11.2 Wave Function Analysis
11.2.6 General Excited-State Analysis
Q-Chem features a new module for extended excited-state analysis, which is interfaced to the ADC, CC/EOM-CC, CIS, and TDDFT methods.734, 736, 733, 54, 735, 637 These analyses are based on the state, transition and difference density matrices of the excited states; the theoretical background for such analysis is given in Chapter 7.13.
Descriptor Explanation
Leading SVs$^2$ Largest NTO occupation numbers
Sum of SVs$^2$ (Omega) Ω=∥𝜸IF∥2, sum of NTO occupation numbers
E(h) Energy of hole NTO, EI⁢(h)=∑p⁢qαp⁢I⁢Fp⁢q⁢αq⁢I
E(p) Energy of particle NTO, EI⁢(p)=∑p⁢qβp⁢I⁢Fp⁢q⁢βq⁢I
PR_NTO NTO participation ratio PRNTO
Entanglement entropy (S_HE) SH|E=-∑iλi⁢log2⁡λi
Nr of entangled states (Z_HE) ZH⁢E=2SH|E
Renormalized S_HE/Z_HE Replace λi→λi/Ω
<r_h> [Ang] Mean position of hole ⟨x→h⟩exc
<r_e> [Ang] Mean position of electron ⟨x→e⟩exc
|<r_e - r_h>| [Ang] Linear e/h distance d→h→e=⟨x→e-x→h⟩exc
Hole size [Ang] RMS hole size: σh=(⟨x→h 2⟩exc-⟨x→h⟩exc2)1/2
Electron size [Ang] RMS elec. size: σe=(⟨x→e 2⟩exc-⟨x→e⟩exc2)1/2
RMS electron-hole separation [Ang] dexc=(⟨|x→e-x→h|2⟩exc)1/2
Covariance(r_h, r_e) [Ang^2] COV⁢(x→h,x→e)=⟨x→h⋅x→e⟩exc-⟨x→h⟩exc⋅⟨x→e⟩exc
Correlation coefficient Re⁢h=COV⁢(x→h,x→e)/σh⋅σe
Table 11.1: Descriptors output by Q-Chem for transition density matrix analysis. Note that squares of the SVs, which correspond to the weights of the respective NTO pairs, are printed. Ω equals the square of the norm of the 1TDM.
The transition-density (1TDM) based analyses include the construction and export of natural transition orbitals620 (NTOs) and electron and hole densities,736 the evaluation of charge transfer numbers,734 an analysis of exciton multipole moments,54, 735, 637 and quantification of electron-hole entanglement.737 NTOs are obtained by singular value decomposition (SVD) of the 1TDM:
γp⁢qIF =⟨ΨI|p†⁢q|ΨF⟩ (11.14)
𝜸 =𝜶⁢𝝈⁢𝜷†, (11.15)
where 𝝈 is diagonal matrix containing singular values and unitary matrices 𝜶 and 𝜷 contain the respective particle and hole NTOs. Note that:
∥𝜸∥2=∑p⁢qγp⁢q2=∑KσK2≡Ω (11.16)
Furthermore, the formation and export of state-averaged NTOs, and the decomposition of the excited states into transitions of state-averaged NTOs are implemented.736 The difference and/or state densities can be exported themselves, as well as employed to construct and export natural orbitals, natural difference orbitals, and attachment and detachment densities.353 Furthermore, two measures of unpaired electrons are computed.361 In addition, a Mulliken or Löwdin population analysis and an exciton analysis can be performed based on the difference/state densities. The main descriptors of the various analyses that are printed for each excited state are given in Tables 11.1 and 11.2. For a detailed description with illustrative examples, see Refs. 736 and 733.
n_u Number of unpaired electrons nu=∑imin⁢(ni,2-ni)
n_u,nl Number of unpaired electrons nu,n⁢l=∑ini2⁢(2-ni)2
PR_NO NO participation ratio PRNO
p_D and p_A Promotion number pD and pA
PR_D and PR_A D/A participation ratio PRD and PRA
<r_h> [Ang] Mean position of detachment density d→D
<r_e> [Ang] Mean position of attachment density d→A
|<r_e - r_h>| [Ang] Linear D/A distance d→D→A=d→A-d→D
Hole size [Ang] RMS size of detachment density σD
Electron size [Ang] RMS size of attachment density σA
Table 11.2: Descriptors output by Q-Chem for difference/state density matrix analysis.
To activate any excited-state analysis STATE_ANALYSIS has to be set to TRUE. For individual analyses there is currently only a limited amount of fine grained control. The construction and export of any type of orbitals is controlled by MOLDEN_FORMAT to export the orbitals as MolDen files, and NTO_PAIRS which specifies the number of important orbitals to print (note that the same keyword controls the number of natural orbitals, the number of natural difference orbitals, and the number of NTOs to be printed). Setting MAKE_CUBE_FILES to TRUE triggers the construction and export of densities in “cube file” format375 (see Section 11.5.4 for details). Activating transition densities in $plots will generate cube files for the transition density, the electron density, and the hole density of the respective excited states, while activating state densities or attachment/detachment densities will generate cube files for the state density, the difference density, the attachment density and the detachment density. Setting IQMOL_FCHK = TRUE (equivalently, GUI = 2) will export data to the “.fchk” formatted checkpoint file, and switches off the generation of cube files. The population analyses are controlled by POP_MULLIKEN and LOWDIN_POPULATION. Setting the latter to TRUE will enforce Löwdin population analysis to be employed for regular populations as well as CT numbers, while by default the Mulliken population analysis is used.
Any MolDen or cube files generated by the excited state analyses can be found in the directory plots in the job’s scratch directory. Their names always start with a unique identifier of the excited state (the exact form of this human readable identifier varies with the excited state method). The names of MolDen files are then followed by either _no.mo, _ndo.mo, or _nto.mo depending on the type of orbitals they contain. In case of cube files the state identifier is followed by _dens, _diff, _trans, _attach, _detach, _elec, or _hole for state, difference, transition, attachment, detachment, electron, or hole densities, respectively. All cube files have the suffice .cube. In unrestricted calculations an additional part is added to the file name before .cube which indicates α (_a) or β (_b) spin. The only exception is the state density for which _tot or _sd are added indicating the total or spin-density parts of the state density. Analysis of relaxed CIS/TDDFT densities can be triggered by CIS_RELAXED_DENSITY=True. The corresponding output files are marked by _rlx. Computation of ESPs for state, transition, and electron/hole densities can be triggered by setting ESP_GRID=-3. These are indicated by _esp as part of the file name.
The _ctnum_atomic.om files created in the main directory serve as input for a charge transfer number analysis, as explained, e.g., in Refs. 734, 636. Use the external TheoDORE program (theodore-qc.sourceforge.net) to create electron/hole correlation plots and to compute fragment based descriptors.
When doing excited-state calculations from an open-shell reference, libwfa will perform the analysis for both α⁢α and β⁢β transition densities. Make sure you look at the correct one. The way to figure it out is to remember that in open-shell references Nα>Nβ, e.g., in doublet references, the unpaired electron is α and the hole is β. Thus, for transitions of the unpaired electron into the unoccupied orbitals you need α⁢α block, whereas for the transitions from doubly occupied orbitals into the singly un-occupied orbital (the hole) you need the β⁢β block.
Note:  In Hermitian formalisms, γIF is a Hermitian conjugate of γFI, but in non-Hermitian approaches, such as coupled-cluster theory, the two are slightly different. While for quantitative interstate properties both γIF and γFI are computed, the qualitative trends in exciton properties derived from (γIF)† and γFI are very similar. Only one 1TDM is analyzed for EOM-CC.
Note:  In spin-restricted calculations, the libwfa module computes NTOs for the α⁢α block of transition density. Thus, when computing NTOs for the transitions between open-shell EOM-IP/EA states make sure to specify correct spin states. For example, use EOM_EA_ALPHA to visualize transitions involving the extra electron.
STATE_ANALYSIS
       Triggers the general state analysis via libwfa.
       FALSE Do not run excited state analysis. TRUE Activate excited state analysis.
       This analysis produces only minimal computational overhead (as long as no cube files are produced) and can be activated whenever some additional information about the excited state is required.
NTO_PAIRS
       Controls how many hole/particle NTO pairs and frontier natural orbital pairs and natural difference orbital pairs are computed for excited states.
       N Write N NTO/NO/NDO pairs per excited state.
       If activated (N>0), a minimum of two NTO pairs will be printed for each state. Increase the value of N if additional NTOs are desired. By default, one pair of frontier natural orbitals is computed for N=0.
Example 11.2  Basic excited-state analysis example for formaldehyde at the ADC(2)/def2-SV(P) level.
basis = def2-sv(p)
n_frozen_core = fc
method = adc(2)
ee_singlets = [0,1,1,0]
state_analysis = true
8 -0 0 -0.671856
1 0.931138 0 1.11728
1 -0.931138 0 1.11728
Example 11.3  Uracil computed at the PBE0/def2-SV(P) level. Activation of the full libwfa functionality: export of NOs, NTOs and NDOs in Molden format, densities in cube format, and computation of the ESPs of these densities.
method = pbe0
basis = def2-sv(p)
cis_n_roots = 4
cis_singlets = true
cis_triplets = true
rpa = false
molden_format = true
nto_pairs = 3
make_cube_files = true
esp_grid = -3
6 1.19438 1.10251 -0
6 -0.00836561 1.69243 -0
7 -1.1696 0.978035 -0
6 -1.21206 -0.402293 -0
7 0.0346914 -0.97914 0
6 1.28159 -0.348737 0
8 -2.24342 -1.02375 -0
8 2.29918 -0.995854 0
1 -0.12316 2.76714 -0
1 -2.06144 1.4441 -0
1 0.0448178 -1.98999 0
1 2.10472 1.67984 -0
$plots
Write cube files for all 4 states
70 -3.5 3.5
70 -3.5 3.5
30 -1.5 1.5
0 4 0 0
1 2 3 4
