12.13 The Generalized Many-Body Expansion Method
12.13.2 Job Control
To perform a GMBE(1) calculation, set GMBE_INT = TRUE in the $rem section. The level of theory applied to the fragments will correspond to the method specified in the $rem section. Researchers utilizing Q-Chem’s GMBE implementation are requested to cite Refs.  70 Ballesteros F., Tan J. A., Lao K. U.
(2023), 159, pp. 074107.
and  1131 Richard R. M., Herbert J. M.
(2012), 137, pp. 064113.
The following keywords control the GMBE calculation in Q-Chem. They should be specified in the $rem section of the input file.
GMBE_INT
GMBE_INT
       Perform a GMBE Calculation.
       TRUE Perform GMBE. FALSE Do not perform GMBE.
GMBE_METHOD
GMBE_METHOD
       Specify whether to perform an energy-based GMBE (GMBE-EB) or a density matrix-based GMBE (GMBE-DM).
       1 Perform GMBE-EB. 2 Perform GMBE-DM.
GMBE_ALGO
GMBE_ALGO
       Specify the cutoff distance criterion used to determine the primitive fragments.
       1 Minimum distance 2 Heavy-atoms distance
GMBE_PRIMARY
GMBE_PRIMARY
       Specify the primary cutoff distance used to determine the primitive fragments. The input for GMBE_PRIMARY is the desired cutoff distance in Å, multiplied by 1000. For example, to use a 2.00 Å cutoff distance, set GMBE_PRIMARY to 2000. Similarly, if GMBE_PRIMARY = 3500, the cutoff distance will be 3.5 Å.
       3000
       The desired cutoff is n = 1000d, where d is the cutoff distance in Å.
GMBE_MAX_PRIM_CARD
GMBE_MAX_PRIM_CARD
       Set the maximum cardinality for the primitive fragments.
       5
       n represents the maximum cardinality of the primitive fragments.
MBEDM_PURE
MBEDM_PURE
       Perform McWeeny purification 909 McWeeny R.
Rev. Mod. Phys.
(1960), 32, pp. 335.
for GMBE density matrix.
       TRUE Perform McWeeney purification on the GMBE density matrix. FALSE Do not perform McWeeney purification on the GMBE density matrix.
GMBE_DM_GUESS_ONLY
GMBE_DM_GUESS_ONLY
       Evaluate the total energy of the system directly using GMBE-DM density matrix. Enabling this option skips SCF iterations, preventing further convergence to the supersystem result.
       TRUE Do not perform SCF iterations and directly evaluate the total energy of the system using the GMBE-DM density matrix. FALSE Perform SCF iterations with the GMBE-DM density matrix as the initial guess.
GMBE_PRINT_LEVEL
GMBE_PRINT_LEVEL
       Control the level of details printed in the output file
       1 Minimal output 2 Detailed output
Example 12.47  Example of a GMBE(1)-EB calculation for a water hexamer.
GEN_SCFMAN         FALSE
SYM_IGNORE         TRUE
METHOD             B3LYP
BASIS              def2-TZVPPD
THRESH             14
SCF_CONVERGENCE    7
MAX_SCF_CYCLES     200
MEM_TOTAL          8000
MEM_STATIC         4000
AO2MO_DISK         5000
GMBE_INT           TRUE ! Perform GMBE
GMBE_METHOD        1    ! 1 = energy-based, 2 = density matrix-based
GMBE_ALGO          1
GMBE_PRIMARY       2000
GMBE_MAX_PRIM_CARD 5
GMBE_PRINT_LEVEL   1    !1 = minimal output,   2 = detailed output
O -1.126149 -1.748387 -0.423240
H -0.234788 -1.493897 -0.661862
H -1.062789 -2.681331 -0.218819
O -0.254210 1.611495 -1.293845
H -1.001520 1.163510 -1.690129
H -0.153399 2.411746 -1.809248
O 1.694541 -0.226287 1.705739
H 0.785920 0.073487 1.677909
H 2.047134 0.150917 2.511706
O -0.864533 0.522472 1.218817
H -0.694120 1.093542 0.469789
H -1.131418 -0.310426 0.829702
O -2.312727 0.054310 -2.138177
H -2.002512 -0.686744 -1.617757
H -3.266931 0.004778 -2.081349
O 1.292355 -0.704768 -0.977342
H 1.642300 -0.601085 -0.092386
H 0.948122 0.159656 -1.202018
Example 12.48  Example of generating an initial guess density matrix using a GMBE(1)-DM calculation for a water hexamer.
GEN_SCFMAN         FALSE
SYM_IGNORE         TRUE
METHOD             B3LYP
BASIS              def2-TZVPPD
THRESH             14
SCF_CONVERGENCE    7
MAX_SCF_CYCLES     200
MEM_TOTAL          4000
MEM_STATIC         4000
ao2mo_disk         5000
GMBE_METHOD        2     ! 1 = energy-based, 2 = density matrix-based
GMBE_ALGO          1
GMBE_PRIMARY       2000
GMBE_DM_GUESS_ONLY FALSE ! Perform SCF iterations with the GMBE-DM initial guess
GMBE_PRINT_LEVEL   1     ! 1 = minimal output, 2 = detailed output
MBEDM_PURE         TRUE  ! Perform purification
