Q-Chem features a number of methods to apply pressure to a chemical system
during a geometry optimization or an AIMD simulation.
1136
Int. J. Quantum Chem.
(2021),
121,
pp. e26208.
The
following methods are implemented:
| Hydrostatic Compression Force Field (HCFF)
1133
ChemPhysChem (2019), 20, pp. 2742. Link |
Section 9.5.2 |
| eXtended Hydrostatic Compression Force Field (X-HCFF)
1135
J. Chem. Phys. (2020), 153, pp. 134503. Link |
Section 9.5.3 |
| Gaussians On Surface Tesserae Simulate HYdrostatic Pressure (GOSTSHYP)
1058
J. Chem. Theory Comput. (2021), 17, pp. 583. Link |
Section 9.5.4 |
To invoke one of these methods, set DISTORT = TRUE in the $rem section. By setting the $rem variable scf_final_print = 1, the energy contribution due to pressure is printed in the output.
DISTORT
DISTORT
Specifies whether to apply pressure or external force to a chemical system
False
False
Do not use pressure or force
True
Use pressure or force
Set to true to apply pressure or force.
The parameters of the jobs are set via options specified in the $distort input section. The format of the $distort section is analogous to the $rem section:
$distort <Keyword> <parameter/option> $end
Note: The following job control variables belong only in the $distort section. Do not place them in the $rem section.
Model
Specifies which model is used to distort the molecule.
INPUT SECTION: $distort
HCFF
1133
ChemPhysChem
(2019),
20,
pp. 2742.
XHCFF
1135
J. Chem. Phys.
(2020),
153,
pp. 134503.
GOSTSHYP
1058
(2021),
17,
pp. 583.
EFEI
External Force is Explicitly Included (Section 9.6)
Please refer to the following subsections for recommendations on which
model to use.
Pressure
Specifies the pressure (in MPa) used to compress the molecule.
DOUBLE
User defined
NPoints_Heavy
Specifies the number of tessellation points per non-hydrogen atom.
110
User defined
Use the default.
NPoints_Hydrogen
Specifies the number of tessellation points per hydrogen atom.
110
User defined
Use the default.
Scaling
Specifies the scaling factor of the atomic van der Waals radii used
in the tessellation of the molecular surface, which is used in the pressure models.
DOUBLE
1.2
User defined
Increase when modeling a chemical complex to make sure that the complex is
placed inside a single cavity.
1058
(2021),
17,
pp. 583.
A value of 1.0 was suggested
to be used in the X-HCFF model.
1135
J. Chem. Phys.
(2020),
153,
pp. 134503.
Screener
Enables/disables Integral screening for gostshyp calculations.
BOOL
True
True
Enable integral screening for gostshyp
False
Disable integral screening for gostshyp
Use default. Disabling integral screening will lead to much higher memory usage
and severe performance drops.
