3.2 General Form
3.2.1 Overview
IQmol (or another graphical interface) is the simplest way to control Q-Chem. However, the low level command line interface is available to enable maximum customization and allow the user to exploit all Q-Chem’s features. The command line interface requires a Q-Chem input file which is simply an ASCII text file. This input file can be created using your favorite editor (e.g., vi, emacs, jot, etc.) following the basic steps outlined in the next few chapters.
Q-Chem’s input mechanism uses a series of keywords to signal user input sections of the input file. As required, the Q-Chem program searches the input file for supported keywords. When Q-Chem finds a keyword, it then reads the section of the input file beginning at the keyword until that keyword section is terminated the $end keyword. A short description of all Q-Chem keywords is provided in Table 3.1 and the following sections. The user must understand the function and format of the $molecule (Section 3.3) and $rem (Section 3.4) keywords, as these keyword sections are where the user places the molecular geometry information and job specification details.
Table 3.1: Partial list of Q-Chem input sections; the first two ($molecule and $rem) are required for all jobs, whereas the rest are required only for certain job types, or else are optional places to specify additional job-control variables. Each input section (“$section”) should be terminated with $end. See the $QC/samples directory that is included with your release for specific examples of Q-Chem input files using these keywords.
Section Name Description
$molecule Contains the molecular coordinate input (input file requisite).
$rem Job specification and customization parameters (input file requisite).
$active_orbitals Specify active orbitals for nonorthogonal configuration interaction (Section 7.5.2).
$alist Specify active orbitals for TDDFT with a truncated subspace (Section 7.13.2).
$aux_basis User-defined auxiliary basis set for resolution-of-identity calculations
(Chapter 8.4).
$aux_basis_j User-defined auxiliary basis set for resolution-of-identity Coulomb
calculations (Chapter 8.4).
$aux_basis_k User-defined auxiliary basis set for resolution-of-identity exact exchange
$aux_basis_corr User-defined auxiliary basis set for resolution-of-identity correlation methods
(Chapter 8.4).
$basis User-defined basis set information (Chapter 8).
$cdft Options for the constrained DFT method (Section 5.11).
$chem_sol Job control for the Q-Chem/ChemSol interface (Langevin dipoles
model; Section 11.2.10).
$comment User comments for inclusion into output file (Section B.1.2.4).
$complex_ccman Contains parameters for complex-scaled and CAP-augmented EOM-CC
calculations (Chapter 7.10).
$ecp User-defined effective core potentials (Section 8.10.5).
$efei Application of external forces in a geometry optimization (Section 9.5.1).
$efp_fragments Specifies labels and positions of EFP fragments (Section 11.5).
$efp_params Contains user-defined parameters for effective fragments (Section 11.5).
$empirical_dispersion User-defined van der Waals parameters for DFT dispersion correction
(Section 5.7.3).
$eom_user_guess User-defined guess for EOM-CC calculations (Chapter 7.10).
$external_charges Specifies external point charges and their positions (Section B.1.2.7).
$fde Specifies frozen density embedding options (Section 11.7).
$force_field_params Force-field parameters for QM/MM calculations (Section 11.3).
$geom_opt Geometry optimization controls for Libopt3 calculations (Section 9.2).
$harmonic_opt Information for optimization with soft harmonic constraints (Section 9.4.7).
$intracule Intracule parameters (Section 13.2).
$isotopes Isotopic substitutions for vibrational calculations (Section 10.8.2).
$localized_diabatization Information for mixing together multiple adiabatic states into diabatic
states (Chapter 10).
$magnet Job control for magnetic field-related response properties (Section 10.11.4).
$mass User-defined atomic mass (Chapter 9.9).
$multipole_field Details of an external multipole field (Section B.1.2.10).
$nbo Options for the Natural Bond Orbital package (Section 10.3.1).
$occupied Guess orbitals to be occupied (Section 4.4.4).
$opt Constraint definitions for geometry optimizations (Section 9.4).
$pcm Job control for polarizable continuum models (Section 11.2.4).
$plots Generate plotting information over a grid of points (Section 10.5).
$qct_active_modes Information for quasi-classical trajectory calculations (Section 9.9.6).
$qct_vib_distribution
$qct_vib_phase
$qm_atoms Specify the QM region for QM/MM calculations (Section 11.3).
$response Job control for the generalized response solver (Section 10.14).
$solvent Additional parameters and variables for implicit solvent models
(Section 11.2).
$smx Job control for SMx implicit solvent models (Section 11.2.9).
$spin-spin Indices for atoms to include in spin-spin coupling calculations (Section 10.11.2.1).
$swap_occupied_virtual Guess orbitals to be swapped (Section 4.4.4).
$svp Special parameters for the iso-density SS(V)PE module (Section 11.2.6).
$svpirf Initial guess for the iso-density SS(V)PE module (Section 11.2.6).
$van_der_waals User-defined atomic radii for Langevin dipoles solvation (Section 11.2.10)
and PCMs (Section 11.2.3).
$velocity User-defined nuclear velocity for AIMD calculations (Chapter 9.9).
$xc_functional User-defined DFT exchange-correlation functional (Section 5.3.7).
$xdm Job control for the XDM dispersion method (Section 5.7.4).
$zbasis User-defined complex basis set information (Section 8.7).
$2pa Additional parameters for two-photon absorption calculations
(Section 7.10.21.6).
The keywords $rem and $molecule are required in any Q-Chem input file
As each keyword has a different function, the format required for specific keywords varies somewhat, to account for these differences (format requirements are summarized in Appendix B). However, because each keyword in the input file is sought out independently by the program, the overall format requirements of Q-Chem input files are much less stringent. For example, the $molecule section does not have to occur at the very beginning of the input file.
Note:  (1) Users are able to enter keyword sections in any order. (2) Each keyword section must be terminated with the $end keyword. (3) The $rem and $molecule sections must be included. (4) It is not necessary to have all keywords in an input file. (5) Each keyword section is described in Appendix B. (6) The entire Q-Chem input is case-insensitive.
The second general aspect of Q-Chem input is that there are effectively four input sources:
    User input file (required)
    .qchemrc file in $HOME (optional)
    preferences file in $QC/config (optional)
    Internal program defaults and calculation results (built-in)
The order of preference is as shown, i.e., the input mechanism offers a program default override for all users, default override for individual users and, of course, the input file provided by the user overrides all defaults. Refer to Section 2.1.6 for details of .qchemrc and preferences. Currently, Q-Chem only supports the $rem keyword in .qchemrc and preferences files.
In general, users will need to enter variables for the $molecule and $rem keyword section and are encouraged to add a $comment for future reference. The necessity of other keyword input will become apparent throughout the manual.
