11.12 Linear-Scaling Computation of Electric Properties
11.12.2 Job Control for the MOProp Module
The MOProp module is invoked by specifying a job number using the MOPROP $rem variable. In addition to electric properties, this module can also compute NMR chemical shifts (MOPROP = 1); this functionality is described in Section 11.13.
MOPROP
       Specifies the job number for MOProp module.
       0 Do not run the MOProp module.
       1 NMR chemical shielding tensors. 2 Static polarizability. 3 Indirect nuclear spin–spin coupling tensors. 100 Dynamic polarizability. 101 First hyperpolarizability. 102 First hyperpolarizability, reading First order results from disk. 103 First hyperpolarizability using Wigner’s 2⁢n+1 rule. 104 First hyperpolarizability using Wigner’s 2⁢n+1 rule, reading first order results from disk.
MOPROP_PERTNUM
       Set the number of perturbed densities that will to be treated together.
       0 All at once. n Treat the perturbed densities batch-wise.
       Use the default. For large systems, limiting this number may be required to avoid memory exhaustion.
MOPROP_CONV_1ST
       Sets the convergence criteria for CPSCF and 1st order TDSCF.
       6
       n<10 Convergence threshold set to 10-n.
MOPROP_CONV_2ND
       Sets the convergence criterion for second-order TDSCF.
       6
MOPROP_MAXITER_1ST
       The maximum number of iterations for CPSCF and first-order TDSCF.
       50
       n Set maximum number of iterations to n.
       Use the default.
MOPROP_MAXITER_2ND
       The maximum number of iterations for second-order TDSCF.
       50
       Use the default.
MOPROP_ISSC_PRINT_REDUCED
       Specifies whether the isotope-independent reduced coupling tensor 𝐊 should be printed in addition to the isotope-dependent 𝐉-tensor when calculating indirect nuclear spin-spin couplings.
       FALSE Do not print 𝐊. TRUE Print 𝐊.
MOPROP_ISSC_SKIP_FC
       Specifies whether to skip the calculation of the Fermi contact contribution to the indirect nuclear spin-spin coupling tensor.
       FALSE Calculate Fermi contact contribution. TRUE Skip Fermi contact contribution.
MOPROP_ISSC_SKIP_SD
       Specifies whether to skip the calculation of the spin-dipole contribution to the indirect nuclear spin-spin coupling tensor.
       FALSE Calculate spin-dipole contribution. TRUE Skip spin-dipole contribution.
MOPROP_ISSC_SKIP_PSO
       Specifies whether to skip the calculation of the paramagnetic spin-orbit contribution to the indirect nuclear spin-spin coupling tensor.
       FALSE Calculate paramagnetic spin-orbit contribution. TRUE Skip paramagnetic spin-orbit contribution.
MOPROP_ISSC_SKIP_DSO
       Specifies whether to skip the calculation of the diamagnetic spin-orbit contribution to the indirect nuclear spin-spin coupling tensor.
       FALSE Calculate diamagnetic spin-orbit contribution. TRUE Skip diamagnetic spin-orbit contribution.
MOPROP_DIIS
       Controls the use of Pulay’s DIIS in solving the CPSCF equations.
       5
       0 Turn off DIIS. 5 Turn on DIIS.
MOPROP_DIIS_DIM_SS
       Specified the DIIS subspace dimension.
       20
       0 No DIIS. n Use a subspace of dimension n.
SAVE_LAST_GPX
       Save the last 𝐆⁢[𝐏x] when calculating dynamic polarizabilities in order to call the MOProp code in a second run, via MOPROP = 102.
       0 False 1 True
MOPROP_RESTART
       Specifies the option for restarting MOProp calculations.
       0 Not a restart calculation. 1 Restart from a previous calculation using the same scratch directory.
       Need to also include "SCF_GUESS READ" and "SKIP_SCFMAN TRUE" to ensure the same set of MOs.
