11.11 Anharmonic Vibrational Frequencies
11.11.2 Vibrational Perturbation Theory
Vibrational perturbation theory has been historically popular for calculating molecular spectroscopy. Nevertheless, it is notorious for the inability of dealing with resonance cases. In addition, the non-standard formulas for various symmetries of molecules forces the users to modify inputs on a case-by-case basis,31, 642, 178 which narrows the accessibility of this method. VPT applies perturbation treatments on the same Hamiltonian as in Eq. (4.1), but divides it into an unperturbed part, U^,
U^=∑im(-12⁢∂2∂⁡qi2+ωi22⁢qi2) (11.54)
and a perturbed part, V^:
V^=16⁢∑i⁢j⁢k=1mηi⁢j⁢k⁢qi⁢qj⁢qk+124⁢∑i⁢j⁢k⁢l=1mηi⁢j⁢k⁢l⁢qi⁢qj⁢qk⁢ql (11.55)
One can then apply second-order perturbation theory to get the ith excited state energy:
E(i)=U^(i)+⟨Ψ(i)|V^|Ψ(i)⟩+∑j≠i|⟨Ψ(i)|V^|Ψ(j)⟩|2U^(i)-U^(j) (11.56)
The denominator in Eq. (11.56) can be zero either because of symmetry or accidental degeneracy. Various solutions, which depend on the type of degeneracy that occurs, have been developed which ignore the zero-denominator elements from the Hamiltonian.672, 31, 642, 178 An alternative solution has been proposed by Barone,58 which can be applied to all molecules by changing the masses of one or more nuclei in degenerate cases. The disadvantage of this method is that it will break the degeneracy which results in fundamental frequencies no longer retaining their correct symmetry. He proposed
EiVPT2=∑jωj⁢(nj+1/2)+∑i≤jxi⁢j⁢(ni+1/2)⁢(nj+1/2) (11.57)
where, if rotational coupling is ignored, the anharmonic constants xi⁢j are given by
xi⁢j=14⁢ωi⁢ωj⁢(ηi⁢i⁢j⁢j-∑kmηi⁢i⁢k⁢ηj⁢j⁢kωk2+∑km2⁢(ωi2+ωj2-ωk2)⁢ηi⁢j⁢k2[(ωi+ωj)2-ωk2]⁢[(ωi-ωj)2-ωk2]) (11.58)
