Many users will find that the library of built-in ECPs is adequate for their needs. However, if you need to use an ECP that is not built into Q-Chem, you can enter it in much the same way as you can enter a user-defined orbital basis set; see Chapter 8.
To apply a user-defined ECP, you must set the ECP and BASIS keywords in $rem to GEN. You then add a $ecp block that defines your ECP, element by element, and a $basis block that defines your orbital basis set, separating elements by asterisks.
The syntax within the $basis block is described in Chapter 8. The syntax for each record within the $ecp block is as follows:.
$ecp
For each atom that will bear an ECP:
Chemical symbol for the atom
ECP name; the value for the ECP; number of core electrons removed
For each ECP component (in the order unprojected,
The component name
The number of Gaussians in the component
For each Gaussian in the component
The power of ; the exponent ; the contraction coefficient
A sequence of four asterisks (i.e., ****)
Note: 1. All of the information in the $ecp block is case-insensitive. 2. The power of (which includes the Jacobian factor) must be 0, 1, or 2. 3. If an or term is included you must include the rem keyword “ECP_FIT = TRUE”.
Example 8.10 Optimizing the HF geometry of AlH using a user-defined ECP and basis set on Al and the 3-21G basis on H.
Al
H1 Al r
H2 Al r H1 120.0
H3 Al r H1 120.0 H2 180.0
r = 1.6
JOBTYPE opt Geometry optimization
METHOD hf Hartree-Fock theory
ECP gen User-defined ECP
BASIS gen User-defined basis
ECP_FIT true
$ecp
Al
Stevens_ECP 2 10
d potential
1 1.95559 -3.03055
s-d potential
0 7.78858 6.04650
2 1.99025 18.87509
p-d potential
0 2.83146 3.29465
2 1.38479 6.87029
$basis
Al
SP 3 1.00
0.90110 -0.30377 -0.07929
0.44950 0.13382 0.16540
0.14050 0.76037 0.53015
SP 1 1.00
0.04874 0.32232 0.47724
H
3-21G
