010),
114,
pp. 13442.
1090
J. Phys. Chem. B
(2011),
115,
pp. 14556.
195
Int. J. Quantum Chem.
(2014),
114,
pp. 1350.
529
Wiley Interdiscip. Rev.: Comput. Mol. Sci.
(2021),
11,
pp. e1519.
This regards whether vibrational contributions
to the free energy should be included or not. In nearly all cases, continuum solvation models are parameterized in order
to reproduce experimental free energies of solvation () using rigid gas-phase geometries for the
solute molecules. There is a potential double-counting problem if from a vibrational frequency calculation
in implicit solvent is added, which might be avoided by instead using gas-phase harmonic frequencies for the solute.
547
J. Phys. Chem. A
(2010),
114,
pp. 13442.
However, the difference between these procedures is negligible ( kcal/mol). for the small-molecule data sets that are used
to train implicit solvent models,
1090
J. Phys. Chem. B
(2011),
115,
pp. 14556.
and only by using solution-phase vibrational frequencies can one obtain corrections
to arising from solvation-induced changes in geometry, which might be significant for larger molecules.
Note that Q-Chem’s harmonic frequency engine assumes a gas-phase molecule (even in the presence of continuum solvent), so that
rotational and translational contributions to the free energy are printed out in every case. These should not be included in
solution-phase free energy differences.
