13.5.3 Additional Customization to NEO Models
Additional customization to the NEO Methods in the previous section can also be invoked. Table 13.1 shows the current customization options we have made available, and Table 13.2 shows the combination of NEO Methods upon which these features have been tested.
Feature Single-point Analytical Analytical
Energies Gradients Hessian
Implicit Solvation ✓ ✓ ✓
Electrostatic Embedding ✓ ✓ –
Empirical Dispersion Correction ✓ ✓ ✓
Pseudopotentials ✓ ✓ ✓
Table 13.1: Features that have been extended to the NEO framework.
Level of Theory Implicit Electrostatic Empirical Pseudopotentials
(Algorithm) Solvation Embedding Dispersion Correction
NEO-HF/DFT ✓ ✓ ✓ ✓
NEO-MSDFT – – – –
CNEO ✓ ✓ ✓ ✓
NEO Hartree Product ✓ ✓ ✓ ✓
LR-NEO-TDHF/TDDFT – – – –
RT-NEO-TDHF/TDDFT – ✓ ✓ ✓
NEO-SCF(V) – – – –
NEO-CC – – – –
NEO-MP2 – – – –
NEO-CI – – – –
Table 13.2: NEO method compatibility. Check mark indicates current support.
13.5.3.1 Implicit Solvation
Bulk solvent effects can be directly incorporated into NEO calculations through the application of various implicit solvation models (Section 11.2) within the NEO framework. 1417 Wildman A. et al.
(2022), 18, pp. 1340.
The polarizable continuum model (PCM) constitutes one family of implicit solvation models and itself encompasses several different formulations: 738 Lange A. W., Herbert J. M.
(2011), 509, pp. 77.
, 553 Herbert J. M.
(2021), 11, pp. e1519.
C-PCM, 1329 Truong T. N., Stefanovich E. V.
(1995), 240, pp. 253.
, 78 Barone V., Cossi M.
(1998), 102, pp. 1995.
IEF-PCM, 240 Chipman D. M.
(2000), 112, pp. 5558.
, 183 Cancès E., Mennucci B.
(2001), 114, pp. 4744.
SS(V)PE, 240 Chipman D. M.
etc. 553 Herbert J. M.
In the PCM approach, the solute molecule is placed in a cavity that is embedded in dielectric continuum solvent, and the cavity surface is discretized into i tesserae grid points. The solvent response is represented by a partial charge qi centered at each tesserae grid point 𝐬i. 1317 Tomasi J., Mennucci B., Cammi R.
Chem. Rev.
(2005), 106, pp. 2999.
, 553 Herbert J. M.
For each SCF iteration, the current electronic and protonic densities, together with the fixed classical nuclei, define the solute’s charge distribution. This charge distribution gives rise to the solute’s electrostatic potential Vi at each tesserae grid point:
Vi=∑AZA|𝐑A-𝐬i|-∑μ⁢νPμ⁢νe⁢∫𝑑𝐫e⁢ϕμe⁢(𝐫e)⁢ϕνe⁢(𝐫e)|𝐫e-𝐬i|+∑μ′⁢ν′Pμ′⁢ν′p⁢∫𝑑𝐫p⁢ϕμ′p⁢(𝐫p)⁢ϕν′p⁢(𝐫p)|𝐫p-𝐬i|. (13.79)
The solute electrostatic potential is then used to compute qi using standard PCM methods. Once obtained, the set of tesserae charges is included as an additional one-electron (one-proton) contribution to the electronic (protonic) Fock or analogous Kohn-Sham matrix:
Fμ⁢νe,solv =Fμ⁢νe,0-∑iqi⁢∫𝑑𝐫e⁢ϕμe⁢(𝐫e)⁢ϕνe⁢(𝐫e)|𝐫e-𝐬i| (13.80a)
Fμ′⁢ν′p,solv =Fμ′⁢ν′p,0+∑iqi⁢∫𝑑𝐫p⁢ϕμ′p⁢(𝐫p)⁢ϕν′p⁢(𝐫p)|𝐫p-𝐬i|, (13.80b)
where Fμ⁢νe,0 and Fμ′⁢ν′p,0 refer to the gas-phase, electronic [Eq. (13.37a)] and protonic [Eq. (13.37b)] Fock or analogous Kohn-Sham matrix elements, respectively.
NEO-PCM calculations involve iterative, self-consistent convergence of the nuclear-electronic wavefunction in the presence of the dielectric continuum solvent. NEO-PCM analytic gradients and analytic Hessians are also implemented. The calculation can be invoked by setting SOLVENT_METHOD = PCM in the $rem input section. Non-electrostatic contributions to the solvation free energy can also be included by setting SOLVENT_METHOD = SMD:
SOLVENT_METHOD
SOLVENT_METHOD
       Sets the preferred solvent method.
       0 Do not use a solvation model. PCM Use an apparent surface charge, polarizable continuum model (Section 11.2.3). SMD Use SMD (Section 11.2.9.3).
       No recommendation.
The SMD approach builds upon PCM by including non-electrostatic interactions, namely the cavitation, dispersion, and solvent structure energy terms. A caveat is that SMD was originally parameterized to reproduce experimental free energies of solvation for conventional, electronic DFT calculations (i.e., solute nuclei represented as point charges). 276 Cramer C. J., Truhlar D. G.
Acc. Chem. Res.
(2008), 41, pp. 760.
In the simplest approach, the cavity surface is discretized into point charges. However, a more sophisticated approach utilizing Gaussian-smeared charges is also supported. 735 Lange A. W., Herbert J. M.
J. Phys. Chem. Lett.
(2010), 1, pp. 556.
, 736 Lange A. W., Herbert J. M.
(2010), 133, pp. 244111.
, 733 Lange A. W. et al.
Mol. Phys.
(2020), 118, pp. e1644384.
, 553 Herbert J. M.
Selection of these various PCM schemes and related variables can be set in the following input sections. For NEO-PCM calculations, use the $pcm and $solvent input sections. For NEO-SMD calculations, use the $pcm and $smx input sections. The capabilities from Q-Chem’s solvation library have been inherited to work with NEO methods, and the full list of variables that have been tested to work with NEO are listed in the pages that follow. See Section 11.2 for more comprehensive information on these solvation models as well as consult John Herbert’s review article 553 Herbert J. M.
to guide your selection. Lastly, examples on setting up a solvated NEO calculation can be found in Section 13.5.6.
The format of the $pcm section is analogous to the $rem section:
$pcm
  <Keyword>  <parameter/option>
Note:  The following job control variables belong only in the $pcm  section. Do not place them in the $rem section.
Theory
       Specifies the which polarizable continuum model will be used.
INPUT SECTION: $pcm
       CPCM
       CPCM (or CPCM1) Conductor-like PCM of Ref.  270 Cossi M. et al.
(2003), 24, pp. 669.
, with fε=(ε-1)/ε.
CPCM2 Original conductor-like screening model of Ref.  , with fε=(ε-1)/(ε+1/2). IEFPCM IEF-PCM with an asymmetric 𝐊 matrix. SSVPE SS(V)PE model, equivalent to IEF-PCM with a symmetric 𝐊 matrix.
       We recommend C-PCM with NEO methods. The IEF-PCM model is more exact and better suited for low-dielectric solvents, but analytic Hessians are not supported.
Method
       Specifies which surface discretization method will be used.
INPUT SECTION: $pcm
       SwiG
       SwiG Switching/Gaussian method Spherical Use a single, fixed sphere for the cavity surface. Fixed Use discretization point charges instead of smooth Gaussians.
       Use the default.
Solver
       Specifies the algorithm used to solve the PCM equations.
INPUT SECTION: $pcm
       INVERSION
       INVERSION Direct matrix inversion CG Iterative conjugate gradient
       Use the default.
SwitchThresh
       Threshold for discarding grid points on the cavity surface.
INPUT SECTION: $pcm
       8
       n Discard grid points when the switching function is less than 10-n.
       Use the default.
Radii
       Specifies which set of atomic van der Waals radii will be used to define the solute cavity.
INPUT SECTION: $pcm
       Bondi
       Bondi Use the (extended) set of Bondi radii (Ref.  1147 Rowland R. S., Taylor R.
J. Phys. Chem.
(1996), 100, pp. 7384.
FF Use Lennard-Jones radii from a molecular mechanics force field. UFF Use radii from the Universal Force Field (Ref.  1108 Rappé A. K. et al.
J. Am. Chem. Soc.
(1992), 114, pp. 10024.
Read Read the atomic radii from a $van_der_waals input section.
       Do not alter this section if doing SMD calculations.
vdwScale
       Scaling factor for the atomic van der Waals radii used to define the solute cavity.
INPUT SECTION: $pcm
       FLOAT
       1.2
       α Use a scaling factor of α>0.
       Use the default.
SASradius
       Form a “solvent accessible” surface with the given solvent probe radius.
INPUT SECTION: $pcm
       FLOAT
       0.0
       r Use a solvent probe radius of r, in Å.
       Use the default.
SurfaceType
       Selects the solute cavity surface construction.
INPUT SECTION: $pcm
       VDW_SAS
       VDW_SAS van der Waals or solvent-accessible surface SES solvent-excluded surface
       Use the default.
Note:  The acceptable values for the number of Lebedev points per sphere are N=6, 26, 38, 50, 86, 110, 146, 170, 194, 302, 350, 434, 590, 770, 974, 1202, 1454, 1730, 2030, 2354, 2702, 3074, 3470, 3890, 4334, 4802, 5294.
HeavyPoints
       The number of Lebedev grid points to be placed non-hydrogen atoms in the QM system.
INPUT SECTION: $pcm
       194
       Acceptable values are listed above.
       Use the default for geometry optimizations. For absolute solvation energies, the user may want to examine convergence with respect to N.
HPoints
       The number of Lebedev grid points to be placed on H atoms in the QM system.
INPUT SECTION: $pcm
       110
PrintLevel
       Controls the printing level during PCM calculations.
INPUT SECTION: $pcm
       0 Prints PCM energy and basic surface grid information. Minimal additional printing. 1 Level 0 plus PCM solute-solvent interaction energy components and Gauss’ Law error. 2 Level 1 plus surface grid switching parameters and a .PQR file for visualization of the cavity surface apparent surface charges. 3 Level 2 plus a .PQR file for visualization of the electrostatic potential at the surface grid created by the converged solute. 4 Level 3 plus additional surface grid information, electrostatic potential and apparent surface charges on each SCF cycle. 5 Level 4 plus extensive debugging information.
       Use the default unless further information is desired.
CavityRadius
       Specifies the solute cavity radius.
INPUT SECTION: $pcm
       FLOAT
       R Use a radius of R, in Ångstroms.
CavityCenter
       Specifies the center of the spherical solute cavity.
INPUT SECTION: $pcm
       FLOAT
       0.0 0.0 0.0
       x y z Coordinates of the cavity center, in Ångstroms.
       The format is CavityCenter followed by three floating-point values, delineated by spaces. Uses the same coordinate system as the $molecule section.
The format of the $solvent section is analogous to the $rem section:
$solvent
Note:  The following job control variables belong only in the $solvent  section. Do not place them in the $rem section.
Dielectric
       Specifies the static dielectric constant for the PCM solvent.
INPUT SECTION: $solvent
       FLOAT
       78.39
       ε Use a dielectric constant ε>0.
       The static (i.e., zero-frequency) dielectric constant is what is usually called “the” dielectric constant. The default corresponds to water at 25∘C.
The format of the $smx section is analogous to the $rem section:
$smx
Note:  The following job control variables belong only in the $smx  section. Do not place them in the $rem section.
Solvent
       Sets the SMx solvent
INPUT SECTION: $smx
       water
       Any name from the list of solvents given in Table 11.7.
13.5.3.2 Electrostatic Embedding
A set of external charges can be incorporated into a NEO calculation by specifying the $external_charges input section along with setting QM_MM = TRUE in the $rem input section. The format is shown below and consists of Cartesian coordinates and the value of the point charge, with one charge per line. The charge is in atomic units and the coordinates are in Ångstroms, unless bohrs are selected by setting the $rem keyword INPUT_BOHR to TRUE. The external charges are rotated with the molecule into the standard nuclear orientation and are specified in the following format:
$external_charges
   x-coord1  y-coord1  z-coord1  charge1
   x-coord2  y-coord2  z-coord2  charge2
   x-coord3  y-coord3  z-coord3  charge3
Note that the electric field and analytic gradients are automatically saved to disk when the $external_charges keyword is present. This therefore enables NEO-QM/MM calculations to be performed using Q-Chem paired an external, molecular mechanics package. When using an external, molecular mechanics driver, the following $rem keyword should be set to FALSE to avoid issues with double counting:
SKIP_CHARGE_SELF_INTERACT
       Ignores the electrostatic interactions among external charges in a QM/MM calculation.
       TRUE No electrostatic interactions among external charges. FALSE Computes the electrostatic interactions among external charges.
13.5.3.3 Empirical Dispersion Correction
All of the available DFT-D empirical dispersion methods for modeling non-covalent interactions introduced in Section 5.7.3 have been extended to NEO (including analytic gradients and analytic Hessians) and can be requested via the $rem variable DFT_D, which is discussed below.
Two caveats are worth pointing out: First, note that the functional form of the DFT-D empirical dispersion potential, EdispD⁢(RA⁢B), is a sum over all pairwise atomic contributions. For convenience, our implementation of the DFT-D correction uses the positions of the quantum proton(s) basis function center(s) for computing the interatomic distances RA⁢B. 795 Li T. E., Hammes-Schiffer S.
(2023), 158, pp. 114118.
Second, the DFT-D dispersion potentials have been parameterized for classical nuclei represented as point charges.
DFT_D
DFT_D
       Controls the empirical dispersion correction to be added.
       FALSE (or 0) Do not apply the DFT-D2, DFT-CHG, or DFT-D3 scheme EMPIRICAL_GRIMME DFT-D2 dispersion correction from Grimme 478 Grimme S.
(2006), 27, pp. 1787.
EMPIRICAL_CHG DFT-CHG dispersion correction from Chai and Head-Gordon 219 Chai J.-D., Head-Gordon M.
(2008), 10, pp. 6615.
EMPIRICAL_GRIMME3 DFT-D3(0) dispersion correction from Grimme (deprecated as of Q-Chem 5.0) D3_ZERO DFT-D3(0) dispersion correction from Grimme et al. 470 Grimme S. et al.
(2010), 132, pp. 154104.
D3S_ZERO DFT-D3S(0) dispersion correction from Tkachenko and Head-Gordon 1316 Tkatchenko N. V., Head-Gordon M.
(2024), 20, pp. 9741.
D3_BJ DFT-D3(BJ) dispersion correction from Grimme et al. 472 Grimme S., Ehrlich S., Goerigk L.
(2011), 32, pp. 1456.
D3S_BJ DFT-D3S(BJ) dispersion correction from Tkachenko and Head-Gordon 1316 Tkatchenko N. V., Head-Gordon M.
D3_CSO DFT-D3(CSO) dispersion correction from Schröder et al. 1177 Schröder H., Creon A., Schwabe T.
(2015), 11, pp. 3163.
D3_ZEROM DFT-D3M(0) dispersion correction from Smith et al. 1233 Smith D. G. et al.
(2016), 7, pp. 2197.
D3_BJM DFT-D3M(BJ) dispersion correction from Smith et al. 1233 Smith D. G. et al.
D3_OP DFT-D3(op) dispersion correction from Witte et al. 1428 Witte J. et al.
(2017), 13, pp. 2043.
D3 Automatically select the “best” available D3 dispersion correction D4 DFT-D4 dispersion correction from Caldeweyher et al. 174 Caldeweyher E., Bannwarth C., Grimme S.
(2017), 147, pp. 034112.
, 175 Caldeweyher E. et al.
(2019), 150, pp. 154122.
, 176 Caldeweyher E. et al.
(2020), 22, pp. 8499.
       Use D4 if the specified functional is avialable. Currently, only a subset of functionals in DFT-D4 is supported. It includes B3LYP, B97, B1LYP, PBE0, PW6B95, M06L, M06, WB97, WB97X, CAMB3LYP, PBE02, PBE0DH, MPW1K, MPWB1K, B1B95, B1PW91, B2GPPLYP, B2PLYP, B3P86, B3PW91, O3LYP, REVPBE, REVPBE0, REVTPSS, REVTPSSH, SCAN, TPSS0, TPSSH, X3LYP, TPSS, BP86, BLYP, BPBE, MPW1PW91, MPW1LYP, PBE, RPBE, and PW91.
Note:  The following variable is applicable only to the DFT-CHG dispersion model.
DFT_D_A
DFT_D_A
       Controls the strength of dispersion corrections in the Chai–Head-Gordon DFT-D scheme, Eq. (5.26).
       600
       n Corresponding to a=n/100.
       Use the default.
Note:  The following input section is only relevant to the DFT-D2 dispersion model. This input section is optional and is only used if the user wants to change the default values recommended by Grimme.
¯$empirical_dispersion
¯¯S6 S6_value
¯¯D D_value
¯¯C6 element_1 C6_value_for_element_1 element_2 C6_value_for_element_2
¯¯VDW_RADII element_1 radii_for_element_1 element_2 radii_for_element_2
¯$end
Note:  The following variables are applicable only to the DFT-D3 dispersion models.
DFT_D3_S6
DFT_D3_S6
       The linear parameter s6 in eq. (5.27). Used in all forms of DFT-D3.
       100000
       n Corresponding to s6=n/100000.
DFT_D3_RS6
DFT_D3_RS6
       The nonlinear parameter sr,6 in Eqs. (5.28) and Eq. (5.31). Used in DFT-D3(0) and DFT-D3M(0).
       100000
       n Corresponding to sr,6=n/100000.
DFT_D3_S8
DFT_D3_S8
       The linear parameter s8 in Eq. (5.27). Used in DFT-D3(0), DFT-D3(BJ), DFT-D3M(0), DFT-D3M(BJ), and DFT-D3(op).
       100000
       n Corresponding to s8=n/100000.
DFT_D3_RS8
DFT_D3_RS8
       The nonlinear parameter sr,8 in Eqs. (5.28) and Eq. (5.31). Used in DFT-D3(0) and DFT-D3M(0).
       100000
       n Corresponding to sr,8=n/100000.
DFT_D3_A1
DFT_D3_A1
       The nonlinear parameter α1 in Eqs. (5.29), (5.30), (5.31), and (5.32). Used in DFT-D3(BJ), DFT-D3(CSO), DFT-D3M(0), DFT-D3M(BJ), and DFT-D3(op).
       100000
       n Corresponding to α1=n/100000.
DFT_D3_A2
DFT_D3_A2
       The nonlinear parameter α2 in Eqs. (5.29) and (5.32). Used in DFT-D3(BJ), DFT-D3M(BJ), and DFT-D3(op).
       100000
       n Corresponding to α2=n/100000.
DFT_D3_POWER
DFT_D3_POWER
       The nonlinear parameter β6 in Eq. (5.32). Used in DFT-D3(op). Must be greater than or equal to 6 to avoid divergence.
       600000
       n Corresponding to β6=n/100000.
DFT_D3_3BODY
DFT_D3_3BODY
       Controls whether the three-body interaction in Grimme’s DFT-D3 method should be applied (see Eq. (14) in Ref.  470 Grimme S. et al.
       FALSE (or 0) Do not apply the three-body interaction term TRUE Apply the three-body interaction term
Note:  The following variables are applicable only to the DFT-D4 dispersion model.
DFT_D4_S6
DFT_D4_S6
       The linear parameter s6. Used in DFT-D4.
       Optimized number for the specified functional
       n Corresponding to s6=n/100000000.
DFT_D4_S8
DFT_D4_S8
       The linear parameter s8. Used in DFT-D4.
       n Corresponding to s8=n/100000000.
DFT_D4_S10
DFT_D4_S10
       The linear parameter s10. Used in DFT-D4.
       n Corresponding to s10=n/100000000.
DFT_D4_A1
DFT_D4_A1
       The nonlinear parameter α1. Used in DFT-D4.
       n Corresponding to α1=n/100000000.
DFT_D4_A2
DFT_D4_A2
       The nonlinear parameter α2. Used in DFT-D4.
       n Corresponding to α2=n/100000000.
DFT_D4_S9
DFT_D4_S9
       The linear parameter s9. Used in DFT-D4.
       n Corresponding to s9=n/100000000.
DFT_D4_WF
DFT_D4_WF
       Weighting factor for Gaussian weighting.
       600000000
       n Corresponding to w⁢f=n/100000000.
       Use default
DFT_D4_GA
DFT_D4_GA
       Charge scaling
       300000000
       n Corresponding to g⁢a=n/100000000.
       Use default
DFT_D4_GC
DFT_D4_GC
       Charge scaling
       200000000
       n Corresponding to g⁢c=n/100000000.
       Use default
13.5.3.4 Pseudopotentials
Q-Chem’s Effective Core Potential (ECP) package has been integrated with the NEO method to enable the description of relativistic and core electronic effects for systems in which some of the atoms may bear pseudopotentials. This is done by adding an additional one-electron potential contribution, which serves to model the effects of the core electrons, into the electronic Fock or analagous Kohn-Sham matrix (also see Section 8.10). In both the electronic and protonic Fock or analogous Kohn-Sham matrices, the one-electron term corresponding to the interaction of electrons or quantum protons with the classical nucleus with an ECP utilizes the effective nuclear charge shielded by the core electrons. 796 Li T. E., Paenurk E., Hammes-Schiffer S.
(2024), 15, pp. 751.
The following $rem variable controls which ECP is used:
ECP
ECP
       Defines the effective core potential and associated basis set to be used
       No ECP
       General, Gen User defined. ($ecp keyword required) Symbol Use standard ECPs discussed above.
       ECPs are recommended for first row transition metals and heavier elements. Also consult Section 8.10 for more details.
