6.9 Maximum Physical Regularisation Perturbation Theory
6.9.2 MPR-BWs2 Job Control
MPR-BWs2 has been implemented as a specific partition of the RI-BW-s2 program. It is invoked by setting METHOD = RIBWS2 in the $rem section and writing METHOD = MPR-BWS2 in the $bws2 section. Iterative and non-iterative parameters as well as additional variables to control the convergence behaviour of the iterative method are also defined in the $bws2 section. See 6.8 for variables unrelated to MPR-BWs2
METHOD
       Defines the correlation energy expression to be used.
INPUT SECTION: $bws2
       BWS2
       MPR-BWS2
       In order to activate MPR-BWs2, the method keyword has to be set to MPR-BWS2 or MPRBWS2
MPR_A0
       Controls the value of the A0 parameter.
       1000
       n where n/1000 is the value of A0.
       Since A0 is equal to α in BW-s2 theory, its standard value is set to α=A0=1 and recreates BW-s2. If both MPR_A0 and ALPHA are defined in the input file, the last read takes priority.
MPR_A1
       Controls the value of the A1 parameter..
       n where n/1000 is the value of A1.
       Large values lead to convergence issues.
MPR_A2
       Controls the value of the A2 parameter..
       n where n/1000 is the value of A2.
MPR_A3
       Controls the value of the A3 parameter..
       n where n/1000 is the value of A3.
MPR_A4
       Controls the value of the A4 parameter..
       n where n/1000 is the value of A4.
MPR_B0
       Controls the value of the B0 parameter..
       n where n/1000 is the value of B0.
MPR_B1
       Controls the value of the B1 parameter..
       n where n/1000 is the value of B1.
MPR_B3
       Controls the value of the B3 parameter..
       n where n/1000 is the value of B3.
MPR_B4
       Controls the value of the B4 parameter..
       n where n/1000 is the value of B4.
MPR_A0_NONITER
       Controls the value of the A0 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of A0.
       Arbitrary values are possible.
MPR_A1_NONITER
       Controls the value of the A1 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of A1.
MPR_A2_NONITER
       Controls the value of the A2 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of A2.
MPR_A3_NONITER
       Controls the value of the A3 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of A3.
MPR_A4_NONITER
       Controls the value of the A4 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of A4.
MPR_B0_NONITER
       Controls the value of the B0 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of B0.
MPR_B1_NONITER
       Controls the value of the B1 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of B1.
MPR_B3_NONITER
       Controls the value of the B3 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of B3.
MPR_B4_NONITER
       Controls the value of the B4 parameter for non-iterative contributions.
       n where n/1000 is the non-iterative value of B4.
PARAM_GRADIENT
       Controls whether or not to compute the derivative of the energy with respect to parameters.
       TRUE Computes the iterative and non-iterative parameter gradient. FALSE Does not compute the parameter gradient.
       If required, set to TRUE.
Example 6.23  MPR-BWs2 calculation on formaldehyde with A0=1 and B0=-1.
    Standard MPR-BWs2 calculation
C   0.0000      0.0000      0.0000
O   0.0000      0.0000     -1.2195
H   0.9391      0.0000      0.5422
H  -0.9391      0.0000      0.5422
JOBTYPE             SP
METHOD              RIBWS2              ! activate RI-BWS2 driver
BASIS               DEF2-SVP
AUX_BASIS           RIMP2-DEF2-SVP      ! auxilliary basis is required
SYM_IGNORE          TRUE
SYMMETRY            FALSE
$bws2
METHOD              MPR-BWS2            ! activate MPR-BWs2
MPR_A0              1000                ! A_0 = 1.0
MPR_B0              -1000               ! B_0 = -1.0
MAX_CYCLES          50
Example 6.24  MPR-BWs2 calculation on formaldehyde with non-iterative contributions.
    MPR-BWs2 calculation with non-iterative contributions
JOBTYPE             SP
BASIS               DEF2-SVP
SYM_IGNORE          TRUE
SYMMETRY            FALSE
$bws2
MPR_A0              500                 ! A_0 = 0.5
MPR_B1_NONITER      -1500               ! non-iterative B_0 = -1.5
MAX_CYCLES          50
Example 6.25  MPR-BWs2 calculation on formaldehyde including the parameter gradient.
    MPR-BWs2 calculation with parameter gradient
JOBTYPE             SP
BASIS               DEF2-SVP
SYM_IGNORE          TRUE
SYMMETRY            FALSE
$bws2
MPR_A0              1500                ! A_0 = 1.5
MAX_CYCLES          50
PARAM_GRADIENT      TRUE                ! activate parameter gradient
