10.9 Anharmonic Vibrational Frequencies
10.9.2 Vibration Configuration Interaction Theory
To solve the nuclear vibrational Schrödinger equation, one can only use direct integration procedures for diatomic molecules. For larger systems, a truncated version of full configuration interaction is considered to be the most accurate approach. When one applies the variational principle to the vibrational problem, a basis function for the nuclear wave function of the nth excited state of mode i is
ψi(n)=ϕi(n)⁢∏j≠imϕj(0) (10.70)
where the ϕi(n) represents the harmonic oscillator eigenfunctions for normal mode qi. This can be expressed in terms of Hermite polynomials:
ϕi(n)=(ωi12π12⁢2n⁢n!)12⁢e-ωi⁢qi22⁢Hn⁢(qi⁢ωi) (10.71)
With the basis function defined in Eq. (10.70), the nth wave function can be described as a linear combination of the Hermite polynomials:
Ψ(n)=∑i=0n1∑j=0n2∑k=0n3⋯⁢∑m=0nmci⁢j⁢k⁢⋯⁢m(n)⁢ψi⁢j⁢k⁢⋯⁢m(n) (10.72)
where ni is the number of quanta in the ith mode. We propose the notation VCI(n) where n is the total number of quanta, i.e.:
n=n1+n2+n3+⋯+nm (10.73)
To determine this expansion coefficient c(n), we integrate the H^, as in Eq. (4.1), with Ψ(n) to get the eigenvalues
c(n)=EVCI⁢(n)(n)=⟨Ψ(n)|H^|Ψ(n)⟩ (10.74)
This gives us frequencies that are corrected for anharmonicity to n quanta accuracy for a m-mode molecule. The size of the secular matrix on the right hand of Eq. (10.74) is ((n+m)!/n!⁢m!)2, and the storage of this matrix can easily surpass the memory limit of a computer. Although this method is highly accurate, we need to seek for other approximations for computing large molecules.
