6.18 Variational Two-Electron Reduced-Density-Matrix Methods
6.18.2 Theory
The electronic energy is an exact functional of the 1-RDM and 2-RDM
E=12⁢∑p⁢q⁢r⁢sDr⁢sp⁢q2⁢(p⁢r|q⁢s)+∑p⁢qDqp1⁢hp⁢q, (6.49)
where the 1-RDM (𝐃1) and 2-RDM are represented in a given spin-orbital basis indexed by p, q, r, and s. The one-hole RDM (𝐐1), 𝐐2, 𝐆2, and partial three-particle RDMs (𝐓𝟏 and 𝐓𝟐) are linear functions of 𝐃1 and 𝐃2.270 Minimizing the electronic energy with respect to 𝐃2 while enforcing the linear relations among these RDMs, the contraction and spin constraints placed on 𝐃2, and the positive semidefinite property of all RDMs constitutes a semidefinite program (SDP). The current v2RDM implementation uses a boundary-point SDP (BPSDP) algorithm to solve the SDP.754, 600, 629
The primal formulation of the SDP is
minimize Eprimal =𝐜T⋅𝐱 (6.50)
such that 𝐀𝐱 =𝐛
and M⁢(𝐱) ⪰0.
Here, 𝐱 represents the primal solution vector, the vector 𝐜 contains all information defining the quantum system (the one- and two-electron integrals), and the mapping M⁢(𝐱) maps the primal solution onto the set of positive semidefinite RDMs
M⁢(𝐱)=(𝐃10000000𝐐10000000𝐃20000000𝐐20000000𝐆20000000𝐓𝟏0000000𝐓𝟐)⪰0. (6.51)
The action of the constraint matrix, 𝐀, on 𝐱 is a compact representation of the N-representability conditions. 𝐀 maintains the appropriate mappings between each block of M⁢(𝐱) and enforces the appropriate spin and contraction conditions. Alternatively, one could consider the dual formulation of the semidefinite problem, expressed as
maximize Edual =𝐛T⋅𝐲 (6.52)
such that 𝐳 =𝐜-𝐀T⁢𝐲
and M⁢(𝐳) ⪰0
where 𝐲 and 𝐳 are the dual solutions, and M⁢(𝐳) is constrained to be positive semidefinite.
The BPSDP algorithm involves an iterative two-step procedure:
  1. 1.
    Solve 𝐀𝐀T⁢𝐲=𝐀⁢(𝐜-𝐳)+τ⁢μ⁢(𝐛-𝐀𝐱) for 𝐲 by conjugate gradient methods.
  2. 2.
    Update 𝐱 and 𝐳 by separating 𝐔=M⁢(μ⁢𝐱+𝐀T⁢𝐲-𝐜) into its positive and negative components (by diagonalization). The updated primal and dual solutions 𝐱 and 𝐳 are given by M⁢(𝐱)=𝐔⁢(+)/μ and M⁢(𝐳)=-𝐔⁢(-).
Here, τ is a step-length parameter that lies in the interval [1.0,1.6] 629. The penalty parameter μ controls how strictly the primal or dual constraints are enforced and is updated dynamically according to the protocol outlined in Ref. 629. The frequency with which μ is updated is controlled by the $rem keyword RDM_MU_UPDATE_FREQUENCY. The algorithm is considered converged when the primal error ||𝐀𝐱-𝐛||, the dual error ||𝐀T⁢𝐲-𝐜+𝐳||, and the primal/dual energy gap |Eprimal-Edual| are sufficiently small. The convergence in the primal/dual errors and the primal/dual energy gap are controlled by the $rem keywords RDM_EPS_CONVERGENCE and RDM_E_CONVERGENCE, respectively. The BPSDP algorithm scales n6 for the DQG conditions and n9 for the T1 and T2 conditions where n is the number of active orbitals in the v2RDM computation. In v2RDM-CASSCF (if the $rem keyword RDM_OPTIMIZE_ORBITALS is set to true), the molecular orbitals are optimized after a chosen number of v2RDM iterations (Steps 1. and 2. above) indicated by the $rem keyword RDM_ORBOPT_FREQUENCY.
