11.13 NMR and Other Magnetic Properties
11.13.1 NMR Chemical Shifts and J-Couplings
NMR calculations are available at both the Hartree-Fock and DFT levels of theory.365, 904 Q-Chem computes NMR chemical shielding tensors using gauge-including atomic orbitals231, 1012, 349 (GIAOs), an approach that has proven to reliable and accurate for many applications.364, 289 The shielding tensor 𝝈 is a second-order property that depends upon the external magnetic field, 𝐁, and the spin angular momentum 𝒎 for a given nucleus:
Δ⁢E=-𝒎⋅(𝟏-𝝈)⋅𝐁. (11.70)
Using analytical derivative techniques to evaluate 𝝈, the components of this 3×3 tensor are computed as
σi⁢j=∑μ⁢νPμ⁢ν⁢(∂2⁡hμ⁢ν∂⁡Bi⁢∂⁡mj)+∑μ⁢ν∂⁡Pμ⁢ν∂⁡Bi⁢∂⁡hμ⁢ν∂⁡mj (11.71)
where i,j∈{x,y,z} indicate Cartesian components. Note that there is a separate chemical shielding tensor for each 𝒎, that is, for each nucleus. To compute σi⁢j it is necessary to solve coupled-perturbed SCF (CPSCF) equations to obtain the perturbed densities ∂⁡P/∂⁡Bi, which can be accomplished using the MO-based “MOProp” module whose use is described below. (Use of the MOProp module to compute optical properties of molecules was discussed in Section 11.12.) Alternatively, a linear-scaling, density matrix-based CPSCF (D-CPSCF) formulation is available,683, 514 which is described in Section 11.13.2.
In addition to chemical shifts, indirect nuclear spin-spin coupling constants, also known as scalar couplings or J-couplings, can be computed at the SCF level. The coupling tensor 𝐉A⁢B between atoms A and B is evaluated as the second derivative of the electronic energy with respect to the nuclear magnetic moments 𝒎:
𝐉A⁢B=∂2⁡E∂⁡𝒎A⁢∂⁡𝒎B. (11.72)
The indirect coupling tensor has five distinct contributions. The diamagnetic spin-orbit (DSO) contribution is calculated as an expectation value with the ground state wave function. The other contributions are the paramagnetic spin-orbit (PSO), spin-dipole (SD), Fermi contact (FC), and mixed SD/FC contributions. These terms require the electronic response of the systems to the perturbation due to the magnetic nuclei. Ten distinct CPSCF equations must be solved for each perturbing nucleus, which makes the calculation of J-coupling constants more time-consuming than that of chemical shifts.
Some authors have recommended calculating only the Fermi contact contribution,52 and skipping the other contributions, for H1-H1 coupling constants. For that purpose, Q-Chem allows the user to skip calculation of any of the four contributions: (FC, SD, PSO, or DSO. (The mixed SD/FC contributions is automatically calculated at no additional cost whenever both the SD and FC contributions are computed.) See Section 11.12.2 for details. Note that omitting any of the contributions cannot be rationalized from a theoretical point of view. Results from such calculations should be interpreted extremely cautiously.
Note:  1. Specialized basis sets are highly recommended in any J-coupling calculation. The pcJ-n basis set family423 has been added to the basis set library. 2. The Hartree-Fock level of theory is not suitable to obtain J-coupling constants of any degree of reliability. Use GGA or hybrid density functionals instead.
11.13.1.1 NMR Job Control and Examples
This section describes the use of Q-Chem’s MO-based CPSCF code, which is contained in the “MOProp” module that is also responsible for computing electric properties. NMR chemical shifts are requested by setting MOPROP = 1, and J-couplings by setting JOBTYPE = ISSC. The reader is referred to to Section 11.12.2 for additional job control variables associated with the MOProp module, as well as explanations of the ones that are invoked in the samples below. An alternative, 𝒪⁢(N) density matrix-based implementation of NMR chemical shifts is also available and is described in Section 11.13.2. Setting JOBTYPE = NMR invokes the density-based code, not the MO-based code.
Example 11.26  MO-based NMR calculation.
  H        0.00000        0.00000        0.00000
  C        1.10000        0.00000        0.00000
  F        1.52324        1.22917        0.00000
  F        1.52324       -0.61459        1.06450
  F        1.52324       -0.61459       -1.06450
  METHOD             B3LYP
  BASIS              6-31G*
  MOPROP               1
  MOPROP_PERTNUM       0  ! do all perturbations at once
  MOPROP_CONV_1ST      7  ! sets the CPSCF convergence threshold
  MOPROP_DIIS_DIM_SS   4  ! no. of DIIS subspace vectors
  MOPROP_MAXITER_1ST 100  ! max iterations
  MOPROP_DIIS          5  ! turns on DIIS (=0 to turn off)
  MOPROP_DIIS_THRESH   1
  MOPROP_DIIS_SAVE     0
In the following compound job, we show how to restart an NMR calculation should it exceed the maximum number of CPSCF iterations (specified with MOPROP_MAXITER_1ST, or should the calculation run out of time on a shared computer resource. Note that the first job is intentionally set up to exceed the maximum number of iterations, so will crash. However, the calculation is restarted and completed in the second job.
Example 11.27  Illustrates how to restart an NMR calculation. In this first job, we intentionally set the max number of iterations too small, to force premature end so that we can demonstrate restart capability in the 2nd job.
   METHOD               B3LYP
   BASIS                6-31G*
   SCF_ALGORITHM        DIIS
   MOPROP               1
   MOPROP_MAXITER_1ST   10   ! too small, for demonstration only
   GUESS_PX             1
   MOPROP_DIIS_SAVE     0   ! don’t hang onto the subspace vectors
   METHOD               B3LYP
   BASIS                6-31G*
   SCF_GUESS            READ
   SKIP_SCFMAN          TRUE   ! no need to redo the SCF
   MOPROP               1
   MOPROP_RESTART       1
   MOPROP_MAXITER_1ST   100  ! more reasonable choice
   GUESS_PX             1
   MOPROP_DIIS_SAVE     0
Example 11.28  J-coupling calculation: water molecule with B3LYP/cc-pVDZ
   H1 O OH
   H2 O OH H1 HOH
   OH  = 0.947
   HOH = 105.5
   JOBTYPE          ISSC
   EXCHANGE         B3LYP
   BASIS            cc-pVDZ
   LIN_K            FALSE
   SYMMETRY         TRUE
   MOPROP_CONV_1ST  6
11.13.1.2 Nucleus-Independent Chemical Shifts: Probes of Aromaticity
Unambiguous theoretical estimates of degree of aromaticity are still on high demand. The NMR chemical shift methodology offers one unique probe of aromaticity based on one defining characteristics of an aromatic system: its ability to sustain a diatropic ring current. This leads to a response to an imposed external magnetic field with a strong (negative) shielding at the center of the ring. Schleyer et al. have employed this phenomenon to justify a new unique probe of aromaticity.938 They proposed the computed absolute magnetic shielding at ring centers (unweighted mean of the heavy-atoms ring coordinates) as a new aromaticity criterion, called nucleus-independent chemical shift (NICS). Aromatic rings show strong negative shielding at the ring center (negative NICS), while anti-aromatic systems reveal positive NICS at the ring center. As an example, a typical NICS value for benzene is about -11.5 ppm as estimated with Q-Chem at the Hartree-Fock/6-31G* level. The same NICS value for benzene was also reported in Ref. 938. The calculated NICS value for furan of -13.9 ppm with Q-Chem is about the same as the value reported for furan in Ref. 938. Below is one input example of how to the NICS of furan with Q-Chem, using the ghost atom option. The ghost atom is placed at the center of the furan ring, and the basis set assigned to it within the basis mix option must be the basis used for hydrogen atom.
Example 11.29  Calculation of the NMR NICS probe of furan, HF/6-31G* level. Note the ghost atom at the center of the ring.
   C    -0.69480       -0.62270       -0.00550
   C     0.72110       -0.63490        0.00300
   C     1.11490        0.68300        0.00750
   O     0.03140        1.50200        0.00230
   C    -1.06600        0.70180       -0.00560
   H     2.07530        1.17930        0.01410
   H     1.37470       -1.49560        0.00550
   H    -1.36310       -1.47200       -0.01090
   H    -2.01770        1.21450       -0.01040
   GH    0.02132        0.32584        0.00034
   JOBTYPE               NMR
   METHOD                HF
   BASIS                 mixed
   SCF_ALGORITHM         DIIS
   PURCAR                111
   SEPARATE_JK           0
   LIN_K                 0
   CFMM_ORDER            15
   GRAIN                 1
   CFMM_PRINT            2
   CFMMSTAT              1
   PRINT_PATH_TIME       1
   LINK_MAXSHELL_NUMBER  1
   SKIP_SCFMAN           0
   IGUESS                core
   SCF_CONVERGENCE       7
   ITHRSH                10
   IPRINT                23
   D_SCF_CONVGUIDE       0
   D_SCF_METRIC          2
   D_SCF_STORAGE         50
   D_SCF_RESTART         0
   PRINT_PATH_TIME       1
   SYM_IGNORE            1
   NO_REORIENT           1
$basis
C 1
6-31G*
C 2
6-31G*
C 3
6-31G*
O 4
6-31G*
C 5
6-31G*
H 6
6-31G*
H 7
6-31G*
H 8
6-31G*
H 9
6-31G*
H 10
6-31G*
