13.4 The Nuclear-electronic Orbital (NEO) Approach: Integrating Electronic and Nuclear Quantum Effects in Quantum Chemistry
13.4.4 Job Control for the NEO-SCF methods
The NEO method is a natural extension of the Self-Consistent-Field methods and it inherits most of its functionalities. Thus, the keywords that are used in the SCF Job Control are used in the NEO-SCF methods with a few additional keywords. The NEO-SCF methods require definition of the nuclear basis sets (see Examples for more information). Refer to Ref. 192 for selection of the protonic basis sets. Only pure (Spherical) Gaussian basis sets are currently available. The following three $rem variables must be specified in order to run NEO-SCF calculations:
NEO
       Enable a NEO-SCF calculation.
       TRUE Enable a NEO-SCF calculation. FALSE Disable a NEO-SCF calculation.
       Set to TRUE if desired.
METHOD
       No default
       NAME Use METHOD = NAME, where NAME is one of the following: HF for Hartree-Fock theory; one of the DFT methods listed in Section 5.3.4.;
       In general, consult the literature to guide your selection. Our recommendations for DFT are indicated in bold in Section 5.3.4.
BASIS
       Specifies the electronic basis sets to be used.
       No default basis set
       General, Gen User defined ($basis keyword required). Symbol Use standard basis sets as per Chapter 8. Mixed Use a mixture of basis sets (see Chapter 8).
In addition, the following $rem variables, that appear in the conventional SCF calculations can be used to customize the NEO-SCF calculation:
SCF_CONVERGENCE
       NEO-SCF is considered converged when the electronic wave function error is less that 10-SCF_CONVERGENCE. Adjust the value of THRESH at the same time. (Starting with Q-Chem 3.0, the DIIS error is measured by the maximum error rather than the RMS error as in earlier versions.)
       5 For single point energy calculations. 8 For geometry optimizations.
       User-defined
NEO_N_SCF_CONVERGENCE
       NEO-SCF is considered converged when the nuclear wave function error is less that 10-NEO_N_SCF_CONVERGENCE.
       7
       User-defined
UNRESTRICTED
       FALSE Closed-shell systems. TRUE Open-shell systems.
       FALSE Constrain the spatial part of the alpha and beta orbitals to be the same. TRUE Do not Constrain the spatial part of the alpha and beta orbitals.
       The ROHF method is not available. Note that for unrestricted calculations on systems with an even number of electrons it is usually necessary to break α/β symmetry in the initial guess, by using SCF_GUESS_MIX or providing $occupied information (see Section 4.4 on initial guesses).
MAX_SCF_CYCLES
       50
       n n>0 User-selected.
SCF_ALGORITHM
       DIIS Pulay DIIS.
       DIIS Pulay DIIS. DM Direct minimizer. DIIS_DM Uses DIIS initially, switching to direct minimizer for later iterations (See THRESH_DIIS_SWITCH, MAX_DIIS_CYCLES). DIIS_GDM Use DIIS and then later switch to geometric direct minimization (See THRESH_DIIS_SWITCH, MAX_DIIS_CYCLES). GDM Geometric Direct Minimization. RCA Relaxed constraint algorithm RCA_DIIS Use RCA initially, switching to DIIS for later iterations (see THRESH_RCA_SWITCH and MAX_RCA_CYCLES described later in this chapter) ROOTHAAN Roothaan repeated diagonalization.
       In the NEO methods, the GDM procedure is recommended.
JOBTYPE
       Specifies the calculation.
       Default is single-point, which should be changed to one of the following options.
       OPT Equilibrium structure optimization. TS Transition structure optimization is currently not available in NEO. RPATH Intrinsic reaction path following is currently not available in NEO.
       Application-dependent. Always use SYM_IGNORE = 1 with geometry optimization.
XC_GRID
       0 Use SG-0 for H, C, N, and O; SG-1 for all other atoms. n Use SG-n for all atoms, n=1,2, or 3 XY A string of two six-digit integers X and Y, where X is the number of radial points and Y is the number of angular points where possible numbers of Lebedev angular points, which must be an allowed value from Table 5.2 in Section 5.5. -XY Similar format for Gauss-Legendre grids, with the six-digit integer X corresponding to the number of radial points and the six-digit integer Y providing the number of Gauss-Legendre angular points, Y=2N2.
Additional NEO specific $rem variables can be used to customize the NEO-SCF calculation:
NEO_E_CONV
       Energy convergence criteria in the NEO-SCF calculations so that the difference in energy between electronic and protonic iterations is less than 10-NEO_E_CONV.
       8
       User-defined
       Tighter criteria for geometry optimization are recommended.
NEO_BASIS_LIN_DEP_THRESH
       This keyword is used to set the liner dependency threshold for nuclear basis sets. It is defined as 10-NEO_BASIS_LIN_DEP_THRESH.
       DOUBLE
       5.0
       User-defined
       No recommendation.
NEO_PURECART
       This keyword is used to specify Cartesian or spherical Gaussians for nuclear basis functions.
       2222
       User-defined
       Default are Cartesian Gaussians. 1111 would define spherical Gaussians similar to keyword PURECART. Current NEO calculations do not support Cartesian electronic or nuclear basis sets with h angular momentum.
NEO_ISOTOPE
       Enable calculations of different types of isotopes. Only one type of isotope is allowed at present.
       1 Default is the proton isotope.
       1 This NEO calculation is using proton isotope. 2 This NEO calculation is using deuterium isotope. 3 This NEO calculation is using tritium isotope.
       Refer to the NEO literature for the best performance on the isotope effects calculations.
NEO_VPP
       Remove J-K terms from the nuclear Fock matrix and the corresponding kernel terms for NEO excited state methods for the case of one quantum proton.
       1 Enable this option. 0 Disable this option.
       Use this only in the case of one quantum hydrogen.
NEO_EPC
       Specifies the electron-proton correlation functional.
       No default
       NAME Use NEO_EPC = NAME, where NAME can be either epc172 or epc19.
       Consult the NEO literature to guide your selection.
The following additional $rem variables can be used to customize the NEO excited states methods calculation to obtain excitation energies:
SET_ROOTS
       Sets the number of NEO excited state roots to find by Davidson or display the number of roots obtained by direct diagonalization.
       n n>0 Looks for n NEO excited states.
SET_RPA
       Do a NEO-TDDFT or NEO-TDHF calculation.
       LOGICAL/INTEGER
       FALSE Do a NEO-TDA or NEO-CIS calculation. TRUE Do a NEO-TDDFT or NEO-TDHF calculation.
DIRECT_DIAG
       Perform direct diagonalization to obtain all the NEO excitation energies.
       0 Use Davidson algorithm.
       1 Do the direct diagonalization. 0 Use Davidson algorithm.
       Only use this option when Davidson solutions are not stable.
