7.7 Non-Orthogonal Configuration Interaction with Single Substitutions (NOCIS) and Static Exchange (STEX)
7.7.1 NOCIS
The motivation for NOCIS 891 Oosterbaan K. J., White A. F., Head-Gordon M.
(2018), 149, pp. 044116.
, 892 Oosterbaan K. J., White A. F., Head-Gordon M.
(2019), 15, pp. 2966.
, 890 Oosterbaan K. J. et al.
(2020), 22, pp. 8182.
is the desire to improve on CIS while still maintaining a reasonably low computational scaling. It does so by including orbital relaxation, which CIS neglects altogether, and the non-orthogonal interaction between multiple core-hole references, such as the O 1⁢s orbitals in O2.
A brief overview of the NOCIS algorithm is as follows: after a ground-state orbital optimization, a Maximum Overlap Method (MOM) 381 Gilbert A. T. B., Besley N. A., Gill P. M. W.
(2008), 112, pp. 13164.
is done for an ionization from each localized core orbital of interest. This introduces orbital relaxation, and also renders the excited states non-orthogonal to the ground state. The Hamiltonian, overlap, and total spin squared matrices are constructed using the Slater-Condon rules for matrix elements between determinants which share a common set of orbitals and NOCI for the remaining matrix elements 1187 Thom A. J. W., Head-Gordon M.
(2009), 131, pp. 124113.
. Finally, the generalized eigenvalue problem is solved.
