6.9 Maximum Physical Regularisation Perturbation Theory
6.9.1 Introduction
Maximum Physical Regularisaion can be understood both as an extension to size-consistent Brillouin-Wigner theory (BW-s2) as well as to Møller-Plesset perturbation theory (MP2). In either framework, it introduces additional terms into the unperturbed Hamiltonian which allow the user to manipulate ground state properties and energies with more parametric precision. The second order energy in MPR-BWs(2) is given by an equation superficially reminiscient of both MP2 and BW-s2:
Ec(2)=14⁢∑i⁢j⁢a⁢b⟨a⁢b|⁢|i⁢j⟩⁢ti⁢ja⁢b(1) (6.33)
where the first order amplitudes ti⁢ja⁢b(1) are determined by their linear amplitude equation. In strong analogy to BW-s2, MPR-BWs2 contains two matrices Wi⁢j and Wa⁢b which augment and mould the phyiscal description of the unperturbed ground state. The MPR-BWs2 amplitude equation is given by:
∑c((fa⁢c+Wa⁢c)⁢ti⁢jc⁢b(1)+(fc⁢b+Wc⁢b)⁢ti⁢ja⁢c(1))-∑k((fi⁢k+Wi⁢k)⁢tk⁢ja⁢b(1)+(fk⁢j+Wk⁢j)⁢ti⁢ka⁢b(1))+⟨i⁢j|⁢|a⁢b⟩=0 (6.34)
The central distinction between MPR-BWs2, BW-s2 and MP2 lies in the definition of Wa⁢b and Wi⁢j. The occupied block in MPR-BWs2 has five distinct contributions. The first term (A0) is identical to BW-s2 and is characterised by the fact that it traces out to the second order energy multiplied by A0:
Wi⁢j←A08⁢(ti⁢ka⁢b(1)⁢⟨a⁢b|⁢|j⁢k⟩+tj⁢ka⁢b(1)⁢⟨a⁢b|⁢|i⁢k⟩) (6.35)
Analogously, the second term (A1) traces out to the opposite-spin part of the second order correlation energy and can best be written in spatial orbitals as:
Wi⁢j←A12⁢(ti⁢k¯a⁢b¯(1)⁢(i⁢a|k⁢b¯)+tj⁢k¯a⁢b¯(1)⁢(j⁢a|k⁢b¯)) (6.36)
The remaining occupied terms contain the pseudo-density matrices ρi⁢j and ρa⁢b, which are defined in analogy to MP2, but are notably distinct from the true second order MPR-BWs2 density matrix:
ρi⁢j=-12⁢ti⁢ka⁢b(1)⁢tj⁢ka⁢b(1) (6.37)
ρa⁢b=12⁢ti⁢ja⁢c(1)⁢ti⁢jb⁢c(1) (6.38)
The A2 and A3 terms are constructed as follows:
Wi⁢j←A2⁢⟨i⁢k|⁢|j⁢l⟩⁢ρk⁢l+A3⁢⟨i⁢a|⁢|j⁢b⟩⁢ρa⁢b (6.39)
Finally, the A4 term is given by a symmetric contraction with the fock matrix:
Wi⁢j←A42⁢(fi⁢k⁢ρk⁢j+fj⁢k⁢ρk⁢i) (6.40)
The virtual parameters are labelled according to their occupied counterparts, wherefore the B0 and B1 parameters are:
Wa⁢b←B08⁢(ti⁢ja⁢c(1)⁢⟨b⁢c|⁢|i⁢j⟩+ti⁢jb⁢c(1)⁢⟨a⁢c|⁢|i⁢j⟩) (6.41)
Wa⁢b←B12(ti⁢j¯a⁢c¯(1)(ib|j⁢c¯)+ti⁢j¯b⁢c¯(1)(ia|j⁢c¯) (6.42)
The B2 parameter, which would contract ρa⁢b into Wa⁢b is deliberately not implemented, since its evaluation contains a step of order O⁢(V4), where V is the number of virtual orbitals. The B3 and B4 terms are given by:
Wa⁢b←B3⁢⟨a⁢i|⁢|b⁢j⟩⁢ρi⁢j (6.43)
Wa⁢b←B42⁢(fa⁢c⁢ρc⁢b+fb⁢c⁢ρc⁢a) (6.44)
For an interpretation of these parameters and their respective terms, see Ref.  328 Dittmer L. B., Head-Gordon M.
(2024), 162, pp. 054109.
Since terms with quadratic dependence on the amplitudes subsequently turn the amplitude equation into a cubic tensor equation, convergence of the self-consistent construction scheme described in section 6.8 is sometimes difficult or impossible to achieve. For this reason, it can be best to approximate the effect of each parameter non-iteratively. As can be seen from the Hylleraas functional, the second order correlation energy can be rewritten as:
Ec(2)=-∑p⁢qPp⁢q(2)⁢(fp⁢q+Wp⁢q) (6.45)
where Pp⁢q(2) denotes the exact second order density matrix. Replacing Pi⁢j(2) with ρi⁢j and Pa⁢b(2) with ρa⁢b and subtracting the iterative contribution defines the non-iterative approximation:
Ec,noniter(2)=∑i⁢jρi⁢j⁢Wi⁢jnoniter-∑a⁢bρa⁢b⁢Wa⁢bnoniter (6.46)
