5.3.1 Suggested Density Functionals
Q-Chem contains over 150 exchange-correlation functionals, not counting those that can be straightforwardly appended with a dispersion correction (such as B3LYP-D3). Therefore, we suggest a few functionals from the second through fourth rungs of Jacob’s Ladder in order to guide functional selection. Most of these suggestions come from a benchmark of over 200 density functionals on a vast database of nearly 5000 data points, covering non-covalent interactions, isomerization energies, thermochemistry, and barrier heights. The single recommended method from each category is indicated in bold.
From the GGAs on Rung 2, we recommend:
    B97-D3(BJ): METHOD B97-D3 and DFT_D D3_BJ
    revPBE-D3(BJ): METHOD revPBE and DFT_D D3_BJ
    BLYP-D3(BJ): METHOD BLYP and DFT_D D3_BJ
    PBE: METHOD PBE
From the meta-GGAs on Rung 3, we recommend:
    B97M-rV: METHOD B97M-rV
    MS1-D3(0): METHOD MS1 and DFT_D D3_ZERO
    MS2-D3(0): METHOD MS2 and DFT_D D3_ZERO
    M06-L-D3(0): METHOD M06-L and DFT_D D3_ZERO
    TPSS-D3(BJ): METHOD TPSS and DFT_D D3_BJ
From the hybrid GGAs on Rung 4, we recommend:
    ωB97X-V: METHOD wB97X-V
    ωB97X-D3: METHOD wB97X-D3
    ωB97X-D: METHOD wB97X-D
    B3LYP-D3(BJ): METHOD B3LYP and DFT_D D3_BJ
    revPBE0-D3(BJ): METHOD revPBE0 and DFT_D D3_BJ
From the hybrid meta-GGAs on Rung 4, we recommend:
    ωB97M-V: METHOD wB97M-V
    ωM05-D: METHOD wM05-D
    M06-2X-D3(0): METHOD M06-2X and DFT_D D3_ZERO
    TPSSh-D3(BJ): METHOD TPSSh and DFT_D D3_BJ
From the double-hybrid GGAs on Rung 5, we recommend:
    ωB97X-2(LP): METHOD wB97X-2(LP)
    ωB97X-2(TQZ): METHOD wB97X-2(TQZ)
    DSD-PBEPBE-D3: METHOD DSD-PBEPBE-D3
From the double-hybrid mGGAs on Rung 5, we recommend:
    ωB97M-(2): METHOD wB97M-(2)
    PTPSS-D3: METHOD PTPSS-D3
