5.3.8 Semi-Empirical Functionals
The following semi-empirical methods are available in Q-Chem:
    HF-3c: It is an HF-based semi-empirical method which is used with a minimal basis called MINIX. All the elements from H to Xe are supported. For the elements from Rb (Z=37) to Xe (Z=54), def2-ECP must be used. 1166 Sure R., Grimme S.
    (2013), 34, pp. 1672.
    PBEh-3c: It is a DFT based method which is used with def2-mSVP basis set.This is available for all the elements from H to Rn. For the elements from Rb (Z=37) to Rn (Z=86), def2-ECP has to be used. It is a more accurate method than HF-3c as it has correlation, 418 Grimme S. et al.
    (2015), 143, pp. 054107.
    although the double-ζ basis set makes it more expensive for large molecules.
Note:  The HF-3c and PBEh-3c methods were parameterized for use with the aforementioned basis sets. Although Q-Chem does not enforce this, other basis sets should not be used unless there is a good reason for doing so, and only then with caution as the results may not match published accuracy.
Example 5.4  Q-Chem input for HF-3c method.
 method  hf-3c
 basis   minix
 ecp     def2-ecp
        I         0.6539056222    0.0300979939    0.0000000000
        O        -2.8593081518    0.0835488510    0.0000000000
        H        -1.8947008157    0.2596704547    0.0000000000
        H        -2.8641221666   -0.8778240298    0.0000000000
Example 5.5  Q-Chem input for PBEh-3c method.
   METHOD           PBEh-3c
   BASIS            def2-mSVP
   XC_GRID          000099000590
   INCDFT           0
   INCFOCK          0
   SCF_CONVERGENCE  8
   THRESH           14
   SYMMETRY         false
   SYM_IGNORE       true
