6.19 Variational Two-Electron Reduced-Density-Matrix Methods
6.19.3 v2RDM Job Control
RDM_POSITIVITY
       Indicates positivity conditions enforced in the v2RDM optimization.
       DQG
       DQG, Two-electron conditions DQGT1 Two-electron conditions plus the T1 partial three-electron conditions DQGT2 Two-electron conditions plus the T2 partial three-electron conditions DQGT1T2 Two-electron conditions plus the T1 and T2 partial three-electron conditions
       Use DQGT1T2 or DQGT2 for best accuracy, but such computations may become infeasible for large active spaces.
RDM_E_CONVERGENCE
       The threshold for the primal-dual energy gap.
       4
       N for a threshold of 10-N
       Increase for gradient computations.
RDM_EPS_CONVERGENCE
       The threshold for the error in the primal and dual constraints.
       4
RDM_MAXITER
       Maximum number of diagonalization steps in the BPSDP solver.
       50000
       N>0
       Increase for computations that are difficult to converge.
RDM_CG_CONVERGENCE
       The minimum threshold for the conjugate gradient solver.
       12
       Should be at least (RDM_EPS_CONVERGENCE+2).
RDM_CG_MAXITER
       Maximum number of iterations for each conjugate gradient computations in the BPSDP algorithm.
       1000
       N>0
       Use default unless problems arise.
RDM_TAU
       Step-length parameter used in the BPSDP solver.
       10
       N for a value of 0.1 * N
       RDM_TAU should range between 10 and 16 for 1.0τ1.6.
RDM_MU_UPDATE_FREQUENCY
       The number of v2RDM iterations after which the penalty parameter μ is updated.
       200
       N>0
       Change if convergence problems arise.
RDM_SOLVER
       Indicates which solver to use for the v2RDM optimization.
       VECTOR
       VECTOR Picks the hand-tuned loop-based code. BLOCK_TENSOR Picks the libtensor-based code.
       Use the default.
RDM_CONSTRAIN_SPIN
       Indicates if the spin-constraints are enforced.
       TRUE Enforce spin-constraints. FALSE Do not enforce spin-constraints.
       Use default.
RDM_OPTIMIZE_ORBITALS
       Indicates if the molecular orbitals will be optimized.
       TRUE Optimize orbitals. FALSE Do not optimize orbitals.
       Use default unless all orbitals are active.
RDM_ORBOPT_FREQUENCY
       The number of v2RDM iterations after which the orbital optimization routine is called.
       500
       N>0
       Use default unless convergence problems arise.
RDM_ORBOPT_GRADIENT_CONVERGENCE
       The threshold for the orbital gradient during orbital optimization.
       4
       N for threshold of 10-N
       Tighten for gradient computations.
RDM_ORBOPT_ENERGY_CONVERGENCE
       The threshold for energy convergence during orbital optimization.
       8
RDM_ORBOPT_MAXITER
       The maximum number of orbital optimization steps each time the orbital optimization routine is called.
       20
       N>0
RDM_PRINT
       Controls the amount of printing.
       0 Print minimal information. 1 Print information about all iterations.
       Use 1 to analyze convergence issues.
