3.3.2 Reading Molecular Coordinates from a Previous Job or File
  • The READ variable is entered into the molecular coordinate input
  • Scratch files from a previous calculation have been saved. These may be obtained explicitly by using the save option across multiple job runs as described below and in Chapter 2, or implicitly when running multiple calculations in one input file, as described in Section 3.6.
Example 3.8  Reading a geometry from a prior calculation.
   READ
Example 3.9  Reading molecular coordinates from another file. filename may be given either as the full file path, or path relative to the working directory.
   READ filename
