5.11.3 Job Control
A CDFT calculation is requested by setting CDFT = TRUE in the $rem section. A $cdft input section needs to be specified as described above. Three SCF algorithms are currently available for CDFT calculations: DIIS, RCA, and the combined RCA-DIIS algorithm. Additional job control variables are described below.
CDFT
CDFT
       Initiates a constrained DFT calculation
       TRUE Perform a Constrained DFT Calculation FALSE No Density Constraint
       Set to TRUE if a Constrained DFT calculation is desired.
CDFT_POSTDIIS
CDFT_POSTDIIS
       Controls whether the constraint is enforced after DIIS extrapolation.
       TRUE Enforce constraint after DIIS FALSE Do not enforce constraint after DIIS
       Use the default unless convergence problems arise, in which case it may be beneficial to experiment with setting CDFT_POSTDIIS to FALSE. With this option set to TRUE, energies should be variational after the first iteration.
CDFT_PREDIIS
CDFT_PREDIIS
       Controls whether the constraint is enforced before DIIS extrapolation.
       TRUE Enforce constraint before DIIS FALSE Do not enforce constraint before DIIS
       Use the default unless convergence problems arise, in which case it may be beneficial to experiment with setting CDFT_PREDIIS to TRUE. Note that it is possible to enforce the constraint both before and after DIIS by setting both CDFT_PREDIIS and CDFT_POSTDIIS to TRUE.
CDFT_THRESH
CDFT_THRESH
       Threshold that determines how tightly the constraint must be satisfied.
       5
       N Constraint is satisfied to within 10-N.
       Default value is set to match SCF_CONVERGENCE. Use the default unless problems occur.
CDFT_MAXITER
CDFT_MAXITER
       Maximum number of iterations for converging the constraint.
       20
       N A maximum of N microiterations will be attempted.
       Default value is expected to be sufficient in most situations.
CDFT_PRINT
CDFT_PRINT
       Whether detailed information about CDFT iterations should be printed in the output file.
       TRUE Print detailed information. FALSE Do not print detailed information.
       Use the default and invoke additional printing for troubleshooting.
CDFT_BECKE_POP
CDFT_BECKE_POP
       Whether the calculation should print the Becke atomic charges at convergence
       TRUE Print populations FALSE Do not print them
       Use the default. Note that the Mulliken populations printed at the end of an SCF run will not typically add up to the prescribed constraint value. Only the Becke populations are guaranteed to satisfy the user-specified constraints.
