5.7 DFT Methods for van der Waals Interactions
5.7.1 Non-Local Correlation (NLC) Functionals
From the standpoint of the electron density, the vdW interaction is a non-local one: even for two non-overlapping, spherically-symmetric charge densities (two argon atoms, say), the presence of molecule B in the non-covalent A⋯B complex induces ripples in the tail of A’s charge distribution, which are the hallmarks of non-covalent interactions.187 (This is the fundamental idea behind the non-covalent interaction plots described in Section 11.5.5; the vdW interaction manifests as large density gradients in regions of space where the density itself is small.) Semi-local GGAs that depend only on the density and its gradient cannot describe this long-range, correlation-induced interaction, and meta-GGAs at best describe it at middle-range via the Laplacian of the density and/or the kinetic energy density. A proper description of long-range electron correlation requires a non-local functional, i.e., an exchange-correlation potential having the form
vcnl⁢(𝐫)=∫f⁢(𝐫,𝐫′)⁢𝑑𝐫′. (5.19)
In this way, a perturbation at a point 𝐫′ (due to B, say) then induces an exchange-correlation potential at a (possibly far-removed) point 𝐫 (on A).
Q-Chem includes four such functionals that can describe dispersion interactions:
    vdW-DF-04, developed by Langreth, Lundqvist, and coworkers,224, 225 implemented as described in Ref. 964.
    vdW-DF-10 (also known as vdW-DF2), which is a re-parameterization of vdW-DF-04.548
    VV09, developed961 and implemented962 by Vydrov and Van Voorhis.
    VV10 by Vydrov and Van Voorhis.963
    rVV10 by Sabatini and coworkers.807
Each of these functionals is implemented in a self-consistent manner, and analytic gradients with respect to nuclear displacements are available.964, 962, 963 The non-local correlation is governed by the $rem variable NL_CORRELATION, which can be set to one of the four values: vdW-DF-04, vdW-DF-10, VV09, or VV10. The vdW-DF-04, vdW-DF-10, and VV09 functionals are used in combination with LSDA correlation, which must be specified explicitly. For instance, vdW-DF-10 is invoked by the following keyword combination:
   CORRELATION        PW92
   NL_CORRELATION     vdW-DF-10
VV10 is used in combination with PBE correlation, which must be added explicitly. In addition, the values of two parameters, C and b (see Ref. 964), must be specified for VV10. These parameters are controlled by the $rem variables NL_VV_C and NL_VV_B, respectively. For instance, to invoke VV10 with C=0.0093 and b=5.9, the following input is used:
   CORRELATION        PBE
   NL_CORRELATION     VV10
   NL_VV_C            93
   NL_VV_B            590
The variable NL_VV_C may also be specified for VV09, where it has the same meaning. By default, C=0.0089 is used in VV09 (i.e. NL_VV_C is set to 89). However, in VV10 neither C nor b are assigned a default value and must always be provided in the input.
Unlike local (LSDA) and semi-local (GGA and meta-GGA) functionals, for non-local functionals evaluation of the correlation energy requires a double integral over the spatial variables, as compared to the single integral [Eq. (5.8)] required for semi-local functionals:
Ecnl=∫vcnl⁢(𝐫)⁢𝑑𝐫=∫f⁢(𝐫,𝐫′)⁢ρ⁢(𝐫)⁢𝑑𝐫⁢𝑑𝐫′. (5.20)
In practice, this double integration is performed numerically on a quadrature grid.964, 962, 963 By default, the SG-1 quadrature (described in Section 5.5.2 below) is used to evaluate Ecnl, but a different grid can be requested via the $rem variable NL_GRID. The non-local energy is rather insensitive to the fineness of the grid such that SG-1 or even SG-0 grids can be used in most cases, but a finer grid may be required to integrate other components of the functional. This is controlled by the XC_GRID variable discussed in Section 5.5.2.
The two functionals originally developed by Vydrov and Van Voorhis can be requested by specifying METHOD = VV10 or METHOD LC-VV10. In addition, the combinatorially-optimized functionals of Mardirossian and Head-Gordon (ωB97X-V, B97M-V, and ωB97M-V) make use of non-local correlation and can be invoked by setting METHOD to wB97X-V, B97M-V, or wB97M-V.
Example 5.8  Geometry optimization of the methane dimer using VV10 with rPW86 exchange.
   C   0.000000  -0.000140   1.859161
   H  -0.888551   0.513060   1.494685
   H   0.888551   0.513060   1.494685
   H   0.000000  -1.026339   1.494868
   H   0.000000   0.000089   2.948284
   C   0.000000   0.000140  -1.859161
   H   0.000000  -0.000089  -2.948284
   H  -0.888551  -0.513060  -1.494685
   H   0.888551  -0.513060  -1.494685
   H   0.000000   1.026339  -1.494868
   JOBTYPE            opt
   BASIS              aug-cc-pVTZ
   EXCHANGE           rPW86
   CORRELATION        PBE
   XC_GRID            2
   NL_CORRELATION     VV10
   NL_GRID            1
   NL_VV_C            93
   NL_VV_B            590
In the above example, the SG-2 grid is used to evaluate the rPW86 exchange and PBE correlation, but a coarser SG-1 grid is used for the non-local part of VV10. Furthermore, the above example is identical to specifying METHOD = VV10.
NL_CORRELATION
       Specifies a non-local correlation functional that includes non-empirical dispersion.
       None No non-local correlation.
       None No non-local correlation vdW-DF-04 the non-local part of vdW-DF-04 vdW-DF-10 the non-local part of vdW-DF-10 (also known as vdW-DF2) VV09 the non-local part of VV09 VV10 the non-local part of VV10
       Do not forget to add the LSDA correlation (PW92 is recommended) when using vdW-DF-04, vdW-DF-10, or VV09. VV10 should be used with PBE correlation. Choose exchange functionals carefully: HF, rPW86, revPBE, and some of the LRC exchange functionals are among the recommended choices.
NL_VV_C
       Sets the parameter C in VV09 and VV10. This parameter is fitted to asymptotic van der Waals C6 coefficients.
       89 for VV09 No default for VV10
       n Corresponding to C=n/10000
       C=0.0093 is recommended when a semi-local exchange functional is used. C=0.0089 is recommended when a long-range corrected (LRC) hybrid functional is used. For further details see Ref. 963.
NL_VV_B
       Sets the parameter b in VV10. This parameter controls the short range behavior of the non-local correlation energy.
       No default
       n Corresponding to b=n/100
       The optimal value depends strongly on the exchange functional used. b=5.9 is recommended for rPW86. For further details see Ref. 963.
USE_RVV10
       Used to turn on the rVV10 NLC functional
       FALSE Use VV10 NLC (the default for NL_CORRELATION) TRUE Use rVV10 NLC
       Set to TRUE if the rVV10 NLC is desired.
