7.7 Correlated Excited State Methods: The CIS(D) Family
7.7.1 CIS(D) Theory
The CIS(D) excited state procedure is a second-order perturbative approximation to the computationally expensive CCSD, based on a single excitation configuration interaction (CIS) reference. The coupled-cluster wave function, truncated at single and double excitations, is the exponential of the single and double substitution operators acting on the Hartree-Fock determinant:
|Ψ⟩=exp⁡(T1+T2)⁢|Ψ0⟩ (7.30)
Determination of the singles and doubles amplitudes requires solving the two equations
⟨Ψia|H-E|(1+T1+T2+12⁢T12+T1⁢T2+13!⁢T13)⁢Ψ0⟩=0 (7.31)
and
⟨Ψi⁢ja⁢b|H-E|(1+T1+T2+12⁢T12+T1⁢T2+13!⁢T13+12⁢T22+12⁢T12⁢T2+14!⁢T14)⁢Ψ0⟩=0 (7.32)
which lead to the CCSD excited state equations. These can be written
⟨Ψia|H-E|(U1+U2+T1⁢U1+T1⁢U2+U1⁢T2+12⁢T12⁢U1)⁢Ψ0⟩=ω⁢bia (7.33)
and
⟨Ψia|H-E|(U1+U2+T1U1+T1U2+U1T2+12T12U1+T2U2+12⁢T12⁢U2+T1⁢T2⁢U1+13!⁢T13⁢U1⁢|Ψ0⟩=ω⁢bi⁢ja⁢b (7.34)
This is an eigenvalue equation 𝐀𝐛=ω⁢𝐛 for the transition amplitudes (𝐛 vectors), which are also contained in the U operators.
The second-order approximation to the CCSD eigenvalue equation yields a second-order contribution to the excitation energy which can be written in the form
ω(2)=𝐛(0)𝐭⁢𝐀(1)⁢𝐛(1)+𝐛(0)𝐭⁢𝐀(2)⁢𝐛(0) (7.35)
or in the alternative form
ω(2)=ωCIS⁢(D)=ECIS⁢(D)-EMP2 (7.36)
where
ECIS⁢(D)=⟨ΨCIS|V|U2⁢ΨHF⟩+⟨ΨCIS|V|T2⁢U1⁢ΨHF⟩ (7.37)
and
EMP2=⟨ΨHF|V|T2⁢ΨHF⟩ (7.38)
The output of a CIS(D) calculation contains useful information beyond the CIS(D) corrected excitation energies themselves. The stability of the CIS(D) energies is tested by evaluating a diagnostic, termed the “theta diagnostic”.696 The theta diagnostic calculates a mixing angle that measures the extent to which electron correlation causes each pair of calculated CIS states to couple. Clearly the most extreme case would be a mixing angle of 45∘, which would indicate breakdown of the validity of the initial CIS states and any subsequent corrections. On the other hand, small mixing angles on the order of only a degree or so are an indication that the calculated results are reliable. The code can report the largest mixing angle for each state to all others that have been calculated.
