13.2 Intracules
13.2.5 Intracule Job Control
INTRACULE
INTRACULE
WIG_MEM
WIG_MEM
       Reduce memory required in the evaluation of W⁢(u,v).
WIG_LEB
WIG_LEB
WIG_GRID
WIG_GRID
       194
N_WIG_SERIES
N_WIG_SERIES
       10
       n<100
N_I_SERIES
N_I_SERIES
       Sets summation limit for series expansion evaluation of in⁢(x).
       40
       n>0
N_J_SERIES
N_J_SERIES
       Sets summation limit for series expansion evaluation of jn⁢(x).
       40
       n>0
