7.8.10 Single-precision arithmetics in EOM-CC calculations
Similar to ground-state CCSD calculations described in Section 6.15, single precision can be used in EOM-CC and EOM-MP2 calculations 738. Currently, the following variants of EOM are supported: EE, SF,IP, EA; both in standard and RI/CD implementations, for energies and properties evaluation. If you wish to use single-precision version of EOM, please first read Section 6.15 for basic setup of single-precision coupled-cluster calculation. Here we describe only additional EOM-specific keywords.
Precision selection is controlled by the EOM_SINGLE_PREC keyword: 0 corresponds to double-precision calculation and 1 corresponds to single-precision calculation. EOM-specific convergence criteria are controlled by the same keywords as in the double precision, but the same rule as for CCSD applies: too tight thresholds may cause issues with convergence. The default Davidson threshold 10-5 works well for most cases 738.
The keyword CC_SP_DM controls calculation of intermediates, density matrices, and S2 for EOM calculations in the same manner as for CCSD, which is described in Section 6.15.
Calculations of analytical gradients require solving amplitude-response equations, which can be done on single precision as well; this is activated by EOM_ARESP_SINGLE_PREC=1.
EOM_SINGLE_PREC
       Precision selection for EOM-CC/MP2 calculations. Available in CCMAN2 only.
       0 double-precision calculation
       1 single-precision calculation 2 single-precision calculation is followed by double-precision clean-up iterations
       Do not set too tight convergence criteria when use single precision
       Precision selection for amplitude response EOM equations. Available in CCMAN2 only.
Example 7.38  A job evaluating EOM-EA-CCSD energies for formaldehyde anion using single-precision execution combined with CD
Formaldehyde anion, single-precision calculation
C
H 1 1.127888
H 1 1.127888 2 100.546614
basis = cc-pvdz
method = ccsd
cholesky_tol = 3
EA_STATES = [1,0,0,0]
cc_ref_prop = 1   Compute properties of the CCSD reference
!SP keywords
cc_single_prec = 1
cc_sp_t_conv = 4
cc_sp_e_conv = 6
cc_erase_dp_integrals = 0 ! set 1 to save disk space
cc_sp_dm = 1
!EOM-specific keyword
eom_single_prec = 1
Example 7.39  Geometry optimization of a triplet excited state of uracil-water complex in single-precision setup
N            .034130    -.986909    0.000000
N          -1.173397     .981920    0.000000
C          -1.218805    -.408164    0.000000
C           -.007302    1.702153    0.000000
C           1.196200    1.107045    0.000000
C           1.289085    -.345905    0.000000
O           2.310232    -.996874    0.000000
O          -2.257041   -1.026495    0.000000
H            .049329   -1.997961    0.000000
H          -2.070598    1.437050    0.000000
H           -.125651    2.776484    0.000000
H           2.111671    1.674079    0.000000
O           1.747914   -1.338382   -3.040233
H           2.180817   -1.817552   -2.333676
H           0.813180   -1.472188   -2.883392
basis = cc-pvdz
job_type = opt
method = ccsd
cc_state_to_opt = [1,1]
mem_total = 30000
EE_TRIPLETS = [1]
cc_sp_t_conv = 4
cc_sp_e_conv = 6
cc_single_prec = 1
eom_single_prec = 1
CC_SP_DM = 1
CC_EOM_PROP = 1
EOM_ARESP_SINGLE_PREC = 1
