5.3.3 Correlation Functionals
Note:  All correlation functionals in this section can be invoked using the $rem variable CORRELATION. Popular and/or recommended functionals within each class are listed first and indicated in bold. The rest are in alphabetical order.
    Local Spin-Density Approximation (LSDA)
      PW92: Perdew-Wang parameterization of the LSDA correlation energy from 1992716
      VWN5 (VWN): Vosko-Wilk-Nusair parameterization of the LSDA correlation energy #5958
      srVWN: Short-range version of the VWN correlation functional by Toulouse and coworkers926
      Liu-Parr: Liu-Parr ρ1/3 model from the functional expansion formulation588
      PK09: Proynov-Kong parameterization of the LSDA correlation energy from 2009758
      PW92RPA: Perdew-Wang parameterization of the LSDA correlation energy from 1992 with RPA values716
      srPW92: Short-range version of the PW92 correlation functional by Paziani and coworkers705
      PZ81: Perdew-Zunger parameterization of the LSDA correlation energy from 1981717
      VWN1: Vosko-Wilk-Nusair parameterization of the LSDA correlation energy #1958
      VWN1RPA: Vosko-Wilk-Nusair parameterization of the LSDA correlation energy #1 with RPA values958
      VWN2: Vosko-Wilk-Nusair parameterization of the LSDA correlation energy #2958
      VWN3: Vosko-Wilk-Nusair parameterization of the LSDA correlation energy #3958
      VWN4: Vosko-Wilk-Nusair parameterization of the LSDA correlation energy #4958
      Wigner:Wigner correlation functional (simplification of LYP)995, 885
    Generalized Gradient Approximation (GGA)
      PBE: Perdew, Burke, and Ernzerhof correlation functional707
      LYP: Lee-Yang-Parr opposite-spin correlation functional545
      P86: Perdew-Wang correlation functional from 1986 based on the PZ81 LSDA functional718
      P86VWN5: Perdew-Wang correlation functional from 1986 based on the VWN5 LSDA functional718
      PBEloc: PBE correlation functional with a modified beta term by Della Sala and coworkers185
      PBEsol: PBE correlation functional modified for solids711
      srPBE: Short-range version of the PBE correlation functional by Goll and coworkers318, 317
      PW91: Perdew-Wang correlation functional from 1991708
      regTPSS: Slight modification of the PBE correlation functional (also called vPBEc)806
    Meta-Generalized Gradient Approximation (meta-GGA)
      TPSS:Tao, Perdew, Staroverov, and Scuseria correlation functional912
      revTPSS: Revised version of the TPSS correlation functional710
      B95: Becke’s two-parameter correlation functional from 199571
      oTPSS: TPSS correlation functional with 2 refit parameters (for use with oTPSS exchange) by Grimme and coworkers313
      PK06: Proynov-Kong “tLap” functional with τ and Laplacian dependence756
      PKZB: Perdew, Kurth, Zupan, and Blaha correlation functional709
      SCAN: Strongly Constrained and Appropriately Normed correlation functional900
      TM: Tao-Mo correlation functional, representing a minor modification to the TPSS correlation functional911
      TPSSloc: The TPSS correlation functional with the PBE component replaced by the PBEloc correlation functional185
