8.8 Auxiliary Basis Sets for RI (Density Fitting)
8.8.1 Overview
While atomic orbital standard basis sets are used to expand one-electron functions such as molecular orbitals, auxiliary basis sets are also used in many Q-Chem jobs to efficiently approximate products of one-electron functions, such as arise in electron correlation methods.
For a molecule of fixed size, increasing the number of basis functions per atom, n, leads to 𝒪⁢(n4) growth in the number of significant four-center two-electron integrals, since the number of non-negligible product charge distributions, |μ⁢ν⟩, grows as 𝒪⁢(n2). As a result, the use of large (high-quality) basis expansions is computationally costly. Perhaps the most practical way around this “basis set quality” bottleneck is the use of auxiliary basis expansions. 376 Feyereisen M., Fitzgerald G., Komornicki A.
(1993), 208, pp. 359.
, 344 Dunlap B. I.
(2000), 2, pp. 2113.
, 642 Jung Y. et al.
Proc. Natl. Acad. Sci. USA
(2005), 102, pp. 6692.
The ability to use auxiliary basis sets to accelerate a variety of electron correlation methods, including both energies and analytical gradients, is a major feature of Q-Chem.
|μ⁢ν⟩≈|μ⁢ν~⟩=∑K|K⟩⁢Cμ⁢νK (8.2)
∑L⟨K|L⟩⁢Cμ⁢νL=⟨K|μ⁢ν⟩ (8.3)
⟨μ⁢ν|λ⁢σ⟩≈⟨μ⁢ν~|λ⁢σ~⟩=∑K,LCμ⁢νL⁢⟨L|K⟩⁢Cλ⁢σK (8.4)
More details on Q-Chem’s use of RI methods is given in Section 6.6 on RI-MP2 and related methods, Section 6.19 on pairing methods, Section 6.12.9 on coupled cluster methods, Section 4.6.6 on DFT methods, and Section 7.12 on restricted active space methods. In the remainder of this section we focus on documenting the input associated with the auxiliary basis itself.
Q-Chem contains a variety of built-in auxiliary basis sets, that can be specified by the $rem keyword AUX_BASIS. These auxiliary basis sets are listed in Table 8.9 and specified in the $rem input section by means of the job control variables that are listed below. Note that in addition to the built-in auxiliary basis sets (Table 8.9), it is also possible to enter user-defined auxiliary basis sets using an $aux_basis (or $aux_basis_j, $aux_basis_k, $aux_basis_corr) input section, whose syntax generally follows the $basis input section documented above in Section 8.4.
AUX_BASIS
AUX_BASIS
       Sets the auxiliary basis set to be used
       No default auxiliary basis set
       General, Gen User-defined. As for BASIS Symbol Use standard auxiliary basis sets as in the table below Mixed Use a combination of different basis sets
       Consult literature and Basis Set Exchange to aid your selection.
AUX_BASIS_J
AUX_BASIS_J
       Sets the auxiliary basis set for RI-J to be used or invokes RI-J
AUX_BASIS_K
AUX_BASIS_K
       Sets the auxiliary basis set for RI-K or occ-RI-K to be used or invokes occ-RI-K
AUX_BASIS_CORR
AUX_BASIS_CORR
       Sets the auxiliary basis set for RI-MP2 to be used or invokes RI-MP2 in case of double-hybrid DFT or MP2
Symbolic Name Atoms Supported
RIJ-def2-XXa H, He, Li → Ne, Na → Ar, K → Br, Rb → Xe, Cs → La, Hf → Rn
RIJK-def2-XXa H, He, Li → Ne, Na → Ar, K → Br, Rb → Xe, Cs → La, Hf → Rn
RIMP2-def2-XXb H, He, Li → Ne, Na → Ar, K → Br, Rb → Xe, Cs → La, Hf → Rn
RIMP2-def2-ma-XXc H, He, Li → Ne, Na → Ar, K → Br, Rb → Xe, Cs → La, Hf → Rn
RIMP2-def2-ha-XXc H, He, Li → Ne, Na → Ar, K → Br, Rb → Xe, Cs → La, Hf → Rn
RIMP2-VDZd H, He, Li → F, Na → Cl, K → Br
RIMP2-TZVPP H, He, Li → Ne, Na → Ar, Ga → Kr
RIMP2-cc-pVDZ H, He, Li → Ne, Na → Ar, Ga → Kr
RIMP2-cc-pVTZ H, He, Li → Ne, Na → Ar, Ga → Kr
RIMP2-cc-pVQZ H, He, Li → Ne, Na → Ar, Ga → Kr
RIMP2-cal-cc-pVDZe H, He, B → Ne, Al → Ar, Ga → Kr
RIMP2-cal-cc-pVTZe H, He, B → Ne, Al → Ar, Ga → Kr
RIMP2-cal-cc-pVQZe H, He, B → Ne, Al → Ar, Ga → Kr
RIMP2-aug-cc-pVDZ H, He, B → Ne, Al → Ar, Ga → Kr
RIMP2-aug-cc-pVTZ H, He, B → Ne, Al → Ar, Ga → Kr
RIMP2-aug-cc-pVQZ H, He, B → Ne, Al → Ar, Ga → Kr
    aXX includes SV(P), SVP, TZVP, TZVPP, QZVP, and QZVPP. bXX includes SV(P), SVP, SVPD, TZVP, TZVPD, TZVPP, TZVPPD, QZVP, and QZVPPD. cXX includes SVP, TZVP, TZVPP, and QZVPP, obtained by systematic pruning of diffuse functions. For example, RIMP2-def2-ma-SVP is obtained from RIMP2-def2-SVPD by pruning in the same manner that def2-ma-SVP is obtained from def2-SVPD. dThis is the original SVP fitting set from Ref.  1386 Weigend F. et al.
    (1998), 294, pp. 143.
    . eWhere cal = may, jun, or jul. These are constructed from the corresponding RIMP2-aug-cc-pVXZ basis set by systematic deletion of diffuse functions analogous to how the “calendar” basis set cal-cc-pVXZ is constructed from aug-cc-pVXZ.
Table 8.9: Built-in auxiliary basis sets available in Q-Chem for electron correlation.
