12.14 The XPol+SAPT (XSAPT) Method
12.14.1 Introduction
The “XSAPT” method, which may be regarded either as an acronym for “XPol+SAPT” or for “extended” symmetry adapted perturbation theory (SAPT), was originally introduced by Jacobson and Herbert 540 Jacobson L. D., Herbert J. M.
(2011), 134, pp. 094118.
, 483 Herbert J. M. et al.
(2012), 14, pp. 7679.
as a low-scaling, systematically-improvable method for intermolecular interactions that could be applicable to large systems. The idea was to replace the need for empirical parameters in the XPol method with on-the-fly evaluation of exchange-repulsion and dispersion interactions via pairwise-additive SAPT. Stated differently, XSAPT uses XPol to evaluate many-body (non-pairwise-additive) polarization effects, but then assumes that dispersion and exchange-repulsion interactions are pairwise additive, and evaluates them via pairwise SAPT0 or SAPT0(KS) calculations. The method was significantly extended by Lao, Herbert, and co-workers, 667 Lao K. U., Herbert J. M.
J. Phys. Chem. Lett.
(2012), 3, pp. 3241.
, 668 Lao K. U., Herbert J. M.
(2013), 139, pp. 034107.
, 670 Lao K. U., Herbert J. M.
(2015), 119, pp. 235.
, 672 Lao K. U., Herbert J. M.
(2018), 14, pp. 2955.
, 673 Lao K. U., Herbert J. M.
(2018), 14, pp. 5128.
, 170 Carter-Fenk K. et al.
(2019), 10, pp. 2706.
, 743 Liu K.-Y., Carter-Fenk K., Herbert J. M.
(2019), 151, pp. 031102.
, 414 Gray M., Herbert J. M.
(2021), 155, pp. 034103.
with various approximations applied in place of the SAPT0 or SAPT0(KS) dispersion terms, 169 Carter-Fenk K., Lao K. U., Herbert J. M.
Acc. Chem. Res.
(2021), 54, pp. 3679.
which are both the least accurate and most expensive contributions to second-order SAPT. Overviews of of XSAPT-based methods can be found in Refs.  670 Lao K. U., Herbert J. M.
and 169 Carter-Fenk K., Lao K. U., Herbert J. M.
Acc. Chem. Res.
and implementation details can be found in Refs.  483 Herbert J. M. et al.
, and 743 Liu K.-Y., Carter-Fenk K., Herbert J. M.
. In particular, the XSAPT+MBD method 170 Carter-Fenk K. et al.
stands out as a way to obtain qualitative insight about noncovalent interactions in large systems, backed by quantitative energetics calculations. 169 Carter-Fenk K., Lao K. U., Herbert J. M.
Acc. Chem. Res.
In many cases, this type of analysis has upended textbook “conventional wisdom", as reviewed in Ref.  491 Herbert J. M.
(2021), 125, pp. 7125.
