9.1 Equilibrium Geometries and Transition-State Structures
9.1.2 Job Control
(May 16, 2021)
Obviously a level of theory, basis set, and starting molecular geometry must be specified to begin a geometry optimization or transition-structure search. These aspects are described elsewhere in this manual, and this section describes job-control variables specific to optimizations.
JOBTYPE
       Specifies the calculation.
       Default is single-point, which should be changed to one of the following options.
       OPT Equilibrium structure optimization. TS Transition structure optimization. RPATH Intrinsic reaction path following.
       Application-dependent.
GEOM_OPT_HESSIAN
       Determines the initial Hessian status.
       DIAGONAL
       DIAGONAL Set up diagonal Hessian. READ Have exact or initial Hessian. Use as is if Cartesian, or transform if internals.
       An accurate initial Hessian will improve the performance of the optimizer, but is expensive to compute.
GEOM_OPT_COORDS
       Controls the type of optimization coordinates.
       -1
        0 Optimize in Cartesian coordinates.  1 Generate and optimize in internal coordinates, if this fails abort. -1 Generate and optimize in internal coordinates, if this fails at any stage of the optimization, switch to Cartesian and continue.  2 Optimize in Z-matrix coordinates, if this fails abort. -2 Optimize in Z-matrix coordinates, if this fails during any stage of the optimization switch to Cartesians and continue.
       Use the default, as delocalized internals are more efficient. Note that optimization in Z-matrix coordinates requires that the input be specified in Z-matrix format.
GEOM_OPT_TOL_GRADIENT
       Convergence on maximum gradient component.
       300 300×10-6 tolerance on maximum gradient component.
       n Integer value (tolerance = n×10-6).
       Use the default. To converge GEOM_OPT_TOL_GRADIENT and one of GEOM_OPT_TOL_DISPLACEMENT and GEOM_OPT_TOL_ENERGY must be satisfied.
       Convergence on maximum atomic displacement.
       1200 1200×10-6 tolerance on maximum atomic displacement.
GEOM_OPT_TOL_ENERGY
       Convergence on energy change of successive optimization cycles.
       100 100×10-8 tolerance on maximum (absolute) energy change.
       n Integer value (tolerance = value n×10-8).
GEOM_OPT_MAX_CYCLES
       Maximum number of optimization cycles.
       50
       n User defined positive integer.
       The default should be sufficient for most cases. Increase if the initial guess geometry is poor, or for systems with shallow potential wells.
GEOM_OPT_PRINT
       Controls the amount of Optimize print output.
       3 Error messages, summary, warning, standard information and gradient print out.
       0 Error messages only. 1 Level 0 plus summary and warning print out. 2 Level 1 plus standard information. 3 Level 2 plus gradient print out. 4 Level 3 plus Hessian print out. 5 Level 4 plus iterative print out. 6 Level 5 plus internal generation print out. 7 Debug print out.
       Use the default.
GEOM_OPT_SYMFLAG
       Controls the use of symmetry in Optimize.
       TRUE Make use of point group symmetry. FALSE Do not make use of point group symmetry.
       Use the default.
GEOM_OPT_MODE
       Determines Hessian mode followed during a transition state search.
       0 Mode following off. n Maximize along mode n.
       Use the default, for geometry optimizations.
GEOM_OPT_MAX_DIIS
       Controls maximum size of subspace for GDIIS.
       0 Do not use GDIIS. -1 Default size = min(NDEG, NATOMS, 4) NDEG = number of molecular degrees of freedom. n Size specified by user.
       Use the default or do not set n too large.
GEOM_OPT_DMAX
       Maximum allowed step size. Value supplied is multiplied by 10-3.
       300 = 0.3
       n User-defined cutoff.
       Use the default.
GEOM_OPT_UPDATE
       Controls the Hessian update algorithm.
       -1
       -1 Use the default update algorithm.  0 Do not update the Hessian (not recommended).  1 Murtagh-Sargent update.  2 Powell update.  3 Powell/Murtagh-Sargent update (TS default).  4 BFGS update (OPT default).  5 BFGS with safeguards to ensure retention of positive definiteness (GDIIS default).
       Use the default.
GEOM_OPT_LINEAR_ANGLE
       Threshold for near linear bond angles (degrees).
       165 degrees.
       n User-defined level.
       Use the default.
FDIFF_STEPSIZE
       Displacement used for calculating derivatives by finite difference.
       100 Corresponding to 0.001 Å. For calculating second derivatives.
       n Use a step size of n×10-5.
       Use the default except in cases where the potential surface is very flat, in which case a larger value should be used. See FDIFF_STEPSIZE_QFF for third and fourth derivatives.
Example 9.1  As outlined, the rate of convergence of the iterative optimization process is dependent on a number of factors, one of which is the use of an initial analytic Hessian. This is easily achieved by instructing Q-Chem to calculate an analytic Hessian and proceed then to determine the required critical point
   H  1  oh
   H  1  oh 2 hoh
   oh  = 1.1
   hoh = 104
   JOBTYPE    freq   Calculate an analytic Hessian
   METHOD     hf
   BASIS      6-31g(d)
Now proceed with the optimization making sure to read in the analytic
Hessian (use other available information too).
   JOBTYPE            opt
   METHOD             hf
   BASIS              6-31g(d)
   SCF_GUESS          read
   GEOM_OPT_HESSIAN   read   Have the initial Hessian
Example 9.2  Optimization in Z-matrix coordinates. The input must be specified in Z-matrix format with coordinates specified. In the example below there are two coordinates representing the bond length and bond angle of a water molecule.
   H 1 r
   H 1 r 2 ang
   r   0.95
   ang 104.5
   JOBTYPE           OPT
   METHOD            HF
   BASIS             STO-3G
   GEOM_OPT_COORDS   2
