11.8 Polarizable Embedding Model
11.8.1 Introduction
The polarizable embedding (PE) model is a fragment-based quantum-classical explicit embedding scheme to model molecular properties in complex heterogeneous environments 885 Olsen J. M. H., Aidas K., Kongsted J.
(2010), 6, pp. 3721.
, 886 Olsen J. M. H., Kongsted J.
Adv. Quantum Chem.
(2011), 61, pp. 107.
. The theory is explained thorougly in literature 885 Olsen J. M. H., Aidas K., Kongsted J.
Adv. Quantum Chem.
, 735 List N. H., Olsen J. M. H., Kongsted J.
(2016), 18, pp. 20234.
. In essence, the environment is represented by a multi-center multipole expansion to model electrostatic interactions, whereas polarization is taken into account by dipole-dipole polarizabilities placed at the expansion points. Polarization effects can thus be treated fully self-consistently by mutual polarization of the environment and the quantum region.
A recent tutorial review on how to prepare PE calculations in general (creating embedding potentials) is also available 1144 Steinmann C. et al.
Int. J. Quantum Chem.
(2019), 119, pp. 1.
. For automated generation of embedding potentials, please refer to the PyFraME tool 11 1 https://gitlab.com/FraME-projects/PyFraME which is also explained in the aforementioned review.
PE can be used for Hartree-Fock and density-functional theory ground-state SCF methods. In addition, PE has been combined with the algebraic-diagrammatic construction for the polarization propagator (ADC) 1059 Scheurer M. et al.
(2018), 14, pp. 4870.
, explained in the subsequent section.
11.8.1.1 PE-ADC
The combined scheme of the PE model and ADC (PE-ADC) 1059 Scheurer M. et al.
is built on top of a PE-HF ground-state calculation and takes into account perturbative corrections of the excitation energies in a density-driven manner. That is, after the Hartree-Fock ground-state calculations, the induced dipole moments in the environment are kept frozen and an ADC calculation is performed as usual. Thereafter, perturbative corrections of the electronic excitation energies are calculated based on i) the transition density (perturbative linear-response-type correction, ptLR), and ii) the difference density (perturbative state-specific correction, ptSS) for each excited state.
11.8.1.2 PE Job Control
The PE job control is accomplished in two sections, $rem and $pe. To enabling PE-ADC, specification of the ADC method and other ADC job control parameters (thresholds, max. iterations etc.) should be set in the $rem section. PE-ADC supports the excited state analysis (STATE_ANALYSIS) carried out by the libwfa module.
PE
PE
       Turns PE on.
       False
       True Perform a PE calculation. False Don’t perform a PE calculation.
       Set the $rem variable PE to TRUE to start a PE calculation.
Note:  Turning PE on disables symmetry by setting SYM_IGNORE to TRUE.
Note:  Setting the REM variables USE_LIBQINTS and GEN_SCFMAN to TRUE is required to run PE.
The PE-specific options can be set in the $pe input section. The format of the $pe section requires key and value pairs separated by a space character:
$pe
   <keyword>  <parameter>
Note:  The following job control variables belong only in the $pe section. Do not place them in the $rem section.
POTFILE
       Path of the potential file.
INPUT SECTION: $pe
       potfile.pot
       Provide the path/name of the potential file.
DIIS
       Use DIIS acceleration to obtain induced moments.
INPUT SECTION: $pe
       TRUE Turns DIIS acceleration on. FALSE Turns DIIS acceleration off (normal Jacobi solver is used).
CONVERGENCE_INDUCED
       Threshold for induced moments convergence. Converge induced moments to a residual norm of 10-CONVERGENCE_INDUCED.
INPUT SECTION: $pe
       8 Corresponding to 10-8
       n≤12 Corresponding to 10-n
       Use the default unless higher accuracy is desired.
MAXITER
       Maximum number of iterations for induced moments.
INPUT SECTION: $pe
       50
       n≥1
       Use the default. If more iterations are required to converge the induced moments, there might be an error in the system setup.
BORDER
       Activate border redistribution/removal options for sites in proximity to the QM/MM border.
INPUT SECTION: $pe
       TRUE Enable border options. FALSE Disable border options.
BORDER_TYPE
       Remove or redistribute multipole moments/polarizabilities.
INPUT SECTION: $pe
       REMOVE
       REMOVE remove multipole moments/polarizabilities. REDIST redistribute multipole moments/polarizabilities.
BORDER_RMIN
       Minimum distance from QM atoms to MM sites to be taken into account for removal/redistribution
INPUT SECTION: $pe
       FLOAT
       2.2 (AU)
       r>0 (Unit depends on BORDER_RMIN_UNIT)
BORDER_RMIN_UNIT
       Unit of BORDER_RMIN, default is atomic units (AU)
INPUT SECTION: $pe
       AU
       AU Use atomic units. AA Use Angstrom.
BORDER_REDIST_ORDER
       Order from which on moments are removed. For example, if set to 1 (default), only charges are redistributed and all higher order moments are removed.
INPUT SECTION: $pe
       n=0,1,2,3,…
BORDER_N_REDIST
       Number of neighbor sites to redistribute multipole moments/polarizabilities to. The default (-1) redistributes to all sites which are not in the border region.
INPUT SECTION: $pe
       -1
       n=-1,1,2,3,…,number of MM sites
       Use the default value.
BORDER_REDIST_POL
       Redistribute polarizabilities? If set to FALSE, polarizabilities are removed.
INPUT SECTION: $pe
       TRUE Redistribute polarizabilities. FALSE Remove polarizabilities.
Example 11.43  Input for a PE-HF calculation of 4-Nitroaniline in presence of six water molecules
The potential file \texttt{gen\_scfman\_pe\_potfile.pot} can be
found in the samples folder.
   C      8.64800        1.07500       -1.71100
   C      9.48200        0.43000       -0.80800
   C      9.39600        0.75000        0.53800
   C      8.48200        1.71200        0.99500
   C      7.65300        2.34500        0.05500
   C      7.73200        2.03100       -1.29200
   H     10.18300       -0.30900       -1.16400
   H     10.04400        0.25200        1.24700
   H      6.94200        3.08900        0.38900
   H      7.09700        2.51500       -2.01800
   N      8.40100        2.02500        2.32500
   N      8.73400        0.74100       -3.12900
   O      7.98000        1.33100       -3.90100
   O      9.55600       -0.11000       -3.46600
   H      7.74900        2.71100        2.65200
   H      8.99100        1.57500        2.99500
   METHOD               HF
   BASIS                STO-3G
   PE                   TRUE
   SYM_IGNORE           TRUE
   USE_LIBQINTS         TRUE
$pe
   potfile  gen_scfman_pe_potfile.pot
11.8.1.3 PE output
After SCF convergence, the PE module prints a summary of PE energy contributions, for example:
Polarizable Embedding Summary:
   Electrostatics:
      Electronic:                   0.30901227399981
      Nuclear:                      -0.32134940137969
      Multipole:                    0.00000000000000
      Total:                        -0.01233712737988
   Polarization:
      Electronic:                   -0.01817189734325
      Nuclear:                      0.01717961961137
      Multipole:                    -0.02091890381649
      Total:                        -0.02191118154837
   Total Energy:                    -0.03424830892825
If a PE-ADC calculation is carried out, the perturbative corrections are printed together with the excitation energies:
  Excited state 1 (singlet, A)                                     [converged]
  Term symbol:  2 (1) A                                     R^2 =  1.84764e-13
  Total energy:                                           -483.3704138865 a.u.
  Excitation energy:                                               3.906651 eV
  PE ptSS energy correction:                                      -0.001804 eV
  Corrected Excitation Energy (ptSS):                              3.904847 eV
  PE ptLR energy correction:                                      -0.000096 eV
  Corrected Excitation Energy (ptLR):                              3.906554 eV
