6.18 Variational Two-Electron Reduced-Density-Matrix Methods
6.18.1 Introduction
The methods described in this section involve the direct variational optimization of the two-electron reduced-density matrix (2-RDM, 𝐃2), subject to necessary ensemble N-representability conditions.288, 287, 640, 800, 252, 254 Such conditions place restrictions on the 2-RDM in order to ensure that it is derivable from an antisymmetrized N-electron wavefunction. In the limit that the N-representability of the 2-RDM is exactly enforced, the variational 2-RDM (v2RDM) approach is equivalent to full configuration interaction (CI). Such computations are, in general, computationally infeasible, so the v2RDM optimization is typically carried out under a subset of two- or three-particle conditions. When only partially enforcing N-representability, the v2RDM approach yields a lower bound to the full CI energy.
In Q-Chem, all v2RDM optimizations are carried out under the following conditions:
    the 2-RDM is positive semidefinite
    the one-electron reduced-density matrix (1-RDM) is positive semidefinite
    the trace of the 2-RDM is equal to the number of pairs of electrons, N⁢(N-1)
    each spin block of the 2-RDM properly contracts to the appropriate spin block of the 1-RDM
    the expectation value of M^S is 12⁢(Nα-Nβ) (the maximal spin projection)
Additionally, an optional spin constraint can be placed on the 2-RDM such that ⟨S2⟩=S⁢(S+1), where the S is the spin quantum number. Note that this constraint on the expectation value of S^2 does not strictly guarantee that the 2-RDM corresponds to an eigenfunction of S^2. Without additional constraints, a v2RDM optimization would yield poor-quality 2-RDMs with energies far below those of full CI. Reasonable results require, at a minimum, that one enforce the positivity of additional pair-probability density matrices, including the two-hole reduced-density matrix (𝐐2) and the particle-hole reduced-density matrix (𝐆2). The positivity of 𝐃2, 𝐐2, and 𝐆2 constitute the DQG constraints of Garrod and Percus.287 For many systems, the DQG constraints yield a reasonable description of the electronic structure. However, if high accuracy is desired, it is sometimes necessary to consider constraints on higher-order reduced-density matrices (e.g. the three-electron reduced-density matrix [3-RDM]). In Q-Chem, v2RDM optimizations can be performed under the T1 and T2 partial three-particle conditions,253, 1065 which do not explicitly depend upon the 3-RDM. The positivity conditions imposed in v2RDM computations are controlled through the $rem keyword RDM_POSITIVITY.
The main utility of the v2RDM approach is in the context of active-space-based descriptions of strong or nondynamical correlation. The most common active-space-based approach for strong correlation is the compete active space self-consistent field (CASSCF) method. By performing a v2RDM computation within an active space and coupling v2RDM to an orbital optimization procedure, one can achieve a v2RDM-driven CASSCF procedure296, 270, 609 that provides a lower bound the conventional CI-based CASSCF energy. Because the v2RDM-CASSCF method scales polynomially with respect to the number of active orbitals, v2RDM-CASSCF can handle much larger active spaces (e.g., 50 electrons in 50 orbitals) compared to CI-CASSCF (e.g., 18 electrons in 18 orbitals).
The current v2RDM and v2RDM-CASSCF implementations can make use of the density fitting (DF) approximation to the two-electron integrals. The use of DF integrals is particularly advantageous for v2RDM-CASSCF computations with large active spaces because of the increased efficiency in the orbital optimization/integral transformation step. The use of DF integrals is triggered by using the $rem keyword AUX_BASIS. Analytic gradients are only available for DF integrals and are not available when frozen molecular orbitals are requested. Specification of the active space is demonstrated in the examples below. Additionally, a GPU-accelerated implementation of v2RDM and v2RDM-CASSCF employing the DQG conditions is available.
