11.5 Visualizing and Plotting Orbitals, Densities, and Other Volumetric Data
11.5.7 ELF Plots
Formulated by Becke and Edgecombe74, the electron localization function (ELF),
ELF=[1+(τσ-(∇⁡ρσ)24⁢ρσ35⁢(6⁢π2)2/3⁢(ρσ5/3))2]-1 (11.18)
is a measure of electron localization. It is derived from the Hartree-Fock conditional pair probability and can reveal information about bonding and shell structure279. ELF values lie between 0 and 1, with an ELF=1 representing perfect localization,and an ELF=1/2 representing electron-gas like pair probability. To generate ELF plots with Q-Chem, set the PLOT_ELF $rem variable to TRUE. For closed-shell systems, the α spin ELF is calculated. For open-shell systems, the α, β and spin-adapted ELFs are calculated485.
The following example illustrates the calculation of the ELF for a water molecule.
Example 11.14  A job that evaluates the ELF for H2O on a 50 x 50 x 50 grid. The output is in a cube file called elf_alpha.0.cube.
O       -4.5320698567      0.2524215916      0.0130780103
H       -3.5641829319      0.2173288989     -0.0173259969
H       -4.8109190521     -0.4489616171     -0.5945943692
jobtype opt
method b3lyp
basis 6-31g*
plot_elf true
make_cube_files true
$plots
water
50 -7 7
50 -4 4
50 -4 4
0 1 0 0
(Please refer also to elf_methane.in the $QC/samples directory. This uses the newer $plots format).
