7.13 Core Ionization Energies and Core-Excited States
7.13.3 Methods Based on Kohn-Sham Eigenvalues
7.13.3.1 Koopmans’ Approach
A simpler alternative to TDDFT for x-ray emission is to use Kohn-Sham eigenvalue differences,
Δ⁢E=ϵv-ϵc, (7.167)
where ϵv and ϵc are valence and core energy levels, respectively. Oscillator strengths are obtained from the corresponding transition dipole matrix elements,
fc→v∝∥⟨ϕc|𝝁^|ϕv⟩∥2. (7.168)
This Koopmans’ theorem-type approach is somewhat crude, as there is no account for orbital relaxation in the core-excited state, but it has the benefit that only a ground-state calculation is required and therefore this approach is applicable to large systems, 506 Hanson-Heine M. W. D., George M. W., Besley N. A.
(2018), 696, pp. 119.
and in conjunction with SRC functionals even this simple procedure can afford reasonable estimates of the transition energies. 505 Hanson-Heine M. W. D., George M. W., Besley N. A.
(2017), 146, pp. 094106.
The method is controlled by $rem variables NCORE_XES and NVAL_XES that specify the number of core (c) and valence (v) levels to consider, and an example is given in Example 7.13.3.1. Extension of this approach to resonant x-ray emission spectroscopy (involving an excited electronic state) is possible by modeling that state as a non-aufbau solution of the SCF equations, e.g., using algorithms such as (Section 4.5.14), SGM (Section 4.5.15), or STEP (Section 4.5.16).
NCORE_XES
NCORE_XES
       Specifies how many core levels to use in a Koopmans-type XES calculation.
       n Compute transition dipoles corresponding to the first (lowest energy) n core orbitals, ϕc.
NVAL_XES
NVAL_XES
       Specifies how many valence virtual levels to use in a Koopmans-type XES calculation.
       n Compute transition dipoles corresponding to the highest n occupied orbitals, ϕv.
       Setting n=1 will include the HOMO in the occupied space, n=2 will include HOMO and HOMO-1, etc.
Example 7.202  The calculation of the XES spectrum of water using the Koopmans approach with a short-range corrected functional.
   C         0.0000000000    0.0000000000    0.5121520001
   O         0.0000000000    0.0000000000   -0.6942567610
   H         0.9377642813    0.0000000000    1.1074358558
   H        -0.9377642813    0.0000000000    1.1074358558
   METHOD          src1r1
   BASIS           6-311G**
   NCORE_XES       2
   NVAL_XES        4
7.13.3.2 Transition-Potential DFT
The transition potential (TP-)DFT method 1264 Stener M., Lisini A., Decleva P.
Chem. Phys.
(1995), 191, pp. 141.
, 1324 Triguero L., Pettersson L. G. M., Ågren H.
Phys. Rev. B
(1998), 58, pp. 8097.
, 612 Jana S., Herbert J. M.
(2023), 19, pp. 4100.
is an alternative approach that accounts for some orbital relaxation yet retains a framework based on Kohn-Sham eigenvalues, requiring only a ground-state calculation. This approach is based on Slater’s transition concept, 1224 Slater J. C.
Adv. Quantum Chem.
(1972), 6, pp. 1.
, 611 Jana S., Herbert J. M.
(2023), 158, pp. 094111.
in which an SCF calculation with a fractional electron (originally ni=1/2) is removed from occupied orbital ϕi, then the ionization energy for that MO is approximated as
IEi≈-ϵi(ni=1/2). (7.169)
This can be justified based on a Taylor expansion in terms of the orbital occupations. 1224 Slater J. C.
Adv. Quantum Chem.
(1972), 6, pp. 1.
Excitation energies are approximated as eigenvalue differences ϵa-ϵi obtained from a fractional-electron SCF calculation in which ni=1/2 electron is promoted from ϕi into the LUMO:
ΔEi→a=ϵa(ni=1/2,nLUMO=1/2)-ϵi(ni=1/2,nLUMO=1/2), (7.170)
with oscillator strengths fi→a∝|⟨ϕi|𝝁^|ϕa⟩|2, as in Eq. (7.168).
TP-DFT calculations in Q-Chem are setup to remove 1/2 electron from the lowest core orbital of a given atom that is specified using TPDFT_ATOM. (For more flexible and general fractional-electron SCF schemes, see Section 7.13.3.3.) Optionally, one may use TPDFT_LUMO to occupy the LUMO, corresponding to an excitation energy calculation [Eq. (7.170)], or omit this variable to compute the core-level electron binding energy [Eq. (7.169)].
TPDFT_ATOM
TPDFT_ATOM
       Activate TP-DFT by specifying the atom from which to remove an electron.
       n Remove an electron from the lowest-energy orbital on the atom whose index is n.
       Be sure to set UNRESTRICTED = TRUE for TP-DFT calculations.
TPDFT_FRAC
TPDFT_FRAC
       Specify the fractional value of ni to be removed.
       n Remove n/100 of an electron from the orbital specified using TPDFT_ATOM.
TPDFT_LUMO
TPDFT_LUMO
       Specify the fractional value of nLUMO to be added.
       n Add n/100 of an electron to the LUMO.
       Leave TPDFT_LUMO = 0 for core-level binding energy calculations [Eq. (7.169)] or use TPDFT_LUMO = 50 to implement Eq. (7.170).
Example 7.203  TP-DFT excitation energy calculation, removing ni=1/2 from O(1s) and placing it in the LUMO.
   H 1 0.95
   H 2 0.95 2 104.5
   METHOD       b3lyp
   BASIS        aug-cc-pCVQZ
   UNRESTRICTED true
   TPDFT_ATOM   1
   TPDFT_FRAC   50
   TPDFT_LUMO   50 ! set to 0 for IE calculation
7.13.3.3 Slater-Type Fractional-Electron Methods
A more general set of fractional-electron methods for both core-level ionization (i.e., XPS) and core-level excitation (XAS and also XES) has been explored by Jana and Herbert. 611 Jana S., Herbert J. M.
These methods generalize Slater’s transition concept, 1224 Slater J. C.
Adv. Quantum Chem.
(1972), 6, pp. 1.
and allow an arbitrary fraction of an electron to be removed from a core MO and (optionally) placed into a virtual MO, as specified by the user. The use of these generalized Slater-type methods is controlled by the $rem variables that are described below and illustrated in examples that follow. For XAS, oscillator strengths are computed according to Eq. (7.168), and the (occupied, virtual) orbital pairs (ϕi,ϕa) for which the transition dipole moment is computed are specified using NCORE_XAS and NVAL_XAS, as described in Section 7.13.3.1. To converge the fractional-electron state, it may be necessary to use an algorithm such as MOM (Section 4.5.14), SGM (Section 4.5.15), or STEP (4.5.16). Consult Refs.  611 Jana S., Herbert J. M.
and 612 Jana S., Herbert J. M.
for best practices regarding which generalized Slater-type method to use.
FRACTIONAL_ELECTRON
FRACTIONAL_ELECTRON
       Specify the fraction of an electron to be removed from the occupied space.
       -n Remove n/1000 of an electron.
       The original Slater method (ni=1/2) corresponds to FRACTIONAL_ELECTRON = -500 but there can be other choices.
FRAC_VIR_ELEC
FRAC_VIR_ELEC
       Specify the fraction of an electron to place into the occupied space.
       n Add n/1000 of an electron.
       A value >0 should be used for excitation (XAS or XES), whereas the default is appropriate for ionization (XPS).
FRAC_ELEC_ORB
FRAC_ELEC_ORB
       Specify the occupied orbital from which the fractional electron should be removed.
       n Remove from ϕn.
FRAC_VIR_ELEC_ORB
FRAC_VIR_ELEC_ORB
       Specify the virtual orbital to which the fractional electron should be added.
       n Add to ϕn.
       Use this only if FRAC_VIR_ELEC >0.
Example 7.204  Original Slater transition method (STM) for oxygen K-shell XPS, removing ni=1/2 electron from O(1s) core orbital. A normal SCF calculation is used to obtain the initial set of orbitals, followed by a fractional-electron calculation that is converged using the IMOM algorithm.
C  -0.00000000  0.00000000  0.07378202
O   0.00000000  0.00000000  1.20921798
 UNRESTRICTED  TRUE
 BASIS         def2-QZVP
 METHOD        B3LYP
 POINT_GROUP_SYMMETRY FALSE
 INTEGRAL_SYMMETRY    FALSE
 SCF_GUESS     READ
 METHOD        B3LYP
 BASIS         def2-QZVP
 UNRESTRICTED  TRUE
 FRAC_ELEC_ORB        1  ! lowest-energy orbital is O(1s)
 FRAC_VIR_ELEC_ORB    1
 FRACTIONAL_ELECTRON -500
 FRAC_VIR_ELEC        0
 MOM_START            1
 MOM_METHOD           IMOM
Example 7.205  XAS at carbon K-edge, using Slater’s transition method with ni=1/2 electrons removed from C(1s) and na=1/2 electron placed in the LUMO.
 UNRESTRICTED  TRUE
 BASIS         def2-QZVP
 METHOD        B3LYP
 SCF_GUESS     READ
 METHOD        B3LYP
 BASIS         def2-QZVP
 UNRESTRICTED  TRUE
 FRAC_ELEC_ORB        2  ! C(1s)
 FRAC_VIR_ELEC_ORB    1
 FRAC_VIR_ELEC        500
 MOM_START            1
 MOM_METHOD           IMOM
 NCORE_XAS            2
 NVAL_XAS             2
