10.4 Density Analysis
10.4.2 Atoms in Molecules
Q-Chem can output a file suitable for analysis with the Atoms in Molecules package (AIMPAC). The source for AIMPAC can be freely downloaded from the web site
http://www.chemistry.mcmaster.ca/aimpac/imagemap/imagemap.htm
Users should check this site for further information about installing and running AIMPAC. The AIMPAC input file is created by specifying a filename for the WRITE_WFN $rem.
WRITE_WFN
WRITE_WFN
       Specifies whether or not a .wfn file is created, which is suitable for use with AIMPAC. Note that the output to this file is currently limited to f orbitals, which is the highest angular momentum implemented in AIMPAC.
       (NULL) No output file is created.
       filename Specifies the output file name. The suffix .wfn will be appended to this name.
