7.3.9 Spin-Orbit Coupling
The following sections describe two different ways to include spin-orbit couplings (SOCs) into TDDFT calculations.
7.3.9.1 SOCs Between TDDFT States
There are several levels at which SOCs can be incorporated into TDDFT: 697 Kotaru S., Pokhilko P., Krylov A. I.
(2022), 157, pp. 224110.
  1. (i)
    one-electron part of the Breit-Pauli Hamiltonian,
  2. (ii)
    one-electron SOC using scaled nuclear charges, and
  3. (iii)
    full SOC using the mean-field treatment of the two-electron part. 1065 Pokhilko P., Epifanovsky E., Krylov A. I.
    (2019), 151, pp. 034106.
    , 697 Kotaru S., Pokhilko P., Krylov A. I.
Options (i) and (ii) are are available for both TDA and RPA variants (including TDHF and CIS states), for restricted Kohn-Sham references only. Option (iii) is available for both restricted and unrestricted variants, but only within TDA. Calculations of SOC for SF-TDDFT are also possible within TDA using option (iii). A Python code is available,856 which harvests SOCs along with TDDFT energies and oscillator strengths from the Q-Chem output and uses them to construct and diagonalize the Breit-Pauli Hamiltonian, to obtain the coupled states. 855 Mandal A., Herbert J. M.
(2025), 27, pp. 16336.
It can be used to compute L- and M-edge spectra for TDDFT, CIS, and DFT/CIS methods.
The implementation of one-electron SOC, options (i) and (ii), is based on the following. The SOCs are computed by evaluating matrix elements of the one-electron part of the Breit-Pauli Hamiltonian:
H^SO=-α022⁢∑i,AZAri⁢A3⁢(𝐫i⁢A×𝐩i)⋅𝐬i (7.35)
where i denotes electrons, A denotes nuclei, α0=1/137.037 is the fine structure constant, and ZA is the bare positive charge on nucleus A. In the second quantization representation, the spin-orbit Hamiltonian in different directions can be expressed as
H^SO,x =-α022⁢∑p⁢qL~x,p⁢q⁢ℏ2⁢(a^p†⁢a^q¯+a^p¯†⁢a^q) (7.36a)
H^SO,y =-α022⁢∑p⁢qL~y,p⁢q⁢ℏ2⁢i⁢(a^p†⁢a^q¯-a^p¯†⁢a^q) (7.36b)
H^SO,z =-α022⁢∑p⁢qL~z,p⁢q⁢ℏ2⁢(a^p†⁢a^q-a^p¯†⁢a^q¯) (7.36c)
where L~^α=L^α⁢r-3 for α∈{x,y,z} and L~α,p⁢q are the matrix elements of this operator. The single-reference ab initio excited states (within the TDA) are given by
|ΦsingletI⟩ =∑i,asiI⁢a⁢(a^a†⁢a^i+a^a¯†⁢a^i¯)⁢|ΦHF⟩ (7.37a)
|ΦtripletI,Ms=0⟩ =∑i,atiI⁢a⁢(a^a†⁢a^i-a^a¯†⁢a^i¯)⁢|ΦHF⟩ (7.37b)
|ΦtripletI,Ms=1⟩ =2⁢∑i,atiI⁢a⁢a^a†⁢a^i¯⁢|ΦHF⟩ (7.37c)
|ΦtripletI,Ms=-1⟩ =2⁢∑i,atiI⁢a⁢a^a¯†⁢a^i⁢|ΦHF⟩ (7.37d)
where siI⁢a and tiI⁢a are singlet and triplet excitation coefficients of the Ith singlet or triplet state respectively, with the normalization
∑i⁢a(siI⁢a)2=∑i⁢a(tiI⁢a)2=12. (7.38)
The quantity |ΦHF⟩ refers to the Hartree-Fock ground state. Thus the SOC constant from the singlet state to different triplet manifolds are
⟨ΦsingletI|H^SO|ΦtripletJ,Ms=0⟩=α02⁢ℏ2⁢(∑i,a,bL~z,a⁢b⁢siI⁢a⁢tiJ⁢b-∑i,j,aL~z,i⁢j⁢siI⁢a⁢tjJ⁢a) (7.39)
or
⟨ΦsingletI|H^SO|ΦtripletJ,Ms=±1⟩=∓α02⁢ℏ2⁢2⁢(∑i,a,bL~x,a⁢b⁢siI⁢a⁢tiJ⁢b-∑i,j,aL~x,i⁢j⁢siI⁢a⁢tjJ⁢a)+α02⁢ℏ2⁢2⁢i⁢(∑i,a,bL~y,a⁢b⁢siI⁢a⁢tiJ⁢b-∑i,j,aL~y,i⁢j⁢siI⁢a⁢tjJ⁢a). (7.40)
The SOC constant between different triplet manifolds can be obtained as
⟨ΦtripletI,Ms=0|H^SO|ΦtripletJ,Ms=±1⟩=∓α02⁢ℏ2⁢2⁢(∑i,a,bL~x,a⁢b⁢tiI⁢a⁢tiJ⁢b+∑i,j,aL~x,i⁢j⁢tiI⁢a⁢tjJ⁢a)α02⁢ℏ2⁢2⁢i⁢(∑i,a,bL~y,a⁢b⁢tiI⁢a⁢tiJ⁢b+∑i,j,aL~y,i⁢j⁢tiI⁢a⁢tjJ⁢a) (7.41)
or
⟨ΦtripletI,Ms=±1|H^SO|ΦtripletJ,Ms=±1⟩=±α02⁢ℏ2⁢(∑i,a,bL~z,a⁢b⁢tiI⁢a⁢tiJ⁢b+∑i,j,aL~z,i⁢j⁢tiI⁢a⁢tjJ⁢a). (7.42)
Note that
⟨ΦtripletI,Ms=0|H^SO|ΦtripletJ,Ms=0⟩=0=⟨ΦtripletI,Ms=±1|H^SO|ΦtripletJ,Ms=∓1⟩. (7.43)
The total (root-mean-square) spin-orbit coupling is
⟨ΦsingletI|H^SO|ΦtripletJ⟩ =(∑Ms=0,±1∥⟨ΦsingletI|H^SO|ΦtripletJ,Ms⟩∥2)1/2 (7.44a)
⟨ΦtripletI|H^SO|ΦtripletJ⟩ =(∑Ms=0,±1∥⟨ΦtripletI,Ms|H^SO|ΦtripletJ,Ms⟩∥2)1/2. (7.44b)
For RPA states, the SOC constant can simply be obtained by replacing siI⁢a⁢tjJ⁢b with Xi,tripletI⁢a⁢Xj,tripletJ⁢b+Yi,singletI⁢a⁢Yj,tripletJ⁢b and tiI⁢a⁢tjJ⁢b with Xi,tripletI⁢a⁢Xj,tripletJ⁢b+Yi,tripletI⁢a⁢Yj,tripletJ⁢b.
A TDDFT + SOC calculation is activated by $rem variable CALC_SOC:
CALC_SOC
CALC_SOC
       Controls whether to calculate the SOC constants for EOM-CC, RAS-CI, CIS, TDDFT/TDA and TDDFT/RPA.
       INTEGER/LOGICAL
       0 Do not perform the SOC calculation. 1 Perform the SOC calculation using the one-electron part of the Breit-Pauli Hamiltonian 2 Perform the full SOC calculation using a mean-field treatment of the two-electron contribution 4 Perform the SOC calculation using scaled nuclear charges
       The final two options are described in Section 7.10.21.4.
Examples 7.3.9.1, 7.3.9.1, and 7.3.9.1 illustrate calculations of SOCs for (SF)-TDDFT states using the above features. These calculations can also be carried out for CIS states by modifying METHOD appropriately.
The libwfa analysis of the spinless one-particle transition density matrices (as described in Ref.  1067 Pokhilko P., Krylov A. I.
J. Phys. Chem. Lett.
(2019), 10, pp. 4857–4862.
) is implemented for the TDDFT and SF-TDDFT calculations. To activate this analysis, use the following: CALC_SOC = 2, STATE_ANALYSIS = TRUE, MOLDEN_FORMAT = TRUE, and NTO_PAIRS = N. Consult Section 10.2 for details of the libwfa package.
Note:  This analysis differs from the NTO analysis of the regular transition density matrix between the singlet and triplet states.
Example 7.16  Calculation of one-electron SOCs for using TDDFT/TDA.
   This sample input calculates the spin-orbit coupling constants for water
   between its ground state and its TDDFT/TDA excited triplets as well as the
   coupling between its TDDFT/TDA singlets and triplets.  Results are given in
   cm-1.
   H       0.000000    -0.115747     1.133769
   H       0.000000     1.109931    -0.113383
   O       0.000000     0.005817    -0.020386
   EXCHANGE             b3lyp
   BASIS                6-31G
   CIS_N_ROOTS          4
   CIS_CONVERGENCE      8
   MAX_SCF_CYCLES       600
   MAX_CIS_CYCLES       50
   SCF_ALGORITHM        diis
   MEM_STATIC           300
   MEM_TOTAL            2000
   CIS_SINGLETS         true
   CIS_TRIPLETS         true
   CALC_SOC             true
   MAX_CIS_CYCLES       300
   INTEGRAL_SYMMETRY    false
   POINT_GROUP_SYMMETRY false
Example 7.17  Calculation of full SOCs for water molecule including mean-field treatment of the two-electron part of the Breit-Pauli Hamilton and UHF/TDDFT/TDA.
Calculation of full SOCs for water molecule inlcuding mean-field treatment
of the two-electron part of the Breit-Pauli Hamiltonian and Wigner-Eckart theorem.
UHF/TDDFT/B3LYP/6-31G within the TDA.
jobtype                 sp
unrestricted            true
method                  b3lyp
basis                   6-31G
cis_n_roots             4
cis_convergence         8
cis_singlets            true
cis_triplets            true
calc_soc                2
Example 7.18  Calculation of SOCs for methylene using non-collinear SF-TDDFT/PBE0.
Calculation of SOCs for methylene using non-collinear SF-TDDFT/PBE0,
with tight convergence.
H1
C  H1 1.0775
H2 C  1.0775 H1 133.29
method = pbe0
basis = cc-pvtz
scf_convergence = 12
cis_convergence = 12
thresh = 14
cis_n_roots = 2
calc_soc = 2                    Compute full SOC with mean-field treatment of 2el part
wang_ziegler_kernel =  true     Important for 1,1 diradicals
spin_flip = true
Example 7.19  DFT/CIS calculation of the sulfur L2,3-edge in H2S. Input options are set to compute SOCs and state-to-state transition moments that can be read by the pySETSOC code,856 to construct and diagonalize the Breit-Pauli Hamiltonian. See Section 7.2.2.4 for additional details about the DFT/CIS method.
S
H  1 1.343015
H  1 1.343015 2 92.538291
 method         cam-b3lyp
 unrestricted   false
 cis_n_roots    200
 calc_soc       2     ! spin-orbit mean-field
 sts_mom        true  ! state-to-state moments, for osc. strengths
 dftcis         1
 dftcis_params  2
 basis          def2-tzvpd
 trnss          true
 trtype         3     ! use alist
 n_sol          3
$alist
2 3 4 5
7.3.9.2 TDDFT+SOC for Spin-Adiabats
For a system exhibiting strong SOC, it can be extremely helpful to calculate the electronic eigenfunctions (called “spin-adiabats”) of the entire (Coulomb + SOC) Hamiltonian. Computation of such spin-adiabatic states has been implemented within the CIS or TDDFT/TDA framework, with the SOC treated by the one-electron Breit-Pauli Hamiltonian at the post-SCF level.
Within a CIS or TDDFT/TDA-SOC, the wavefunction is represented as
|Ψ⟩=∑ϵ∑i⁢ati⁢a(ϵ)⁢|Φia⁢(ϵ)⟩ (7.45)
where ϵ is a label of spin, and
|Φia⁢(ϵ)⟩≡{12⁢(|Ψiαaα⟩+|Ψiβaβ⟩)if ⁢ϵ=singlet12⁢(|Ψiαaα⟩-|Ψiβaβ⟩)if ⁢ϵ=triplet,⁢ms=0|Ψiβaα⟩if ⁢ϵ=triplet,⁢ms=+1|Ψiαaβ⟩if ⁢ϵ=triplet,⁢ms=-1 (7.46)
The spin-adiabatic wavefunctions in Eq. (7.45) are obtained as the eigenstates of following Hamiltonian having (4⁢NO⁢NV)2 total matrix elements:
H=A+VSO+Vm (7.47)
In Eq. (7.47), A is the usual CIS-like TDDFT/TDA linear response matrix (including the one-electron and two-electron terms):
⟨Φ𝒊𝒂|A|Φ𝒋𝒃⟩ =F𝒂⁢𝒃⁢δ𝒊⁢𝒋-F𝒋⁢𝒊⁢δ𝒂⁢𝒃+⟨𝒂⁢𝒋|𝒊⁢𝒃⟩-cHF⁢⟨𝒂⁢𝒋|𝒃⁢𝒊⟩
  +Ω𝒂⁢𝒊⁢𝒃⁢𝒋+Eg⁢s⁢δ𝒂⁢𝒃⁢δ𝒊⁢𝒋 (7.48)
where the indices 𝒂,𝒃,𝒊,𝒋 are the spin-orbitals, F is the Fock matrix, Eg⁢s is the SCF energy, and Ω is the DFT exchange-correlation functional. More details can be found in Section 7.3.1 and Ref.  106 Bellonzi N. et al.
(2020), 152, pp. 044112.
The VSO in Eq. (7.47) is the one-electron SOC Hamiltonian appearing in Eq. (7.35), and the Vm=g⁢μB⁢𝐁⋅𝐒 is the spin-Zeeman term. Here g=2 is assumed. (The coupling between orbital motion and magnetic field is not yet included.) In matrix form, VSO+Vm reads
⟨Ψ𝒊𝒂|VSO+Vm|Ψ𝒋𝒃⟩=V𝒂⁢𝒃⁢δ𝒊⁢𝒋-V𝒋⁢𝒊⁢δ𝒂⁢𝒃 (7.49)
The matrix elements of V are given by
Vpα⁢qα =μB⁢Bz⁢δp⁢q-ℏ⁢α024⁢L~p⁢qz (7.50)
Vpβ⁢qβ =-μB⁢Bz⁢δp⁢q+ℏ⁢α024⁢L~p⁢qz (7.51)
Vpα⁢qβ =(μB⁢Bx⁢δp⁢q-ℏ⁢α024⁢L~p⁢qx)-i⁢(μB⁢By⁢δp⁢q-ℏ⁢α024⁢L~p⁢qy) (7.52)
Vpβ⁢qα =(μB⁢Bx⁢δp⁢q-ℏ⁢α024⁢L~p⁢qx)+i⁢(μB⁢By⁢δp⁢q-ℏ⁢α024⁢L~p⁢qy) (7.53)
where α0 is the fine-structure constant and 𝐋~=𝐋/r3.
Note:  Currently, this CIS or TDDFT/TDA-SOC implementation supports only restricted SCF calculations (which would produce excited state singlets and triplets in the absence of SOC). Also, the ground state is not coupled to the excited states through SOC (or otherwise).
The code is triggered by setting $rem variable CIS_SOC = N, where N is the number of roots desired:
CIS_SOC
CIS_SOC
       Controls the roots of performing TDDFT/TDA-SOC calculation.
       INTEGER/LOGICAL
       FALSE Do not perform the calculation. N Solve the N lowest spin-adiabatic states of TDDFT/TDA-SOC.
       Less than or equal to 4×CIS_N_ROOTS. TDDFT/TDA-SOC first performs a standard TDDFT/TDA calculation so as to generate an initial guess before rerunning the diagonalization to generate the spin adiabats. Therefore, it is a good idea to perform a stand-alone normal TDDFT/TDA calculation and generate the excited spin-diabats and check the desired range of energies, before generating the excited spin-adiabats.
To include a post-SCF magnetic field, the $bfield_postscf section must be initialized:
    $bfield_postscf
    B_x B_y B_z
Here, the Bx,By,Bz are the spatial components of the external magnetic field in Tesla. Their format must be float (i.e., “0” should be “0.0”).
Derivative coupling calculations are possible between spin-adiabats, but note that the value of the real and imaginary components may vary between different calculations – because the wavefunctions are complex-valued and may acquire a different global phase (gauge) for each calculation. The norm of derivative coupling should not change.
Examples 7.3.9.2, 7.3.9.2 and 7.3.9.2 illustrate the energy, gradient and derivative coupling calculations using TDDFT/TDA-SOC. In Example 7.3.9.2, a post-SCF external magnetic field is also included.
Example 7.20  TDDFT/TDA-SOC calculation of formaldehyde using the ωB97X functional for the lowest 7 spin-adiabats.
jobtype                 sp
exchange                wb97x
basis                   6-31g
cis_convergence         8
cis_n_roots             2
symmetry                false
sym_ignore              true
cis_soc                 7
C 0 0 0
H 0 0 1.101224
H 1.00171657 0 -0.45744749
O -1.00461935 0 -0.645642
Example 7.21  Nuclear gradient of the 4th state in the TDDFT/TDA-SOC calculation of formaldehyde with the ωB97X functional.
jobtype                 force
exchange                wb97x
basis                   6-31g
cis_convergence         8
cis_n_roots             2
symmetry                false
sym_ignore              true
cis_soc                 4
cis_state_deriv         4
new_dft                 1 ! This is necessary
C 0 0 0
H 0 0 1.101224
Example 7.22  Derivative coupling between the 4th and 7th TDDFT/TDA-SOC states for a calculation of benzaldehyde with the ωB97X functional, in the presence of 10 Tesla external magnetic field along the z-direction.
jobtype                 sp
exchange                wb97x
basis                   6-31g
scf_convergence         10
cis_convergence         10
cis_n_roots             2
symmetry                false
sym_ignore              true
cis_soc                 7
calc_nac                true
cis_der_numstate        2
$derivative_coupling
4 7
$bfield_postscf
0.0 0.0 10.0
C -0.0827555811 -0.0021927111 0.0742168160
C 0.0163712008 -0.0019362341 1.3503524350
H 0.9426483579 -0.0021873514 1.9554892885
C -1.2462538108 -0.0012178895 2.1035447415
H -1.1928615664 -0.0009432042 3.1942205420
C -2.4029093145 -0.0008942470 1.4089112839
H -3.3571329386 -0.0003915665 1.9718859042
C -2.4418611557 -0.0012099958 0.0672877891
H -3.3674530317 -0.0009676703 -0.5174127708
C -1.1678601986 -0.0019316068 -0.6798528411
H -1.2448466539 -0.0022668669 -1.7738119236
C 1.1607172056 -0.0028394281 -0.8113481262
H 1.2563061018 -0.0031882755 -1.8250763954
O 2.4950317353 -0.0032860998 -0.1735593327
