1.3 Q-Chem Features
1.3.3 New Features in Q-Chem 5.0
    Enhancements to the coupled-cluster package:
      Analytic gradients for Cholesky-decomposed CCSD and EOM-CCSD; efficiency improvement for canonical CCSD and EOM-CCSD gradients (X. Feng, E. Epifanovsky).
      CAP-EOM-CCSD analytic gradients (Z. Benda and T.-C. Jagau) and Dyson orbitals for metastable states (T.-C. Jagau, A.I. Krylov), Section 7.8.7).
      CAP-EOM-MP2 method (A. Kunitsa, K. Bravaya).
      Evaluation of polarizabilities using CCSD and EOM-CCSD (EE and SF) wave functions using full derivative formulation (K. Nanda and A. Krylov, Section 7.8.18.4).
      Evaluation of ⟨S2⟩ for EOM-CCSD wave functions (X. Feng).
      Evaluation of NACs for EOM-CCSD wave functions (S. Faraji, A. Krylov, E. Epifanovski, X. Feng, Section 7.8.18.3).
      Efficiency improvement and new multicore-parallel code for (T) correction (I. Kaliman).
      New coupled-cluster based methods for core states (A. Krylov).
    New capabilities for implicit solvation modeling:
      PCM capabilities for computing vertical excitation, ionization, and electron attachment energies at EOM-CC and MP2 levels (Section 7.8.13).
      State-specific equilibrium and non-equilibrium solvation for all orders and variants of ADC (J. M. Mewes and A. Dreuw; Section 7.9.7).
      Poisson equation boundary conditions allowing use of an arbitrary, anisotropic dielectric function ε⁢(𝐫), with full treatment of volume polarization (M. P. Coons and J. M. Herbert; Section 12.2.10).
      Composite Model for Implicit Representation of Solvent (CMIRS), an accurate model for free energies of solvation (Section 12.2.6)
    New density functionals (N. Mardirossian and M. Head-Gordon; Section 5.3):
      GGA functionals: BEEF-vdW, HLE16, KT1, KT2, KT3, rVV10
      Meta-GGA functionals: B97M-rV, BLOC, mBEEF, oTPSS, TM
      Hybrids: CAM-QTP(00), CAM-QTP(01), HSE-HJS, LC-ωPBE08, MN15, rCAM-B3LYP, WC04, WP04
      Double hybrids: B2GP-PLYP, DSD-PBEB95-D3, DSD-PBEP86-D3, DSD-PBEPBE-D3, LS1DH-PBE, PBE-QIDH, PTPSS-D3, PWPB95-D3
      Grimme’s PBEh-3c “low-cost” composite method
      rVV10 non-local correlation functional
    Additional DFT developments:
      New forms of DFT-D3 (J. Witte; Section 5.7.2).
      New standard integration grids, SG-2 and SG-3 (S. Dasgupta and J. M. Herbert; Section 5.5.2).
      More efficient propagator algorithms for real-time TDDFT (Y. Zhu and J. M. Herbert; Section 7.12).
    New integral package for for computing effective core potential (ECP) integrals (S. C. McKenzie, E. Epifanovsky; Chapter 9).
      More efficient analytic algorithms for energies and first derivatives.
      Support for arbitrary projector angular momentum.
      Support up to h angular momentum in the basis set.
    Analytic derivative couplings for the ab initio Frenkel-Davydov exciton model (A. F. Morrison and J. M. Herbert; Section 13.16).
    New ALMO-based energy decomposition analysis (EDA) methods:
      The second-generation ALMO-EDA methods for DFT (P. R. Horn, Y. Mao and M. Head-Gordon; Section 13.7)
      The extension of ALMO-EDA to RIMP2 theory (J. Thirman and M. Head-Gordon; Section 13.8)
      The “adiabatic" EDA method for decomposing changes in molecular properties (Y. Mao, P. R. Horn and M. Head-Gordon; Section 13.9)
    Wave function correlation capabilities:
      Coupled cluster valence bond (CCVB) method for describing open-shell molecules with strong spin correlations (D. W. Small and M. Head-Gordon; Section 6.16.2).
      Implementation of coupled-cluster valence bond with singles and doubles (CCVB-SD) for closed-shell species (J. Lee, D. W. Small and M. Head-Gordon; Section 6.10.4).
Note:  Several important changes in Q-Chem’s default settings have occurred since version 4.4. • Core electrons are now frozen by default in most post-Hartree-Fock calculations; see Section 6.2. • The keywords for calculation of SOCs and NACs were renamed for consistency between different methods. • Some newer density functionals now use either the SG-2 or SG-3 quadrature grid by default, whereas all functionals used SG-1 by default in v. 4.4. Table 5.3 lists the default grid for various classes of functionals.
