6.17 Memory Options and Parallelization of Coupled-Cluster Calculations
6.17.4 Summary of Keywords
MEM_STATIC
MEM_STATIC
       Sets the memory for individual Fortran program modules
       240 corresponding to 240 MB or 12% of MEM_TOTAL
       For direct and semi-direct MP2 calculations, this must exceed OVN + requirements for AO integral evaluation (32–160 MB). Up to 2000 MB for large coupled-clusters calculations.
CC_MEMORY
CC_MEMORY
       Specifies the maximum size, in MB, of the buffers for in-core storage of block-tensors in CCMAN and CCMAN2.
       50% of MEM_TOTAL. If MEM_TOTAL is not set, use 1.5 GB. A minimum of 192 MB is hard-coded.
       n Integer number of MB
       Larger values can give better I/O performance and are recommended for systems with large memory (add to your .qchemrc file. When running CCMAN2 exclusively on a node, CC_MEMORY should be set to 75–80% of the total available RAM. )
CC_BACKEND
CC_BACKEND
       Used to specify the computational back-end of CCMAN2.
       VM Default shared-memory disk-based back-end
       XM libxm shared-memory disk-based back-end INCORE in-core memory back-end
       Use XM for large jobs with limited memory or when the performance of the default disk-based back-end is not satisfactory, INCORE for small jobs that fit in main memory.
