7.12.10 Job Control for the RASCI1 Implementation
At present the RASCI1 and RASCI2 implementations employ different keywords (which will be reconciled in a future version). This subsection applies to RASCI1 (spin adapted algorithm using exact integrals).
The use of the RASCI1 methodology is controlled by setting the $rem variable CORRELATION to RASCI and EXCHANGE should be set to HF. The RASCI1 implementation is only compatible with even numbers of electrons and restricted orbitals, i.e., UNRESTRICTED = FALSE.
The minimum input also requires specifying the desired (non-zero) value for RAS_ROOTS, the number of electrons in the “active” RAS2 space and the number of orbitals in RAS1 and RAS2 subspaces.
RAS_ROOTS
RAS_ROOTS
       n n>0 Compute n RAS-CI states
       None. Only works with RAS-CI.
RAS_ELEC
RAS_ELEC
       Sets the number of electrons in RAS2 (active electrons).
       n User-defined integer, n>0
RAS_ELEC_ALPHA
RAS_ELEC_ALPHA
       Sets the number of spin-α electrons in RAS2 (active electrons).
RAS_ELEC_BETA
RAS_ELEC_BETA
       Sets the number of spin-β electrons in RAS2 (active electrons).
RAS_ACT
RAS_ACT
       Sets the number of orbitals in RAS2 (active orbitals).
RAS_OCC
RAS_OCC
       Sets the number of orbitals in RAS1
       These are the initial doubly occupied orbitals (RAS1) before including h⁢o⁢l⁢e type of excitations. The RAS1 space starts from the lowest orbital up to RAS_OCC, i.e. no frozen orbitals option available yet. Only works with RAS-CI.
RAS_DO_HOLE
RAS_DO_HOLE
       Controls the presence of hole excitations in the RAS-CI wave function.
       TRUE Include hole configurations (RAS1 to RAS2 excitations) FALSE Do not include hole configurations
RAS_DO_PART
RAS_DO_PART
       Controls the presence of particle excitations in the RAS-CI wave function.
       TRUE Include particle configurations (RAS2 to RAS3 excitations) FALSE Do not include particle configurations
RAS_AMPL_PRINT
RAS_AMPL_PRINT
       Defines the absolute threshold (×102) for the CI amplitudes to be printed.
       10 0.1 minimum absolute amplitude
       n User-defined integer, n≥0
RAS_ACT_ORB
RAS_ACT_ORB
       Sets the user-selected active orbitals (RAS2 orbitals).
       INTEGER ARRAY
       From RAS_OCC + 1 to RAS_OCC + RAS_ACT
       [i,j,k⁢…] The number of orbitals must be equal to the RAS_ACT variable
RAS_NATORB
RAS_NATORB
       Controls the computation of the natural orbital occupancies.
       TRUE Compute natural orbital occupancies for all states FALSE Do not compute natural orbital occupancies
RAS_NATORB_STATE
RAS_NATORB_STATE
       Saves the natural orbitals of the ith RAS-CI computed state into the .fchk file.
       i Saves the natural orbitals for the ith state
       None. Only works with RAS-CI and if GUI = 2.
RAS_GUESS_CS
RAS_GUESS_CS
       Controls the number of closed shell guess configurations in RAS-CI.
       n Imposes to start with n closed shell guesses
       Only relevant for the computation of singlet states. Only works with RAS-CI.
RAS_SPIN_MULT
RAS_SPIN_MULT
       Specifies the spin multiplicity of the roots to be computed
       1 Singlet states
       0 Compute any spin multiplicity 2⁢n+1 User-defined integer, n≥0
       RAS_SPIN_MULT option is only available for MS=0 systems, that is, with the same number of α and β electrons.
RAS_PT2
RAS_PT2
       Perform second-order perturbative correction to RAS-CI energy
       TRUE Compute RASCI(2) energy corrections FALSE Do not compute RASCI(2) energy corrections
RAS_PT2_PARTITION
RAS_PT2_PARTITION
       Specifies the partitioning scheme in RASCI(2)
       1 Davidson-Kapuy (DK) partitioning
       2 Epstein-Nesbet (EN) partitioning 0 Do both DK and EN partitionings
       Only for RAS-CI if RAS_PT2 is set to true.
RAS_PT2_VSHIFT
RAS_PT2_VSHIFT
       Defines the energy level shift (×103⁢a⁢u) in RASCI(2)
RAS_SRDFT
RAS_SRDFT
       Perform short-range density functional RAS-CI calculation
       TRUE Compute RASCI-s⁢rDFT states and energies FALSE Do not perform a RASCI-s⁢rDFT calculation
       None. Only works with RAS-CI. RAS_SRDFT_EXC and RAS_SRDFT_COR need to be set.
RAS_SRDFT_EXC
RAS_SRDFT_EXC
       Define short-range exchange functional
       No default
       NAME Use RAS_SRDFT_EXC = NAME, where NAME is one of the short-range exchange functionals listed in Section 5.3.3
RAS_SRDFT_COR
RAS_SRDFT_COR
       Define short-range correlation functional
       No default
       NAME Use RAS_SRDFT_COR = NAME, where NAME is one of the short-range correlation functionals listed in Section 5.3.4
RAS_OMEGA
RAS_OMEGA
       Sets the Coulomb range-separation parameter within the RAS-CI-s⁢rDFT method.
       400 (ω=0.4 bohr-1)
       None. Range-separation parameter is typical indicated by ω or μ. Only works with RAS-CI.
RAS_SRDFT_DAMP
RAS_SRDFT_DAMP
       Sets damping factor (α<1) in the RAS-CI-s⁢rDFT method.
       REAL
       0.5 (α=0.5)
       α Damping factor 0<α<1
       Modify in case of convergence issues along the RAS-CI-s⁢rDFT iterations. Only works with RAS-CI
RAS_SRDFT_SA_ROOTS
RAS_SRDFT_SA_ROOTS
       Sets the list of roots used to build the state averaged reference density in RAS-CI-srDFT.
       INTEGER ARRAY
       All computed states
       [i,j,k⁢…] List of states.
RAS_NFRAG
RAS_NFRAG
       If n>0 activates the excitation analysis in RAS-CI
       n Number of fragments to be considered
       Only for RAS-CI. The printed information level is controlled by RAS_PRINT.
RAS_NFRAG_ATOMS
RAS_NFRAG_ATOMS
       Sets the number of atoms in each fragment.
       INTEGER ARRAY
       [i,j,k⁢…] The sum of the numbers must be equal to the total number of atoms in the systems
RAS_FRAG_SETS
RAS_FRAG_SETS
       Defines the number of orbitals in each disjoint set to perform orbital localization.
       INTEGER ARRAY
       [NOcc,NAct,NVir] Number of orbitals within RAS1, RAS2 and RAS3 spaces
       [i,j,k⁢…] Defines sets of canonical MOs to be localized into n fragments
       Setting within RAS1, RAS2 and RAS3 spaces alleviates the computational cost of the localization procedure. It might also result in improved fragment orbitals. Only works with RAS-CI.
CALC_SOC
CALC_SOC
       Controls whether to calculate the SOC constants for EOM-CC, RAS-CI, ADC, TDDFT/TDA and TDDFT.
       INTEGER/LOGICAL
       FALSE Do not perform the SOC calculation. TRUE Perform the SOC calculation.
       In addition to TRUE and FALSE, the EOM-CC code has more variants of SOC evaluation; see Section 7.10.20.4.
RAS_SOC_2E
RAS_SOC_2E
       Controls whether to compute two-electron mean-field contribution to RAS-CI SOC.
       FALSE Do not compute two-electron mean-field contribution. TRUE Compute two-electron mean-field contribution.
RAS_SOC_SYM_DENS
RAS_SOC_SYM_DENS
       Controls whether to perform averaging of α and β densities.
       FALSE Do not average α and β densities . TRUE Average α and β densities.
