CIS-type jobs are requested by setting the $rem variable EXCHANGE = HF and CORRELATION = NONE, as in a ground-state Hartree-Fock calculation, but then also specifying a number of excited-state roots using the $rem keyword CIS_N_ROOTS.
Note: For RHF case, singlets and triplets will be computed, unless specified otherwise by using CIS_TRIPLETS and CIS_SINGLETS.
CIS_N_ROOTS
Sets the number of CI-Singles (CIS) excited state roots to find.
Do not look for any excited states.
Looks for CIS excited states.
CIS_SINGLETS
Solve for singlet excited states in RCIS calculations (ignored for UCIS).
Solve for singlet states.
Do not solve for singlet states.
CIS_TRIPLETS
Solve for triplet excited states in RCIS calculations (ignored for UCIS).
Solve for triplet states.
Do not solve for triplet states.
RPA
Do an RPA calculation in addition to a CIS or TDDFT/TDA calculation.
LOGICAL/INTEGER
Do not do an RPA calculation.
Do an RPA calculation.
Do an RPA calculation without running CIS or TDDFT/TDA first.
CIS_STATE_DERIV
Sets CIS state for excited state optimizations and vibrational analysis.
Does not select any of the excited states.
Select the th state.
Check to see that the states do not change order during an optimization, due
to state crossings.
SPIN_FLIP
Selects whether to perform a standard excited state calculation, or a
spin-flip calculation. Spin multiplicity should be set to 3 for systems with
an even number of electrons, and 4 for systems with an odd number of electrons.
TRUE/FALSE
SPIN_FLIP_XCIS
Do a SF-XCIS calculation.
Do not do an SF-XCIS calculation.
Do an SF-XCIS calculation (requires ROHF triplet ground state).
SFX_AMP_OCC_A
Defines a customer amplitude guess vector in SF-XCIS method.
builds a guess amplitude with an -hole in the th orbital
(requires SFX_AMP_VIR_B).
Only use when default guess is not satisfactory.
SFX_AMP_VIR_B
Defines a user-specified amplitude guess vector in SF-XCIS method.
builds a guess amplitude with a -particle in the th orbital
(requires SFX_AMP_OCC_A).
XCIS
Do an XCIS calculation in addition to a CIS calculation.
Do not do an XCIS calculation.
Do an XCIS calculation (requires ROHF ground state).
SASF_RPA
Do an SA-SF-CIS/DFT calculation.
Do not do an SA-SF-CIS/DFT calculation.
Do an SA-SF-CIS/DFT calculation (requires ROHF ground state).
