3.5 Additional Input Sections
3.5.7 Applying a Multipole Field ($multipole_field)
A multipole field can be applied to the molecule under investigation by specifying the $multipole_field input section. Each line in this section consists of a single component of the applied field, in the following format:
$multipole_field
   field_component_1   value_1
   field_component_2   value_2
Each field_component is stipulated using the Cartesian representation e.g., X, Y, and/or Z, (dipole field components); XX, XY, and/or YY (quadrupole field components); XXX, XXY, etc.. The value (magnitude) of each field component should be provided in atomic units.
