10.3 Constrained Optimization
10.3.1 Geometry Optimization with General Constraints
interatomic distances
stre   atom1   atom2   value
angles
Values in degrees, 0≤v⁢a⁢l⁢u⁢e≤180; atom2 is the middle atom of the bend:
out-of-plane-bends
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180 atom2; angle between atom4 and the atom1–atom2–atom3 plane:
dihedral angles
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180; angle the plane atom1–atom2–atom3 makes with the plane atom2–atom3–atom4:
coplanar bends
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180; bending of atom1–atom2–atom3 in the plane atom2–atom3–atom4:
perpendicular bends
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180; bending of atom1–atom2–atom3 perpendicular to the plane atom2–atom3–atom4:
