11.13 NMR and Other Magnetic Properties
11.13.3 Additional Magnetic Field-Related Properties
It is now possible to calculate certain open-shell magnetic field-related properties in Q-Chem. One is the hyperfine interaction (HFI) tensor, describing the interaction of unpaired electron spin with an atom’s nuclear spin levels:
Aa⁢btot⁢(N)=Aa⁢bFC⁢(N)⁢δa⁢b+Aa⁢bSD⁢(N), (11.73)
where the Fermi contact (FC) contribution is
AFC⁢(N)=α2⁢1S⁢8⁢π3⁢ge⁢gN⁢μN⁢∑μ⁢νPμ⁢να-β⁢⟨χμ|δ⁢(𝐫N)|χν⟩ (11.74)
and the spin-dipole (SD) contribution is
Aa⁢bSD⁢(N)=α2⁢1S⁢ge⁢gN⁢μN⁢∑μ⁢νPμ⁢να-β⁢⟨χμ|3⁢rN,a⁢rN,b-δa⁢b⁢rN2rN5|χν⟩ (11.75)
for a nucleus N.
Another sensitive probe of the individual nuclear environments in a molecule is the nuclear quadrupolar interaction (NQI), arising from the interaction of a nuclei’s quadrupole moment with an applied electric field gradient (EFG), calculated as
Qa⁢b⁢(N) =∂2⁡Ve⁢N∂⁡XN,a⁢∂⁡XN,b+∂2⁡VN⁢N∂⁡XN,a⁢∂⁡XN,b (11.76)
=-∑μ⁢νPμ⁢να+β⁢⟨χμ|3⁢rN,a⁢rN,b-δa⁢b⁢rN2rN5|χν⟩+∑A≠NZA⁢3⁢RA⁢N,a⁢RA⁢N,b-δa⁢b⁢RA⁢N2RA⁢N5
for a nucleus N. Diagonalizing the tensor gives three principal values, ordered |Q1|≤|Q2|≤|Q3|, which are components of the asymmetry parameter eta:
η=Q1-Q2Q3 (11.77)
Both the hyperfine and EFG tensors are automatically calculated for all possible nuclei. All SCF-based methods (HF and DFT) are available with restricted and unrestricted references. Restricted open-shell references and post-HF methods are unavailable.
11.13.3.1 Job Control and Examples
Only one keyword is necessary in the $rem section to activate the magnetic property module.
MAGNET
       Activate the magnetic property module.
       FALSE (or 0) Don’t activate the magnetic property module. TRUE (or 1) Activate the magnetic property module.
All other options are controlled through the $magnet input section, which has the same key-value format as the $rem section (see section 3.4). Current options are:
HYPERFINE
       Activate the calculation of hyperfine interaction tensors.
INPUT SECTION: $magnet
       FALSE (or 0) Don’t calculate hyperfine interaction tensors. TRUE (or 1) Calculate hyperfine interaction tensors.
       None. Due to the nature of the property, which requires the spin density ρα-β⁢(𝐫)≡ρα⁢(𝐫)-ρβ⁢(𝐫), this is not meaningful for restricted (RHF) references. Only UHF (not ROHF) is available.
ELECTRIC
       Activate the calculation of electric field gradient tensors.
       FALSE (or 0) Don’t calculate EFG tensors and nuclear quadrupole parameters. TRUE (or 1) Calculate EFG tensors and nuclear quadrupole parameters.
Example 11.31  Calculating hyperfine and EFG tensors for the glycine cation.
  method = hf
  basis = def2-sv(p)
  scf_convergence = 11
  thresh = 14
  symmetry = false
  sym_ignore = true
  magnet = true
$magnet
  hyperfine = true
  electric = true
N        0.0000000000      0.0000000000      0.0000000000
C        1.4467530000      0.0000000000      0.0000000000
C        1.9682482963      0.0000000000      1.4334965024
O        1.2385450522      0.0000000000      2.4218667010
H        1.7988742211     -0.8959881458     -0.5223754133
H        1.7997303368      0.8930070757     -0.5235632630
H       -0.4722340827     -0.0025218132      0.8996536532
H       -0.5080000000      0.0766867527     -0.8765335943
O        3.3107284257     -0.0000000000      1.5849828121
H        3.9426948542     -0.0000000000      0.7289954096
